Offline nitramretep
#1 Posted : 10 May 2016 22:52:29(UTC)
nitramretep
Having purchased some used freight cars and carriages I have noticed that some are either from a smokers home or have never been cleaned. Does anyone have any ideas as to how to safely clean the bodies of carriages or rolling stock? I am avoiding using any chemical cleaners, such as Windex or Mr. Clean, to avoid damaging the paint work.
#2 Posted : 11 May 2016 00:15:09(UTC)
I would use an old toothbrush to gently scrub into all the details wuth warm water and dish detergent.
Then lay the wagon on a towel somewhere gently warm (e.g. in a window in the sun) to dry.
Don't scrub too hard or you will remove the lettering etc, just do it gently.
#3 Posted : 11 May 2016 04:00:33(UTC)
Washing machine = gentle wash = not recommended
#4 Posted : 11 May 2016 07:00:37(UTC)
I would definitely not use a toothbrush, especially anything that was marked regular or hard. A paint brush is probably a much safer bet. I also must advise NOT to place a model train in exposed sunlight, as this can cause paint fade, plastic deformation and other problems.
What I would recommend for metal locomotives is one of the specially designed products that are advertised to clean die cast models without damaging decals and print.
I know that Hag had such a product advertised in their catalog for years. There are AFAIK also other similar products listed in Walthers catalog.
Cleaning a model with water can leave water stains, especially on plastic windows and on the body itself. The best way to do it probably would be to open the model, remove the window panes and then to clean the surface using a moistened Q-Tip or towel and then let it sit on a small chamois or dry using air, if you have a blow dryer with a no-heat setting. You can also purchase a compressed air can that can be used to dry the model.
Here are some sites with advice:
http://modeltrains.about...leaning-Model-Trains.htm
Has anybody any experience with products like this? http://www.busch-model.c...id=1690&sprach_id=en
Offline Thewolf
#5 Posted : 11 May 2016 13:46:46(UTC)
Thewolf
Hi Mike Cool
I am going to follow this post because the Busch products interests me
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
#6 Posted : 11 May 2016 14:21:55(UTC)
I'm with Alan on this. I always use water and washing-up liquid, with an old toothbrush to get into the corners. I dry as much as possible with paper towels and then leave somewhere warm to dry.
The sun is a bit stronger here in Gibraltar than in the UK, so in Summer I prefer leaving the item in the shade near an open window rather than in the sun. In Winter I leave the item near a heater set to low heat.
Offline nitramretep
#7 Posted : 11 May 2016 17:05:12(UTC)
nitramretep
"Cyber Clean", sold by Busch and many other retailers is a product that is "adhesive" based, in the sense it has not surfactants or emulsifiers that break down oils or airborne contaminants. It relies entirely on adhesion to dust or objects such as hair or dander. I have been told, by a museum curator, that it leaves a slight residue that is difficult to remove (this is the opinion of the person, not mine). I remember a similar product many years ago that also was "cleanable" after many uses and that product was less than brilliant or functional after the first several uses. I would not use Cyber Clean and prefer the use of much more simple and practical materials such as those suggested by Alan.
Offline Thewolf
#8 Posted : 11 May 2016 18:48:48(UTC)
Thewolf
Thus it's better to not use it
Thank you
Thewolf
Offline Unholz
#9 Posted : 11 May 2016 19:58:48(UTC)
Unholz
I always use water and washing-up liquid, with an old toothbrush to get into the corners. (...)
I either use distilled water (ages ago this was also recommended for developing and printing films and photographic papers) and/or a soap-free washing lotion (for instance the German brand called Sebamed or something similar). Instead of the toothbrush which I find too hard, I would also recommend a softer painting brush. For drying I use a simple hairdryer.
This page was generated in 0.446 seconds.
