Offline Timnomads
#1 Posted : 17 March 2016 13:04:28(UTC)
Timnomads
Hi All
A friend of mine has given me a Marklin 3352 brown crocodile BigGrin
but it is analogue and so will not run on my Digital layout with my CS2 Crying
What pieces do I need to convert it to digital and does any body have a video/instruction that are idiot proof as this
will be my first soldering job.
Tim
#2 Posted : 17 March 2016 13:19:13(UTC)
Wow, lucky fella getting one of those as a gift.
What motor does it have? Is it the large motor like the original CCS800/3015 or is it a later smaller motor?
To make it an mfx beast the new msd3 series decoders would be a good start. If it is a later small motor then an appropriate motor kit with 5 pole anker and permanent magnet, and an msd3 kit (with electric sounds if you want sounds) should make the job pretty straight forward. Otherwise a corresponding esu loksound decoder would be an alternative, again you will need a motor kit.
Online ktsolias
#3 Posted : 18 May 2016 14:47:35(UTC)
ktsolias
Cong you have one of the best Marklin locos.
The Pieces that you need are
60941 motor
and an mfx decoder
Märklin 60942 or 60972 without sound
Marklin 60947 or 60977 with sound
ESU Loc 4 decoder
Enjoy the conversion
Edited by user 19 May 2016 08:30:51(UTC)  | Reason: Not specified
#4 Posted : 18 May 2016 15:20:17(UTC)
Tim, I will show you my conversion in a couple of days.
you can also add 2 ball bearings (2mmx1.5mmx2mm), there is just enough room for an ESU decoder and loudspeaker to fit into the non motor section. you also can change the couplings (E671860) these are coupling shafts which will fit into the front or rear bogy assembly and doing this you than can add any coupling. you could try telex coupling as a bonus.
regads.,
#5 Posted : 18 May 2016 15:37:36(UTC)
The 3352 has the standard DCM motor, so you can get away with using the cheap 60760 motor/decoder kit which only costs about 25 euro. It will not be mfx, but will run perfectly well on any digital layout.
For any 33xx loco you will also need to swap the bulbs to the 18/20 V versions, as the installed ones are rated at about 3V and will blow the moment you place the new decoder in it and put the power on!
Offline Carlos
#6 Posted : 19 May 2016 03:40:38(UTC)
Carlos
60941 motor
and an mfx decoder
Marklin 60947 or 60974 with sound
ESU Loc 4 decoder
Hi Solias, I have the marklin 3356, can I use the same motor and decoder that
You recommended for the 3352.?
Thank you,
Carlos
#7 Posted : 19 May 2016 07:58:43(UTC)
When converting Swiss crocodiles with the 60941 you may have to grind of a corner of the field magnet to make it negotiate tight curves.
Märklin installed a special field magnet at the factory, but it was discontinued.
Online ktsolias
#8 Posted : 19 May 2016 08:46:46(UTC)
ktsolias
60941 motor
and an mfx decoder
ESU Loc 4 decoder
Thank you,
Carlos
Hi Carlos
Fisrt sorry but the 60974 is incorrect the correct is 60977.
The 3352 and 3356 are actually the same, with the same DCM motor. The differencies are that the 3356 has not the Swiss light changeover (thats make the conversion easier for beginners) and the body color.
Of course you can do the conversion with 60760 kit. (60941 motor and basic fx decoder with only 28 speed steps and only f0 and f4 direct assesible).
But I believe that a Loco of this Class and Quality (In 1986 these two locos were the most expensive in the Märklin Catalog), must have a better mfx decoder (128 speed steps 16 functions....). like 60942 or 60972 (256 Speed steps 32 functions).
If you decide to spend rhe extra money to go for sound defintlly the the 60977 is the best choise.
So see your bugdet and go on.
Have a nice time with the conversion
Be carefull with the Lights (Bulbs - sockets etc.)
Costas
Offline dickinsonj
#9 Posted : 19 May 2016 15:01:58(UTC)
I was planning on installing a 60760 kit in a 3356 croc and it sounds like I need to swap bulbs when I do that. I installed the 60760 kit in 3657 and it works well with the exception of flickering lights. I assumed that I might need to change to different bulbs but I was not sure which ones.
Can you provide some part numbers for the bulb options available/appropriate for converted analog loks?
#10 Posted : 19 May 2016 15:18:18(UTC)
E610080 Lamp bi pin 0.7 VA @ 19 V Digital
I recommend checking out this "sticky" topic in the digital section. Lots of answers there to many questions about digital conversions.
https://www.marklin-user...al-conversion-of-M-locos
Offline dickinsonj
#11 Posted : 19 May 2016 16:24:16(UTC)
Thanks so much.
You are right - I need to mine the info that is already available here in the forum before posting questions like this.
I guess I was just being lazy. Blushing
#12 Posted : 19 May 2016 16:54:25(UTC)
Thanks so much.
No problem!
I don't mind answering questions...
#13 Posted : 19 May 2016 17:06:53(UTC)
The specs probably are not correct.
From dealer web site:
E610080 Märklin Ersatzlampe Allglas T1 3,2mm 22V 24mA
E600080 Märklin Ersatzlampe Allglas T1 19V 50mA
http://www.lokmuseum.de/...artikel.php?SArt=1004529
http://www.lokmuseum.de/...artikel.php?SArt=1004523
"Analogue" Märklin H0 light bulbs are 19 V, "digital" light bulbs are 22 V.
E610080 is what you need for flicker-free light between decoder plus and decoder function output.
Offline dickinsonj
#14 Posted : 19 May 2016 20:41:04(UTC)
My 3657 lights were connected to the common chassis ground, so I left it that way - which seemed to align with the included directions from Marklin, such as they were.
Now it sounds like in addition to changing the bulbs I should connect the returns from the lights to the lead for that on the decoder. What I really would like to do is to use LED's instead of incandescents but that is another upgrade subject that I have yet to master.
#15 Posted : 19 May 2016 22:54:39(UTC)
On locos that have a chassis ground for the lights I generally leave them like that and put up with a bit of flicker. It doesn't bother me that much. I don't need the extra work involved in changing the light socket to a bi-pin one.
If you want LEDs to replace the light bulbs there are some manufacturers who make LED packages with screw or bayonet that are a direct replacement for the incandescent bulbs. Unfortunately I can't remember right now who makes them...
Offline dickinsonj
#16 Posted : 20 May 2016 00:39:37(UTC)
The flickering isn't too noticeable when the engine is assembled - it looked terrible when I ran it with the body off to test it. That model already has the bi-pin type bulbs, so changing the ground would not be very hard.
Forum member sgtb recommended a place to buy the LED replacements - when I find that place I will post it. What I didn't know was whether I would need to add resistors to those LED's to get the brightness under control or not with a new decoder.
Update: Here is the place that Bob recommended for LEDs:
http://stores.ebay.com/g..._i.html?_fsub=2236459013
This page was generated in 0.638 seconds.
