Offline dominator
#1 Posted : 03 April 2016 22:42:12(UTC)
dominator
Are the close couplers supposed to couple up easily at slow speed. I have found I have had to let the loco kind of crash into them to get them coupled, and not always securely.
Dereck
Offline biedmatt
#2 Posted : 03 April 2016 23:06:56(UTC)
biedmatt
Buy one box of Roco 40397 couplers and you will never look back.
https://www.marklin-user...dunread-change-couplings
Matt
Era 3
thanks 5 users liked this useful post by biedmatt
Offline dominator
#3 Posted : 04 April 2016 05:30:26(UTC)
dominator
Hi. That was a different way of fixing the problem from what I imagined. Might have to buy at least 2 boxes of these. They seem to cost about 1 euro each. many thanks Dereck
#4 Posted : 04 April 2016 06:49:11(UTC)
couplers are sometimes not the problem but either the coupling shaft they're attached to is flexible enough to distort the height or the coupling shaft is loose at its securing point (screw)
another reason as Matt pointed out the spring mechanism is to weak to hold the coupling in the centre position and therefore is being pushed out where it can no longer be coupled together.
the Roco couplings as shown are relatively different to the Märklin short couplings not because they somewhat look identical but they couple together on either coupling at the same time. giving it a much more securer coupling option. Märklin coupling only couple on one side of either coupling.
Edited by user 05 April 2016 02:22:00(UTC)  | Reason: Not specified
Offline dominator
#5 Posted : 05 April 2016 00:22:17(UTC)
dominator
Do the Roco and Marklin couplings work together.
Dereck
Offline biedmatt
#6 Posted : 05 April 2016 01:41:17(UTC)
biedmatt
Dereck
Yes. They are much more universal than M's close coupler.
Matt
Era 3
Offline Danlake
#7 Posted : 05 April 2016 03:25:51(UTC)
Danlake
I just started converting my couplers on the freight wagons to Roco universal couplers as well. My initial impression is that they are much better than Marklin and if you enjoy shunting it's a pleasure with these couplers as they just couple so easilyThumpUp
Brgds Lasse
thanks 4 users liked this useful post by Danlake
#8 Posted : 05 April 2016 06:59:32(UTC)
I have found that Maerklin's close couplers (7203) are easier to manually separate than Roco's 40397. The Maerklin ones usually detach when one car/coach is tilted to one side. The Roco ones absolutely require that you use the little tool to lift the little foot underneath to release the coupling. The other major difference is that the shaft of the Roco coupler is about 1mm longer than the Maerklin one, which means that you will have a gap between cars and coaches. I have found that with certain manufacturers (Heris, Liliput, LSM*, ACME*), that the Roco coupler is better than the Maerklin one because the coupling shaft is slightly shorter than optimal, meaning that the Maerklin couplers do not extend fully as to permit coupling. The Roco couplers with the additional mm solve this issue. LSM and ACME have solved this issue by designing the coupling shaft to have positions that allow the coupler to be only partially inserted.
For Pendelzug (Push-Pull) operation, I rely on the Fleischmann Profi Coupling which seems more rigid and reliable when pushed. I guess that you could use the classic Roco close couplings too. The disadvantage is that these couplings can not be combined with others. My solution was to use Maerklin or Roco couplers on the first and last coaches. This has worked for my Maerklin and Roco SBB EW IV Intercity, Roco SBB IC 2000, Hag/Fleischmann Re 540 S-Bahn, Liliput SBB and BLS EWIII and Liliput and Roco/RailTop NPZ Pendelzug trains.
In some cases, I have duplicates for certain coaches that I can use in combination with other types, e.g. when I want to mix SBB EC and EWIV in the same consist.
Offline dominator
#9 Posted : 11 April 2016 03:55:22(UTC)
dominator
Perhaps Tom Jessup could look at this thread.
Dereck
I had the same problem as Tom with my Br43 coupling between tender and loco. You only had to look at it and it would come apart,.. I silicone it in last time it was out. haven't tested it yet though.
