Offline Timnomads
#1 Posted : 06 June 2016 12:47:06(UTC)
Timnomads
Hi All
I would like to try and find a digital model of this SBB 6/6 shunting loco
Does anybody know who makes one
Tim
Edited by user 28 June 2016 12:11:20(UTC)  | Reason: Topic titles should always start with a capital!
thanks 1 user liked this useful post by Timnomads
Offline Unholz
#2 Posted : 06 June 2016 13:07:16(UTC)
Unholz
This one was made (analogue!) by Hobbytrain/Kato in H0 scale a long, long time ago. You might be able to acquire one on the second hand market. A digital version with sound and Telex couplers was recently advertised by a dealer in Switzerland, but it might already be sold out now:
http://shop.zugkraft-stu...u-loksound-m4-v4-0-telex
He currently has a similar diesel yard loco in stock:
Offline waorb
#3 Posted : 06 June 2016 13:39:38(UTC)
waorb
Brazil
Offline Unholz
#4 Posted : 06 June 2016 14:20:01(UTC)
Unholz
Lot of options here: (...)
Er... Confused - but you are aware of the fact that the models/locos shown in your links are completely different types (Bm 6/6 diesel locos)?
The loco in the initial posting is a heavy electric shunter Ee 6/6 II. A few of them are still mostly standing around in the Lausanne Triage marshalling yards in Switzerland.
Offline waorb
#5 Posted : 06 June 2016 21:37:52(UTC)
waorb
Brazil
Offline Timnomads
#6 Posted : 08 June 2016 08:47:05(UTC)
Timnomads
Hi All
Tim
thanks for all your help, with this info I am able to search Ebay, I just hope I can get it to work with my digital CS2 layout
Offline Timnomads
#7 Posted : 08 June 2016 08:59:12(UTC)
Timnomads
Hi all
Tim
Offline Timnomads
#8 Posted : 08 June 2016 15:26:28(UTC)
Timnomads
I have now found one, but the big question - will this work with my marklin CS2 digital controller or will I have to do some work if so what work.
Thank
Tim
Offline waorb
#9 Posted : 08 June 2016 18:26:23(UTC)
waorb
Brazil
Hello Tim.
It depends on which decoder is installed (delta, fx, mfx, MM, DCC), or even pure analog will also work at certain level.
The most important is that the loco must be AC (wechselstrom). Original DC (gleichstrom) loco will also work if some isolation and conversion takes place.
Walter
#10 Posted : 08 June 2016 19:59:54(UTC)
The AC digital version of this model from Kato/Hobbytrain (if offered OEM) should understand at minimum Maerklin Motorola (MM).
Digitizing a DC model:
http://www.eisenbahnfreu...type=file&id=1000107
Offline Timnomads
#11 Posted : 19 June 2016 10:39:37(UTC)
Timnomads
hi All
i now have the loco, BigGrin I have tried to install it on my C S 2 and all it does is run at full speed as soon as it touches the program track. i lifted one end with the driving wheels and tried to install it using all combinations to try and read the address. No luck.
does anybody have an idea on what I should do next Confused
tim
#12 Posted : 19 June 2016 11:59:01(UTC)
On the face of it, it sounds like you have an AC analog loco, as this is what AC analog locos do when placed on track powered by a digital controller such as a CS2.
You would need to convert the loco to digital by installing a digital decoder in it and (possibly) converting the motor to a DC motor.
The specifics of doing this will depend on what model you actually purchased.
Offline Timnomads
#13 Posted : 21 June 2016 17:02:34(UTC)
Timnomads
Thanks, I will take it into the expert and ask him to make it work with a CS2.Mellow
Offline Timnomads
#14 Posted : 28 June 2016 12:16:09(UTC)
Timnomads
Hi All
I have now had my expert have e look at the loco built by Hobbytrains(kato). He is afraid to remove the
cover of the loco as he is worried about whether he would break the bodyshell.
Does anybody have expierence with taking a Hobbytrains model apart and how well made it is ?
Does it easily break, is he justified it not taking the risk, I have enclosed a PDF with the construction and method for opening the loco?
ee66 hobbytrain.pdf (1,300kb) downloaded 21 time(s).
Tim
Offline Unholz
#15 Posted : 28 June 2016 13:36:21(UTC)
Unholz
It is equally difficult to open this loco as with all other (non-Marklin) products that (instead of simple and practical screws) use the method of clips that fit into small "holes" in the underframe. However, in this case you have the advantage (visible in the manual drawing) of only having to press together two rather strong clips underneath the loco near the couplers.
The main problem with digitizing this model will probably be the rather limited space inside for a decoder.
This page was generated in 0.434 seconds.
