Offline Timnomads
#1 Posted : 08 February 2016 11:45:29(UTC)
Timnomads
Hi All
I have a track cleaning wagon #46042. How do I clean the pads on the bottom ? Or can I get replacements.
Tim
Offline Tom Jessop
#2 Posted : 08 February 2016 11:50:53(UTC)
Tom Jessop
Apparently you can wash them according to the catalogue . It dose not say what in but presumably warm water & a soap detergent , you could also use a white spirit cleaner which is used in dry cleaning shops for clothes .
Cheers Tom in Oz .
Offline petestra
#3 Posted : 08 February 2016 14:07:25(UTC)
Yes, Tom is correct. I put my dirty pads into a resealable plastic sandwich bag with some liquid laundry detergent and a little bleach in it. Leave it overnight and then
scrub them with an old tooth brush. They will come out like new. Cheers,Peter Smile
thanks 3 users liked this useful post by petestra
Offline Br502362
#4 Posted : 08 February 2016 17:33:22(UTC)
Br502362
Hi Tim,
Replacement pads are also available with Märklin part number E106291.
Åke
Offline Timnomads
#5 Posted : 09 February 2016 09:42:55(UTC)
Timnomads
Thanks, I will try the bag with soap and bleach.
Offline aos
#6 Posted : 09 February 2016 11:15:08(UTC)
aos
Hi Tim, I recently bought two of the newer trucks (46049) from Lokshop. To my surprise, there were 4 spare pads inside each truck. Have you looked inside your truck. You might be pleasantly surprised also. Alan
Offline Timnomads
#7 Posted : 10 February 2016 09:04:09(UTC)
Timnomads
Hi Thanks Alan I found them on first unpacking the truck, they are now also in need of cleaning Crying Crying Crying
Offline Joseph Meiring
#8 Posted : 10 February 2016 16:11:31(UTC)
Joseph Meiring
....little bit of warm soapy (dishwashing liquid) water, an old toothbrush, and they're ready to use again -
Joe
Offline BrandonVA
#9 Posted : 16 February 2016 16:11:13(UTC)
BrandonVA
Everyone has posted sound advice, the pads can be cleaned with soap; I use the same method as Peter (since I learned it from him :) ). However, for reference extra pads can be purchased, Marklin part number E106291. It is a pack of 10 pads. When I got my cleaning car I purchased extra pads. None have worn out, but I rotate through them until all but the last set are dirty, then wash them all at once. I'm lazy ;)
-Brandon
Offline baggio
#10 Posted : 10 March 2016 04:59:12(UTC)
baggio
I use rubbing alcohol Isopropyl.
I simply use a cloth, pour the Isopropyl on it (while attached to the wagon) and then scrub the pads until they look cleaner than before, even if not perfect.
Then, I run the wagon with the pads wet. I repeat the washing after a few runs. This way, I end up with a "wet" cleaning.
Does the job, but needs to be repeated on a regular basis to keep the tracks clean. I am not that diligent in doing it often enough.... Blushing
This page was generated in 0.543 seconds.