Offline Tom Jessop
#10 Posted : 11 April 2016 08:43:46(UTC)
Tom Jessop
Ok I have almost the same problem ,check out the thread about couplers above in the next sub posting .
Question . How many in a box & how much for the box . quote in either USA money or Euro's .
Cheers Tom in Oz
#11 Posted : 11 April 2016 09:01:24(UTC)
Cheers Tom in Oz
Hi Tom and all !
50 pieces in a box.
I buy them from Axel Schnug, cost is € 43 for the box. http://www.schnug-modell...auf/Kupplungen/Kuppl.htm
Definitely more reliable than Märklin couplers.
But outfitting **all** my rolling stock would be way too expensive.Crying
Only head and tails of established consists (e.g. an Intercity consist, or "block" freight sets made of a number of identical cars) .
The ones that I switch most are mixed freights cars and some local passengers sets, so wherever possible, they are getting the ROCO 40397 treatment
Hope this helps
#12 Posted : 11 April 2016 09:24:24(UTC)
Try with ESU new short couplers!
They are similar looks like Rocos universal short coupler too.
Offline Tom Jessop
#13 Posted : 11 April 2016 12:32:00(UTC)
Tom Jessop
On Doctors orders I am not allowed near any electrical or radio type of apparatus as I will be wearing a 24 hr heart monitor to see what may have caused my recent blackout. This will enable me to count how many couplers that I may consider that I have to change , might be a interesting audit of what I actually have .
Cheers Tom in Oz
#14 Posted : 11 April 2016 14:42:39(UTC)
I hate to be the one to tell you this Tom, but that definately includes your PC! Especially if you have Wifi in the home - then you need to move into the radio free dog house.. Laugh
Offline Tom Jessop
#15 Posted : 11 April 2016 22:57:48(UTC)
Tom Jessop
No dog house here . Looks like Ill have to frequent the street & keep out of way of all RF items in peoples houses , maybe hop into the storm water channel & do some exploring but what will I do at night ? Could always go for a beach walk but not allowed to drive for 6 months either just to see if I have another blackout , Pheww talk about a police stare we live in .
Cheers Tom in Oz ,
#16 Posted : 11 April 2016 23:40:40(UTC)
Cheers Tom in Oz ,
Well, they obviously don't want you doing what the rubbish truck driver did in Glasgow a couple of Christmas' ago ...
That was a case of a guy who had had blackouts and hadn't told his employers - and he had gone through about three employers like this since his first blackout IIRC.
Offline Tom Jessop
#17 Posted : 12 April 2016 01:19:52(UTC)
Tom Jessop
Alan , Exactly what I don't want to happen . When I saw the GP & she said no driving for 6 months & notify the Roads & Traffic authority I did obey her . Scariest thing is having the FD driving me around town, & if I say anything I'm in Bigger trouble . Overall I am improving with the small memory loss that developed after the fall , just having all the waiting to get in for appointments for specialists etc is giving me the pips because of the additional driving .
Cheers Tom in Oz
Offline dominator
#18 Posted : 12 April 2016 01:52:09(UTC)
dominator
Tom, I have the same problem being a passenger in my cars. I get my ear chewed too often. Best cure is to lie down in the back seat and close your eyes. You may even get 40 winks. Believe me, it does help to relieve stress.
Dereck
As you say in Aussie. Poor bastard.
Offline dominator
#19 Posted : 26 April 2016 06:02:56(UTC)
dominator
I have been fiddling with these couplers today and discovered 1 problem with them.
When the cars are brought together, because the couplings are set at exactly the same height, the loops tend to touch and move upwards together, then when they drop down, they drop over the top of the cap and are prevented from hooking onto the pin. When this happens, they appear to have coup[led , but when moving away, will come apart because of this.
The only way these couplings can lock together as intended is for the loop to strike the pin and move up under the cap and move over the pin to engage behind the pin.
I think there can be no good cure for this unless one has different coupling heights from one end of a car to the other. Not very practical . I wonder how the Roco 40397 ones solve this problem.
Dereck
Online H0
#20 Posted : 26 April 2016 08:07:31(UTC)
They don't have a closed loop, they have a hook.
