Offline franciscohg
#1 Posted : 15 April 2016 01:02:40(UTC)
franciscohg
Chile
Hi all, today i received a Brawa 40271 - S9 - what an exquisite locomotive but.....derails on curves...all of themCrying Cursing
The problem is caused by the front truck, and i can see no problem with it, nor in the loco, nor in the manuals.
Anybody aware of a similar problem?
#2 Posted : 15 April 2016 06:59:27(UTC)
Probably is too light weight on the truck.
Try to add some weight on it with the zink.
Offline MaerklinLife
#3 Posted : 15 April 2016 09:36:50(UTC)
MaerklinLife
Have you measured the distance between the wheels and compared them with a working wheel set? The distance might be a bit off, causing the wagon to derail when it enters the curve.
Offline Angus
#4 Posted : 15 April 2016 10:09:42(UTC)
Angus
I had a problem in the past with a loco whose front bogey was not 'sprung' enough to hold it down onto the tracks properly, was fine on straights but curves & turnouts were a problem.
There was a little metal tab like thing on the bogey which I bent a little and then all was well with the loco.
Goofy's suggestion of adding a bit of weight would also help.
#5 Posted : 15 April 2016 11:31:14(UTC)
Check the instructions/manual to see if there is any minimum radius required for the curves. R1 (360mm) might not be valid.(?)
Also -as mentioned- good idea to check the spacing between wheels. The inner spacing should be 13.9mm for perfect running. Depending on track-system (M,K or C) you might get away with slightly bigger spacing (I think C is good for 14.1mm?)
#6 Posted : 15 April 2016 11:35:51(UTC)
Francisco, there is no such thing as I can't find the problem, when you conquer Mt. Everest you have to be prepared for any problem occuring and it is a must by finding a solution otherwise you'll neverf get back to your model trains, good luck with finding the cause.
Offline nitramretep
#7 Posted : 15 April 2016 14:52:01(UTC)
nitramretep
For what its worth a friend of mine who is a Brawa user adds lead shot to hid locomotives on a regular basis when he buys them. Apparently the manufacturer uses a lot of light weight materials and this affects its gripping or traction capabilities. I only have Brawa freight cars and cannot agree or disagree with this weighting issue.
Offline franciscohg
#8 Posted : 15 April 2016 16:44:30(UTC)
franciscohg
Chile
Hi all, thanks for your replies, well, the wheels gauge is correct, little less of 14 mm. I thought of the weight/pressure thing, since when little pressure is applied by hand on the chimney the problem seems to disappear. Sadly there is no spring mechanism on the bogey. There is also no space pot putting a proper spring in between. Will try with a copper plating and/or adding weight. I got a quick response from Brawa but I think they understand that the problem was the tender front truck since they told me to grease the loco tender coupler mechanism. Will continue the work and keep you informed. Anyway, it is a little disappointing to get a no cheap loco that doesn't work well right out of the box.....
Offline franciscohg
#9 Posted : 16 April 2016 03:47:39(UTC)
franciscohg
Chile
Well, i think i am on my way, i have managed to put the spring of an old short pickup shoe to give down pressure to the truck, now the loco can make the turn and pass trough turnouts not derailing, but i think there is uneven pressure because the inner rear wheel of the truck tends to lift causing also a lift in the oposite traction wheel, no derailments at low speed.....i will try to improve the spring solution now.
#10 Posted : 16 April 2016 04:10:31(UTC)
Francisco by rights you shouldn't have to do this and suppose it is always the same dilemma when you don't live in Europe, sending locos back is extremely expensive, I hope Braw is coming up with a solution and send you something to fix the problem.
good luck
Offline franciscohg
#11 Posted : 16 April 2016 04:32:33(UTC)
franciscohg
Chile
Hi John, things are going quite well, i have putted also a spring in the rear truck and the loco is more balanced, but a brake assy tends to hit the pukos in turnouts, i have also removed a plastic washer in the front truck so now it can moves more freely, problem is that the front spring tends to move from its position, i can fix it but i dont want to make any permanent thing until further response from Brawa, i have sent them a video but it seems that i dont catch them on working hoours, so i will wait until monday, but since now i am sure that i can make it run i will order a loksound for itBigGrin
Offline franciscohg
#12 Posted : 17 April 2016 22:05:30(UTC)
franciscohg
Chile
Hi all, yesterday after a surgery a put my hands on a disposable equipment, they usually are made of very good quality materials, and i have found a proper spring, today after a needed nap i have cut it to the right lenght, put it in the front truck, and voila!!!!! Now the loco is well balanced without the need of the back truck spring, so it is running fine over curves and turnouts. Either way will wait from the Brawa response for a more "proffesional" solution, but i am quite happy, the loco is really a beauty and it has been a pity have it condemned to be a shelf queen!!!!!
thanks 3 users liked this useful post by franciscohg
Offline skeeterbuck
#13 Posted : 19 April 2016 16:01:41(UTC)
skeeterbuck
Francisco, Good to hear you have your Brawa loco running well. I have a Brawa 40311 (BR 94) on the way from Germany. It has the smoke & sound already installed. I hoping I don't have any derailing issues as it's a 0-10-0. Laugh It is suppose to have a minimum radius of 360mm.
This is my first venture into the "dark side" (read non-Marklin loco) and I am somewhat anxious to test it out. BigGrin
Chuck
Offline franciscohg
#14 Posted : 20 April 2016 20:13:47(UTC)
franciscohg
Chile
Ohhhhh, fell sorry for youBigGrin BigGrin These Brawa things can be very adictive. Despite that little solved problem that i had, they are exquisite models in almost every aspect except for your wallet's healthBigGrin
This page was generated in 0.417 seconds.
