Offline Carlos
#1 Posted : 19 May 2016 04:07:19(UTC)
Carlos
Hello to everybody:
I have the crocodile 3356, what do I need to convert this loco to digital.
Thank you, regards.
Carlos
#2 Posted : 19 May 2016 06:38:08(UTC)
http://www.stummiforum.de/viewtopic.php?t=94989 (German)
https://modellbahn.mahrer.net/lokumbau/ce68/ (German)
https://www.marklin-user...-digital-conversion.aspx
http://www.ajckids.com/TRAINS/MAIN.ASP?nr=92
I hope that these resources help you. Depending on what type of decoder you want to install, you may need to replace the magnet with a permanent magnet. This is included in some of the recent Maerklin conversion kits. To know which one to use, consult the diagrams in the ajckids link.
http://www.eurorailhobbi...0marklin&stock=60943
http://www.eurorailhobbi...0marklin&stock=60760 (with decoder)
You will also need to rewire the lights, as I am pretty certain that the 3356 had the main lead connected to the reverse unit and the return was via the locomotive chassis. If you want to have flicker free lighting, you will have to rewire it so that both wires are connected to the decoder PC board.
I see that you are on Long Island. It is not that far to Katonah, where RJFTrains is based. rjftrains.com I am sure that Robert can assist you if required.
Offline Carlos
#3 Posted : 19 May 2016 20:30:46(UTC)
Carlos
Offline Carlos
#4 Posted : 19 May 2016 20:41:04(UTC)
Carlos
Thank you Mike, Yes my idea is to change the motor and only a decoder to convert the loco to digital, and of course the lights. I'm not interested in train sounds.
Yes I'm from Long Island, and I know Robert but he lives 3 hours from Long Island.
Thank you again, Regards
Carlos
Offline Harvey
#5 Posted : 20 May 2016 01:04:27(UTC)
Harvey
Carlos
Willis Hobbies is closer to you
Harvey
Converting to digital (H0-scale)
by Gunnar 05/02/2022 14:16:30(UTC)
Converting to digital (Digital)
by cintrans 11/07/2018 01:44:29(UTC)
Converting to Digital (Digital)
by Zuege 11/12/2016 05:17:41(UTC)
Converting to digital no output 6021 Control unit (Digital)
by upnatum 05/11/2010 23:49:02(UTC)
helpless in converting to Digital - until now ! (Digital)
by akshaydi 23/07/2010 22:23:35(UTC)
Question on track in converting to digital (Big scale)
by Robert3000 24/05/2003 21:04:46(UTC)
by paul 13/11/2002 00:11:03(UTC)
This page was generated in 0.509 seconds.
