Offline Thewolf
#1 Posted : 25 January 2016 21:29:02(UTC)
Thewolf
Hi everyone Cool
Is it possible to find a table of compliance between rails M and C of marklin?
I saw a layout in rails M, I would want to draw it in ways C
Thank you for your reply
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
#2 Posted : 25 January 2016 21:47:01(UTC)
#3 Posted : 25 January 2016 21:52:31(UTC)
Offline Thewolf
#4 Posted : 25 January 2016 22:02:45(UTC)
Thewolf
Thank you very much Steve Cool ....but the problem : curves I saw nothing on Google
Maybe I badly expressed my question
Thewolf
Offline Thewolf
#5 Posted : 25 January 2016 22:31:21(UTC)
Thewolf
I found this on Web...... would need for me the same plan in rails M
Thewolf
Offline Thewolf
#6 Posted : 25 January 2016 22:46:30(UTC)
Thewolf
I found this on the Web.
Can we say that the rail 5200 is the rail 24330?
Than you for your reply
Thewolf
#7 Posted : 25 January 2016 22:51:52(UTC)
No. 5200 is 24230, 5100 is 24130, 5120 has no equivalent with C track.
See post #3 in this thread for a link to a reference list.
#8 Posted : 25 January 2016 23:16:42(UTC)
If you are trying to redraw an M track layout as C track you will have problems for several reasons.
Straight tracks have different lengths for C track to M track, unless you can use 24172 and 24188 as pairs together, or get 24360 track pieces. These will then be the same length as two 5106 straight pieces.
The 5117 points are a full 30 degrees on the curved track at R1 radius. The corresponding points for C track are 24.6 degrees of R2 radius. This creates problems in crossovers between tracks and when you attempt to match curves with two radii.
The result is that you cannot directly convert an M track layout. The best you can do is take the idea of the M track layout and play with track pieces (or layout planning software) until you have a layout that is a similar look and feel to the original.
Offline Thewolf
#9 Posted : 25 January 2016 23:34:41(UTC)
Thewolf
Hi Alan Cool
When you say : '' The best you can do is take the idea of the M track layout and play with track pieces (or layout planning software) until you have a layout that is a similar look and feel to the original.''. this is exactly what I want to do
Thank your for all your reply
Thewolf
This page was generated in 0.408 seconds.
