Offline stevep
#1 Posted : 16 November 2015 05:39:32(UTC)
stevep
Hello
New to the forum and just getting back into HO railroading.
I have an old Marklin 6021 digital control station with a 6001 transformer.
I am considering purchasing a 60653 Mobile Station Controller.
What other equipment, if any, is required to use the 60653 controller with
my existing control station and transformer? My set is AC in the USA.
Steve
thanks 1 user liked this useful post by stevep
#2 Posted : 16 November 2015 08:09:59(UTC)
Hi, Steven,
Welcome to the forum.
You will also need a 60113 track box.
You will need a plug to connect your transformer to the track box (I don't have the Märklin spare part number at hand). I'd recommend getting a switching mode power supply instead of the transformer.
66365 is the power supply Märklin offer for US.
Maybe you can get 60653, 60113, and power supply from a starter set. No original box, but usually much cheaper.
Offline rorosha
#3 Posted : 16 November 2015 13:03:03(UTC)
rorosha
Originally Posted by: stevep Go to Quoted Post
Hello
Steve
If you mean, use it as a second controller, in tandem with the 6021, I do not believe that is possible.
There is an interface to hook the 6021 up to a Central Station (Märklin Connect 60128), but I don't think that interface has the intelligence built in to work directly with the Mobile Station. It requires functions provided only by the Central Station.
Rodger
thanks 1 user liked this useful post by rorosha
Offline rorosha
#4 Posted : 16 November 2015 13:06:45(UTC)
rorosha
Hi, Steven,
You're thinking of Märklin 610718, cable to connect power supply to 60113.
#5 Posted : 16 November 2015 13:21:56(UTC)
Correct.
I assumed the 60653 was meant to replace the 6021. Blushing
Online xxup
#6 Posted : 16 November 2015 13:52:01(UTC)
It is possible to use a MS2 with a 6021 by using an Uhlenbrock 63 820 LocoNet Adaptor connected to an Uhlenbrock 63 810 Mobile Station Adaptor.. If the MS2 and MS3 share the same plug then it might be possible to use this to connect a MS3 to a 6021..
Offline stevep
#7 Posted : 16 November 2015 17:14:01(UTC)
stevep
Ok thank you for all quick responses.
I understand better now. The mobile station replaces the 6021
but I will need a track box for sure and perhaps a new 66365 power supply
Steve
Offline rorosha
#8 Posted : 16 November 2015 18:39:50(UTC)
rorosha
Steve
Yes, it can be considered a replacement for the 6021.
As was stated before, you can usually find them from a parted out starter set on eBay and some dealers. If that is the case, they normally come with a power supply and track interface.
One nice thing is that if you want a second control (60653), two can be plugged into one track interface (60113). Only one track interface can be connected to the track at a time, and you only need one power supply. That does save a little bit
Rodger
#9 Posted : 16 November 2015 19:19:22(UTC)
The Uhlenbrock adapter works with the MS1, but AFAIK not with the MS2.
Online xxup
#10 Posted : 16 November 2015 22:48:28(UTC)
Thanks Tom - I was getting my MSs too advanced - it is the MS1 - I don't have a MS2.. Blushing
This page was generated in 0.555 seconds.
