Offline Brian McWhirter
#1 Posted : 24 November 2015 02:29:49(UTC)
Brian McWhirter
I'm not sure this is the proper place to post this. . .
I've got a circa 1964 model 3060 which has been running poorly. Sluggish, no power, etc. I dismantled it to clean, and noticed that one of the gear axles is "floating" where I'd expect to see a bearing (See photo. Red circle indicates axle in question).
Is this normal or not? I don't know if it would cause the noted problems or not, but if it's not correct, I'd like to see about getting it repaired.
Thanks for any input. ..
Brian
thanks 1 user liked this useful post by Brian McWhirter
Offline 3rail4life
#2 Posted : 24 November 2015 03:00:04(UTC)
3rail4life
Hi Brian,
Looks right, that is how it is supposed be.
Good luck with the repairs,
Gordon
#3 Posted : 24 November 2015 16:56:00(UTC)
Clearly the gears are worn out (I can tell from the shape!!)
There is only one cure: replace!
Most are difficult to get these days from mother M, but I have them still from my days as a M repairman.
Let me know what you need.
#4 Posted : 25 November 2015 12:00:53(UTC)
Yes, the brass one on the right definitely has teeth that are very worn. The others don't look so bad, but i would be tempted to replace them anyway.
You should also look at the gears on the wheels, as they will probably be in a similar state.
This page was generated in 0.381 seconds.
