Offline tintrains99
#1 Posted : 21 December 2015 21:22:50(UTC)
tintrains99
I have a nice Marklin 4-6-0 loco that is supposed to work on 5935 (1020mm) radiuss curves. However the front trucks keep popping off the track on the curves. Any suggestions would be helpful.
Thanks and happy holidays.
Tim
Offline NS1200
#2 Posted : 29 December 2015 08:40:31(UTC)
NS1200
Tim,
That is a nice loco you have there!
According to sources on internet the radius of 1,020 mm is the absolute minimum for this loco.
Probably it only runs properly on this radius at very slow speed.
May i suggest you buy some larger radius track?
She is worth it!
Paul
Offline SteamNut
#3 Posted : 29 December 2015 09:16:23(UTC)
SteamNut
I can only speak from a experience from a HO scale lok but is there spring or a piece of metal that acts like one that keeps tension on the front boogies? Perhaps that needs to be adjusted or perhaps there is a screw loose or missing - Fred
Offline Markus Schild
#4 Posted : 29 December 2015 09:47:56(UTC)
Markus Schild
Hi Tim,
The 5747 (DB class 38, early version) should run also on 1020mm curves properly. I would also assume that the small spring (#23 on the spare part sheet) which should press the bogie on the tracks is missing.
Exploded view: http://medienpdb.maerkli...les/1/pdf/5747_explo.pdf
Link must be copied and pasted in a new window.
Markus
Offline pietercc
#5 Posted : 20 January 2016 03:57:59(UTC)
pietercc
Tim,
I have a marklin BR 38, in 1 of course, and to get it to run on the 1020mm track i removed the tension spring and put a weight on the very front of the truck. The spring can restrict the movement, therefore the wheels derail.
Hope this helps,
Pieter
thanks 2 users liked this useful post by pietercc
This page was generated in 0.467 seconds.
