Offline harris19
#1 Posted : 09 May 2016 20:05:28(UTC)
harris19
HELLO friends,
can anybody told me if the marklin set of passenger cars 43918 is available nowadays with different number
or can you tell me from others (brawa, liliput ) f4 zug merkur if they are available
thank you
harris
#2 Posted : 09 May 2016 20:50:23(UTC)
Do you want any blue F train or does it have to be F 4 "Merkur"?
Which time? 50s? 60s? 70s?
43918 is not in stock at Märklin. I don't think it was made with different numbers over time.
43290 is an older Merkur set in a Märklin box.
Both should be available on eBay.
Offline applor
#3 Posted : 10 May 2016 07:16:18(UTC)
applor
43918 is era IIIb with 4 cars
43290 is era IIIa with 3 cars
The sets have different car types too
As Tom says, you need to specify if you want the Mercury set in eraIIIa or eraIIIb.
For eraIIIa I only know of 43290, though also made under Trix T23420.
Offline harris19
#4 Posted : 10 May 2016 08:40:23(UTC)
harris19
i am looking for F4 merkur around mid 50s early 60s
i was seeing
http://www.rheinmodellba...i/f-zuege-epoche-iii.php
and also find this
http://modellbahn.bergho...e-der-blauen-f-zug-wagen
but can not understand german
i think that 43290 is near my thoughts i will try to find the cars saperate .
thank you for your help Tom and Eric
#5 Posted : 10 May 2016 10:10:18(UTC)
Originally Posted by: harris19 Go to Quoted Post
i think that 43290 is near my thoughts i will try to find the cars saperate.
Märklin 43290 are Fleischmann coaches in a Märklin box (with built-in lights).
You can find Fleischmann coaches for "Merkur" or "Gambrinus", but without lights - and you will have to swap a coupler on one end.
Google Chrome can translate pages for you. Or try Google translate:
https://translate.google...e-iii.php&edit-text=
Offline applor
#6 Posted : 10 May 2016 12:44:15(UTC)
applor
i was seeing
and also find this
That is what google translate is for:
https://translate.google...p;edit-text=&act=url
1955 is the changeover from eraIIIa to eraIIIb which was the removal of 3rd class and change to triple headlights and the changeover to the DB cookie logo.
If you are not specifically modelling 'a' or 'b' then you have many options.
If you are after Mercury by Marklin specifically, then you will be able to find one of the two mentioned sets either 2nd hand or new 'old' stock quite easily.
I am a big fan of F-trains and have the following sets: Merkur, Senator, Glückauf and Dompfeil all for era3a.
A currently available eraIIIa F-train set for Blauer Enzian is available, Marklin model 42615 (or eraIIIb is 42610) which I do not have as I think I have enough already:)
Edited by user 10 May 2016 23:30:48(UTC)  | Reason: Not specified
This page was generated in 0.389 seconds.
