Offline Timnomads
#1 Posted : 30 November 2015 09:27:31(UTC)
Timnomads
Hi All
I want to create a loop for my line (see attached) which shows a point with the loop coonecting the two ends. I have noticed that when I do this the red and brown would cross over see diag 1. The points has a red and brown connector wich would be wrong. So before I connect this all up and plug in my CS2 and put a loco on the track. Will this design be ok, even though the red and brown are going to be crossed ?
Tim cs2 red brown dilema.pdf (44kb) downloaded 103 time(s).
I forgot to mention I am using marklin C track
thanks 1 user liked this useful post by Timnomads
#2 Posted : 30 November 2015 10:03:23(UTC)
Hi, Tim,
That sort of problem does not exist with Märklin three-rail tracks.
For two-rail tracks there are modules for reversing loops.
Offline Timnomads
#3 Posted : 30 November 2015 10:33:15(UTC)
Timnomads
Hi, Tim,
Thanks Tom, I can now proceed with the design knowing I will not make an expensive mistake.
Offline sjlauritsen
#4 Posted : 30 November 2015 11:22:05(UTC)
sjlauritsen
I use the Lenz LK200 reverse loop module. It works very well and is easy to setup.
When available, some time next year, you can also use the Märklin/Trix reverse loop module (Trix #66846).
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
#5 Posted : 30 November 2015 13:10:31(UTC)
Søren,
I think Tim uses three-rail H0, so his diagram should be brown-red-brown - and at the end of the reversing loop brown meets brown and red meets red.
Offline sjlauritsen
#6 Posted : 30 November 2015 20:38:03(UTC)
sjlauritsen
Yeah, I understood the post as there was an actual problem occurring - and that could only mean two rail. Anyway, now there is an answer for users of both track types. :-)
Søren from Denmark
This page was generated in 0.264 seconds.