Both hooks pass each other and both hooks fall down behind the pin. Therefore they engage more easy and more reliable than Mother M*'s original.
Offline biedmatt
#21 Posted : 26 April 2016 13:22:23(UTC)
biedmatt
Hi Dereck, I think you have identified the fault with Marklin's close couplers. To a lesser extent this also happens with the old Relex couplers. Roco seems to have solved the problem by sharpening the leading edge of the loop or hook. Their hook is a casting much thicker than Marklin's stamped metal loop. This appears to allow them the ability to sharpen the edge without compromising the strength of the hook. I am not sure you could do the same with M's stamped metal loop.
Matt
Era 3
Offline dominator
#22 Posted : 26 April 2016 23:55:27(UTC)
dominator
Thanks Matt.
Marklin have been champions of metal models for years. [ You could say the were great artificers in metals ]. BUT, they have made a wrong choice in this instant.
The metal loop on Marklin couplers is stamped out of a mild steel sheet.[ they bend very easily ] This means that the edges are sharp, and square. So when 2 square edges come together they want to stay together.
It looks like the Roco couplers have plastic "hooks" which can be moulded to a special shape. { I presumed that must be rounded so that when coming together the have to move past each other. ] Matt has described them as being larger in cross section and shaped with a point. The points coming together are more likely to slide past each other.
The fact that Marklin couplers only latch on one peg is not the problem because when they do latch properly, the don't seem to come apart.
When one loop has coupled, it causes the other loop to slide up and above the pin and pre-uncoupler cap[ PUC ], so it isn't possible with that design for a double latch to happen..
the Roco couplers appear to have a thicker PUC, which causes the hooks to latch [ I may be wrong here ]. They are also one sided so the hooks don't interfere with each other which enables a double latch.
What do we do about it. Lets all go on strikeAngry . Why not let them know that we will not buy their merchandise unless they supply free of charge, Roco couplers. "Yeh right" as the saying goes over hereFlapper .
Maerklin, lf you modified your jig for the loops, so that when a loop is formed, a device comes along and rounds of the leading edge, you may cure the problemBigGrin . You might even coat them with PTFE to make them very slipperyConfused , but that may cause uncouplingCrying ., You could even remove one side of the coupler loop so that the top loop [ now a hook ] is not interfered by the lower loop [ hook ]. Wouldn't that be niceLOL .
Dereck
P S please feel free to upgrade or modify the observations mad here. I need strong glasses now so it is possible [ most likely ] there is something I haven't seen yet.
#23 Posted : 27 April 2016 00:10:28(UTC)
There are many different couplers available that will fit on a NEM pocket. The beauty of this is that we are not restricted to Marklin's, Roco's, or any one coupler of any brand.
I personally like the Marklin close couplers. I've found non other that couple as closely as they do. I also like how the pair of couplings becomes rigid when successfully coupled up, making the close coupling kinetics work much better.
They do share the problem mentioned above of sometimes not coupling up at the first attempt with the Relex type, but I only find this an issue on a small percentage of coupling attempts.
Whatever coupling type you prefer, it doesn't break the bank to swap all your wagons to your preferred type.
Offline biedmatt
#24 Posted : 27 April 2016 00:13:42(UTC)
biedmatt
I think many of us assume the problems are typical of all loop couplers until someone recommends a change. I know I thought it was endemic to loop couplers.
The cap is defined by Marklin as a "pre-uncoupler". It allows you to uncouple the wagens at an uncoupler track and continue to push the wagen to the location desired in your yard without them coupling back together, unless you back away from the opposite wagen.
Matt
Era 3
#25 Posted : 27 April 2016 00:32:02(UTC)
Terrific topic, with loads of good, honest, practical, and technical information which will surely come in useful.
And thanks heaps, for all the great contributions, insights and photos.
This topic might just keep going, like the old "hand uncoupler" thread (from 2007).
Tom in Aus, I hope your health improves.
Offline dominator
#26 Posted : 27 April 2016 03:15:11(UTC)
dominator
Hey Kimball, dont be cheeky. That other thread was a lot of fun. This one is supposed to be serious.
