Offline shine
#1 Posted : 26 April 2016 17:20:32(UTC)
shine
Taiwan, Province Of China
Before signal 72XX. There are two blue wire and a yellow wire can be connected to K83 6083.
Does lights 76XXX has two blue wires and a yellow wire?
Before I designed the C track, when the train through 24994 ( C STRAIGHT CIRCUIT TRACK 3-3/4),C track 24611 (C TRACK LEFT TURNOUT) and 76495 lights will change (the same time).
How to use 76XXX signal in the K83 6083 and 24611 and 24994?
#2 Posted : 26 April 2016 22:06:04(UTC)
You would NOT connect a 72xx (Analogue control box) directly to a k83 (Digital Control Box)
The 763xx Yes - BLUE = actually 4 "equavalent" blue wires for up to 4 signal aspects
The 764xx No.
How to use 76XXX signal in the K83 6083 ...
The 76xxx has its own decoder and does not need a 6083(0) k83
Offline shine
#3 Posted : 27 April 2016 03:21:58(UTC)
shine
Will 76XXX can be connected to C track 24611 (C TRACK LEFT TURNOUT)?
#4 Posted : 28 April 2016 03:30:58(UTC)
No, Not connected together
You may use some additional controller device that causes the Signal to do something at the same time as it changes the Turnout .
Analogue
Assuming your 76xxx means a 763xx generation signal, then it could be used in analogue mode and you could have a wire from a 727x control box to switch both it and the turnout.
Digital
For digital control of your 24611, you will need a decoder - here a k83 could be used as the go-between
The 76xxx is quite capable, as it has an internal decoder as standard.
A digital controller would then be able to send commands to each device . In most cases these days a single route can be configured to do the two operations with the single press of a button.
If it is automation you are after then
Analogue
The 727x analogue control switch can be replaced (augmented) with switch of a circuit/contact track from the layout
Digital
A similar Circuit/Contact track, as above, could send its trigger to the controller who in turn would activate the route(s).
This does require an additional - S88/6088(x) - interface box for the controller to receive the trigger through.
This page was generated in 0.343 seconds.
