Offline thomas buckley
#1 Posted : 22 January 2016 19:02:30(UTC)
thomas buckley
Came across a decent deal on a digital swiss croc locomotive. will these newer locomotives function on my 1970s vintage layout? This forum has been so very helpful during my short time here. All your suggestions and advice have all born fruit and I thank you for your help!!
Offline NS1200
#2 Posted : 22 January 2016 19:17:31(UTC)
NS1200
Yes,digital locomotives will function without problem on your seventies layout.
They will run analogue if you use an oldfashioned simple AC transformer and they will run digital if you use the more sophisticated Mobile Station or Central Station,the latter options will need the use of C track because the control box needs to be plugged into the C connection track.
There is a special piece of track to connect metal track with C track.
Note: if run analogue by means of a simple transformer you will need to set the dip switches on the PCB (Printed Circuit Board) inside the loco in a given configuration so that the loco runs analogue,otherwise it will not respond to your commands,most likely only the lights will work.
The loco will come with a manual in which the setting of the dipswitches is explained.
A toothpick or small sctrewdriver will do the trick.
Make sure you correctly remove the hood from the loco,also explained in the manual.
Which croc is it (Marklin number)?
I have the 3356 (analogue!) which has a metal hood,some crocs have a plastic hood,we can tell you what is what.
http://www.hr4920.de/Web...D/8961/71BA/L1880350.JPG
Paul.
#3 Posted : 23 January 2016 00:11:25(UTC)
thomas buckley
it is 3756 loco.
Offline baggio
#4 Posted : 23 January 2016 05:13:21(UTC)
baggio
Can you please explain this in a bit more detail?
I have digital locos running on an analogue K track layout and they all run. However, some better than others. Some tend to hesitate for no apparent reason from time to time and then pick up speed, etc. On the digital C track they all run fine.
I simply don't understand the reference to having to set up dip switches (Confused ) on the PCB.
Thanks. BigGrin
Offline NS1200
#5 Posted : 23 January 2016 08:54:07(UTC)
NS1200
I was referring to Delta,the simplyfied version of Digital.
Marklin Delta locs have a PCB with dip switches which have to be set in a particular order for analogue operation.
Here the Dutch manual for Delta,showing the pictures.
http://www.marklin.nl/su...lta_control_4F_66045.pdf
About your analogue K track: it is known that the C track has a much better transfer of current because of its connections from track piece to track piece.
Reason for hesitation of loco's could be dirty rails or poor rail connections,or perhaps shortcurrent because of faulty wire connections.
The Metal track i can testify was prone to poor transfer of current,especially because of the blank flexible metal lips to connect the track to other track.
The 3756 has a metal hood and is digital,it is the digital sister of my 3356.
It is a must have!
#6 Posted : 23 January 2016 09:18:23(UTC)
Most Delta locos and some digital locos (37xx series, even some 37xxx series) do not have automatic system detection and the DIP switches must be set for either analogue or digital operation.
Märklin digital locos without DIP switches have automatic system detection ex works.
#7 Posted : 23 January 2016 09:21:28(UTC)
[...] they will run digital if you use the more sophisticated Mobile Station or Central Station,the latter options will need the use of C track because the control box needs to be plugged into the C connection track.
Mobile Stations and Central Stations can be used with any gauge and any track. They may come with spade connectors for H0 C track - if you don't need those spade connectors, just cut them off and connect the station to K track or M track or other gauges.
#8 Posted : 23 January 2016 21:06:56(UTC)
This is only needed on locos over a limited production period because Marklin were unable to license the patent for automatic selection of analogue and digital modes.
All Marklin digital and delta locos have an analogue mode which has all switches off, but to say it is needed on all locos is definitely not correct
This page was generated in 0.967 seconds.