Thanks Matt, have adjusted the wording to suit.
Tom, hope you get better before the 6 months is up. Maybe you ought to wear a lead jacket when viewing this forum. Hope you are still allowed to laugh though, and hopefully have a beer. good for the sole and appetite.
Dereck
Online H0
#27 Posted : 27 April 2016 08:15:27(UTC)
As Matt wrote it is cast metal.
Coming apart is seldom a problem - but sometimes it is.If the metal latch on one side does not move freely then you have a 50% chance that the "good" latch engages and it will work - or a 50% chance that the bad latch engages and train will separate when track is uneven.
Sometimes it helps to turn a car around or swap the order of two cars. Sometimes it helps to bend the metal hook a little bit. Sometimes I just dump the Märklin coupler and put a Roco coupler in.
Another problem: with only one metal loop engaged, the other loop will be too high and will collide with scale models (long coaches, long freight cars).
Roco Universal Coupler couples easier (good for freight cars), Roco Close Coupler couples closer (good for coaches).
I think Fleischmann Profi couplers also couple closer.
I don't see any aspect where Märklin Close Couplers are second to none.
Offline dominator
#28 Posted : 28 April 2016 22:43:20(UTC)
dominator
So far I have managed to bugger 2 of these couplers. I took one side of them off so they coupled together and locked on both pins. Still had the original problem though of them rising together, but caused another problem when pulling the wagons apart. They caught on each other in the opposite direction. Now we know why they stayed with the loop.
At least now I know to leave the loop but find a solution for the sticking together problem. They are fiddly little buggers but didn't take too long to modify.
Dereck
Offline dominator
#29 Posted : 22 December 2016 07:30:30(UTC)
dominator
with the recent purchase of Trix and Roco wagons, i found 2 of the wagons had the older loop couplings in the close coupler socket. Thought that was a waste so i fitted 4 close couplers. One of the wagons kept loosing its couplers and on close inspection I found I could not push them right home. I removed them and checked them withe ones that came out and found they were different. I sorted through the couplers I had spare and found there really were two different designs.
thanks 2 users liked this useful post by dominator
#30 Posted : 23 December 2016 08:31:43(UTC)
with the recent purchase of Trix and Roco wagons, i found 2 of the wagons had the older loop couplings in the close coupler socket. Thought that was a waste so i fitted 4 close couplers. One of the wagons kept loosing its couplers and on close inspection I found I could not push them right home. I removed them and checked them withe ones that came out and found they were different. I sorted through the couplers I had spare and found there really were two different designs...........
Do you mean the design of the spigot part that goes into the pocket, not the loop and guide part?
Online H0
#31 Posted : 23 December 2016 08:45:55(UTC)
I guess that what he refers to.
This groove can make it difficult to insert the coupler the full way. Still you have to get it in completely to achieve full pulling power.
Offline Jabez
#32 Posted : 24 December 2016 00:38:32(UTC)
Jabez
For a thread dealing with couplers, I am surprised that no one has yet directly referenced this article. http://blog.mailez.de/eb...-couplers-for-h0-models/
Offline dominator
#33 Posted : 24 December 2016 06:41:30(UTC)
dominator
HI Jabez. I've been through all that and proved the Roco universal is the best coupler by far. I thought I would point out the 2 differences I found.
Kimball. yes, its the spigot part that goes into the socket. Surprised me.
I will purchase more of the Roco universals later. I have used up the 50 I bought some time ago.
Dereck
#34 Posted : 24 December 2016 13:24:20(UTC)
I've noticed before that some of the Marklin close couplers have a different design of shaft, but they should all still fit in the pockets.
I'm a fan of these couplers and fit them on all my stock as far as I can. My Roco, Liliput and Piko wagons have no trouble working with the Marklin close couplers.
Online H0
#35 Posted : 24 December 2016 14:07:04(UTC)
I did have problems with Roco freight cars when Märklin close couplers were involved.
Longer cars are more likely to cause problems.
This page was generated in 1.050 seconds.
