Offline baggio
#1 Posted : 02 June 2016 04:27:51(UTC)
baggio
Hello, Everyone:
I am trying to resuscitate some US and Fleischmann wagons whose couplers cannot be changed because they do not have a screw that holds the coupler together.
I am planning on using a bit of glue and attach a NEM pocket to each side of the wagon; inside the pocket I then would insert a coupler. I have done this on one wagon that had a screw with very good results.
Problem is: getting more NEM pockets; I only have one left.
Marklin used to sell them as article no. 203679, but this item is discontinued and no longer available.
Does anyone know where I could get a fresh supply (not necessarily from Marklin)?
Thank you.
BigGrin
#2 Posted : 02 June 2016 05:11:32(UTC)
Roco used to sell a part (40344) that could be used to convert 2 axle and short 4 axle cars/coaches to operate with a NEM socket.
http://www.ben-zerba.cz/...-retrofitset-12-pcs.html
Krois has their own and Symoba models on their website: http://shop.krois-modell...pler-Pockets:::1_78.html
http://www.symoba-schnie...tallationInstruction.pdf
These will permit true close coupling operation.
#3 Posted : 02 June 2016 07:33:00(UTC)
Hi, Silvano!
Märklin is the model rail road with the clear system.
Five-digit spare part numbers get padded with a "0" on the right side. Six-digit spare part numbers get padded with an "E" on the left side.
E203679 is not discontinued, it's available at Märklin and any Märklin dealer can order it for you. It now comes in a bag of four.
Offline baggio
#4 Posted : 02 June 2016 14:06:44(UTC)
baggio
That's excellent news! ThumpUp I will do so today and will let you know.
Thanks to both Mike C and Ho for your assistance. Much appreciated. BigGrin
Offline jcrtrains
#5 Posted : 02 June 2016 19:26:23(UTC)
jcrtrains
There is a Fleischmann part that can be used as well. John's Photo and Hobby usually has a good selection. The following page at Reynauld's has pictures and may help you find what you are looking for. I suspect it is 6523 towards the bottom of the page
Reynaulds pictures of Fleischmann parts
thanks 1 user liked this useful post by jcrtrains
#6 Posted : 03 June 2016 07:24:19(UTC)
Fleischmann makes conversion parts to convert the Fleischmann standard coupling to Maerklin type coupling and to the Fleischmann Profi-Coupling, but does not have a conversion to a NEM socket.
Install NEM pockets on 41xx cars (H0-scale)
by PeFu 16/02/2021 22:36:56(UTC)
Conversion of relex Couplings to Nem pockets (General MRR)
by nevw 26/01/2013 01:04:06(UTC)
Athearn cars w/o NEM pockets (H0-scale)
by mascagni 29/07/2008 17:20:58(UTC)
This page was generated in 0.408 seconds.
