#1 Posted : 19 May 2016 17:44:46(UTC)
I did just present my new Bayern steam in another topic.
When i did tested locomotive,i did notice poor lighting effect front and rear.
This model are equipped with warm light LED.
If you decides to get this model...Don´t!
Save yours money.
A model which cost around €440,00 shall not have weak lighting!! Cursing
I did returned locomotive back.
#2 Posted : 19 May 2016 17:47:29(UTC)
P.S.
The lighting shows up with square appearance too.
#3 Posted : 19 May 2016 18:02:10(UTC)
Isn´t there a CV register that controls the strength of the lighting?
#4 Posted : 19 May 2016 18:34:13(UTC)
I would expect dim lights from an Era I locomotive. They didn't have halogen lamps in those days...
#5 Posted : 19 May 2016 19:00:44(UTC)
What´s difference with the dim lighting and the CV register?
There is no information to set the lighting.
The locomotive do have square appearance.
No matter if strength in the lighting increase.
Offline DTaylor91
#6 Posted : 20 May 2016 04:56:45(UTC)
DTaylor91
My thoughts exactly!
thanks 1 user liked this useful post by DTaylor91
GLI
#7 Posted : 20 May 2016 17:27:09(UTC)
In fact did era 1 steam locomotive used paraffin lamp with the reflector.
In this way they did add brighter light.
The prototyp did had the good brightness of the headlights,which Märklin don´t present with the model.
And besides do Märklin present square appearance headlight.
It´s sooooo wrong!
#8 Posted : 20 May 2016 18:57:13(UTC)
It´s sooooo wrong!
You obviously have first hand experience of Era I locos, so I will bow to your superior knowledge.
#9 Posted : 20 May 2016 19:06:50(UTC)
Is it weak also when you look at it straight into the front lights with your eyes at the same level?
I mean, could be like the Dm3 "phenomenon" that the lights do not disperse the light sideways as much as the "older" Märklin does...
Just a thought...
Offline biedmatt
#10 Posted : 20 May 2016 19:44:43(UTC)
biedmatt
Just a thought...
...which is exactly what you want in a headlamp.
The amount of light a Fresnel lighthouse lense could capture and transmit in parallel beams is incredible. Especially when you consider the manufacturing technology of the 1800s. I saw one in a museum on Lake Erie. They are a gorgeous sight to behold.
https://en.m.wikipedia.org/wiki/Fresnel_lens
Matt
Era 3
#11 Posted : 20 May 2016 23:45:48(UTC)
Headlights on a car are made so the driver can see where he/she is driving, and avoid or brake before obstacles on the road.
Headlights on a locomotive is made so the locomotive can be seen from a distance, since it can't avoid or brake fast enough to avoid obstacles anyway.
Headlights on a locomotive is basically signals for others to see, and in Era I until approximately 1870 - 1880, lamps were low intensity whale oil lamps.
Then came acetylene or kerosene lamps, and later electrical lamps.
Actually the lamps can't be too bright, because the must not blind the driver of an opposing train !!
Story of the locomotive headlamp: http://www.presentationm...otive-headlamp-16257.htm
thanks 7 users liked this useful post by Purellum
#12 Posted : 21 May 2016 08:05:51(UTC)
Just a thought...
Yes Juhan!
When i look straight into the front lights.
#13 Posted : 21 May 2016 08:09:34(UTC)
Very nice link!
We must also remember the lighting in the coach.
They was pretty lighting too under era 1.
Märklins B VI are too weak and when you have wagons with the lighting,you see how difference it appears on the model railway in the dark room.
Not good! ThumbDown
#14 Posted : 21 May 2016 08:21:02(UTC)
I don't see it. Maybe someone can show some photos that allow to compare this loco's headlights with other locos and with the interior lights of the coaches (which are often too bright when factory-installed).
#15 Posted : 21 May 2016 08:54:25(UTC)
For a loco build between 1863 and 1871, the light looks pretty correct for me:
thanks 9 users liked this useful post by Purellum
Offline NZMarklinist
#16 Posted : 21 May 2016 13:39:21(UTC)
NZMarklinist
Hi All,
I have the 37977 Coal Fired Sauerlach model. I haven't run it for awhile but I don't recall the lights being too dim or in any other way not as I was expecting.
I concur with Per's comments ThumpUp
Glen
Auckland NZ
Online kiwiAlan
#17 Posted : 21 May 2016 20:25:52(UTC)
My 3687 Glaskasten also has pretty dim lights, and are about what I would expect for a loco from that era.
#18 Posted : 22 May 2016 09:55:30(UTC)
Here is one video show,that shows the same typical model made of Märklin/Trix.
www.youtube.com/watch?v=u6VEuoiQrS0
This lighting effect you see was the same effect with the model i did returned back.
The lighting effect in the prototype was more powerful and not square appearance!
#19 Posted : 22 May 2016 10:11:32(UTC)
This lighting effect is better!
Just put LED inside of the headlamp.
www.youtube.com/watch?v=CgYLDgHe9ZE
#20 Posted : 22 May 2016 23:35:26(UTC)
The Württemberg K prototype is more than 50 years newer than the Bayerische B VI, and had different types of lamps.
Have you ever seen an oil lamp ?? It is not round and does not have much power in the light.
GLI
Offline franciscohg
#21 Posted : 23 May 2016 06:16:46(UTC)
franciscohg
Chile
Ohhhhh, I think I can live with that square effect....
thanks 4 users liked this useful post by franciscohg
#22 Posted : 23 May 2016 09:47:49(UTC)
They only look square if you look stright into them. From normal viewing angles they look fine.
