Offline Harvey
#1 Posted : 18 April 2016 02:40:02(UTC)
Harvey
I have on order an L88 (Walthers has no expected delivery date). I will connect this to my CS2. I will also connect my older S88 to the L88. Does the L88 come with the cable to connect to the CS2 or do I also need to order this (60884)?
Harvey
Offline sjlauritsen
#2 Posted : 18 April 2016 05:05:17(UTC)
sjlauritsen
The L88 uses the 6017x plug on your CS2 or a plug on a Terminal 60125. That type of cable is permanently attached to the L88, so you can say it is included. The L88 also requires a power supply (usually the same that comes with starter sets) 66365 (120 v US) or 66361 (230 v).
The 60884 cable is for connecting the new S88 AC (60881) modules to the CS2 (or existing 6088/60880 modules) without using the L88. You do not really need that cable for your project.
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
#3 Posted : 18 April 2016 23:46:55(UTC)
Hi Harvey,
There is also an installation procedure on page 18 of the attached notice.
The goal is to indicate the CS2 how many units are hoocked on each Link S 88 attached and registered to it.
Failure to do it results in the CS2 not scanning the unit(s) attached to the Link S 88.
Also must redo after each CS2 update.
Link S 88 manual.pdf (3,954kb) downloaded 27 time(s).
Offline Harvey
#4 Posted : 19 April 2016 02:53:32(UTC)
Harvey
Soren, Jean
Thanks for this information - so I don't need to buy the 60884 cable. BigGrin BigGrin BigGrin But, as I have both a 6017 and 60174 booster attached to the CS2, I will need to buy a 60125. Save here, spend there. Also, thanks for the manual. Will require careful reading.
Harvey
This page was generated in 0.418 seconds.