On my B VI it doesnt seem to be an issue...
#23 Posted : 23 May 2016 17:47:16(UTC)
Oil lamp?
You mean paraffin lamp?
And they used reflector too inside of the head lamp.
The Württemberg K with the headlight was just suggestment,by present ideal of the headlight.
I present again this video which shows square appearance!
#24 Posted : 23 May 2016 21:59:29(UTC)
Oil lamp?
No, I mean ( whale ) oil lamp. And even if the reflector is round; the centre of an oil lamp is still pretty "squarish".
And the Württemberg K head lamp can't be an example of an ideal headlamp for a Bayerish B VI, since they are two different types of lamps; the Bayerishe oil lamp being 50 years older than the electrical lamp on the Württemberg K.
Please look at the different pictures here: https://www.google.co.uk...AhVmK8AKHamHDxQQ_AUIBigB
The flame in an oil lamp is ( more or less ) square; only seen from a distance it looks round, and of course the emitting light after the reflector is "roundish".
P.S: Thomas Edison presented his first electrical light bulb in 1879, which is several years after the Bayerishe B VI was build:
https://en.wikipedia.org/wiki/Thomas_Edison
Offline mattj70
#25 Posted : 24 May 2016 05:39:10(UTC)
mattj70
Looks great to me, would like one!
#26 Posted : 24 May 2016 18:21:25(UTC)
The poor lighting in the Bayern locomotive from Märklin must been stronger to have effect in the layout when you use the trains in the darker room.
That´s way i present Märklin Württemberg to equal.
Yes Thomas Edison did present his first electrical light bulb year 1879,but it toke years by start install light bulb in the steam locomotive.
Offline nitramretep
#27 Posted : 24 May 2016 19:41:23(UTC)
nitramretep
Goofy, By effect I presume you mean a beam of light? I can assure you that Epoch I loks had hardly any capabilities of illuminating more than several yards ahead. The older lamps only had flat glass, in the 30s & 40s I believe, they used domed glass lens that created a "beam" of light, not very far but at least an improvement. I have several early lok lights, real ones, and I can assure you the furthest light beam hardly reaches 25 feet. The earlier lamps were more of a warning light to indicate a lok was coming as opposed to lighting the way.
thanks 2 users liked this useful post by nitramretep
#28 Posted : 24 May 2016 21:38:15(UTC)
OK, so you want to have a realistic looking 1850s locomotive with 1920 head lights, and you still think Märklin made it wrong ??
LOL
#29 Posted : 27 May 2016 19:14:43(UTC)
I don´t understand what is wrong with you.
The new model with the LED´s do have same placement of the light.
The light pipes in the new model is exactly same like old models of the Märklin.
The new model shows too weak lighting and the square appearance,which in the prototype has never been like that.
And yes...Märklin still do it wrong.
Not worth to pay €440,00 for an model with too weak lighting.
Offline Ross
#30 Posted : 29 May 2016 03:51:38(UTC)
Ross
Hi All,
This locomotive LED lighting brightness can be improved/changed.
The resistors for the LEDs are 10k in a 0805 size (103 smd marking) and the decoder F0 light intensity value is 255.
Change resistors to a value in the range 1k max brightness -- 10k default dim look.
There are 2 resistors in the tender and 1 resistor in the locomotive. By reducing the resistor value you will be able to control the brightness by changing the decoder F0 value.
The left hand image lights for F0 is set to a value of 10 and the right hand image for F0 is set to the max value 255 with the default 10k resistors.
Lights look ok without room lights but aren't very good with room lights.
Edited by user 01 June 2016 08:50:23(UTC)  | Reason: Not specified
Ross
#31 Posted : 29 May 2016 11:31:32(UTC)
Hi All,
The resistors for the LEDs are 10k (103 smd marking) and the decoder F0 light intensity is 255 value.
The Bayern locomotive which i did had,was standing at the highest value which are 255.
Yet it was poor lighting effect!
It depends the LED´s are placement too far away from the head lamps.
Märklin use light pipes to the head lamps and that´s way you get lesser light to the head lamps.
And shows up with the square appearance! ThumbDown
Offline Ross
#32 Posted : 01 June 2016 08:46:43(UTC)
Ross
Hello Anders,
The LEDs are very close to the light pipes and with resistor value changes, the brightness can be improved so the lights can be seen with the room lights on.
I have placed a photo above which will help people understand the problem. As for the square look I guess it is up to the individual taste/requirements.
Ross
#33 Posted : 01 June 2016 10:46:23(UTC)
They look really prototypical to me.
#34 Posted : 01 June 2016 12:19:04(UTC)
I have locos with weaker lighting than these. I don't think it's a big deal.
Mind you, I've never sent a loco back for any reason...
Offline Ross
#35 Posted : 09 April 2020 03:57:55(UTC)
Ross
Hi All,
I have finally improved the lighting in my 39021 Bad 1V. This is a combined photo showing a before and after result.
The resistor value I used was 3k
Ross
thanks 2 users liked this useful post by Ross
Offline mvd71
#36 Posted : 09 April 2020 04:34:57(UTC)
Hi Goofy,
I see your point, and thank you for letting people know of the problem. I too have seen locos with the square headlight effect and do not like it.
Ross, thanks for showing us how to improve the lights and providing the resistor valie. With the increased brightness the square effect seems to have gone.
Cheers...
This page was generated in 1.111 seconds.
