Offline Thewolf
#1 Posted : 14 November 2015 22:22:30(UTC)
Thewolf
Hi everyone BigGrin
A little question please Cool
For M83 and M84, use DCC or MM ?????
Thank you
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
Offline French_Fabrice
#2 Posted : 14 November 2015 23:21:02(UTC)
French_Fabrice
Hi Serge,
It depends if you are comfortable with programming or not.
-If not, stay with MM and use the address assignation with DIP-Switches. It is also advised in the manual to use the DIP-switch mode, thus MM. Remember: DIP-Sw 10 must set to OFF for use with MM.
-If yes, you may use DCC. If you have more than 320 solenoid devices, DCC is mandatory (up to 2048 devices).
Fabrice
thanks 2 users liked this useful post by French_Fabrice
Offline Thewolf
#3 Posted : 14 November 2015 23:32:52(UTC)
Thewolf
Hi Fabrice BigGrin
I knew that I could count on your skillsBigGrin
I appreciate
I shall stay with MM
Have a nice week end Fabrice...and all my sympathies in these hard moment which you live in France....All the Canadians are with you
Serge
thanks 3 users liked this useful post by Thewolf
#4 Posted : 15 November 2015 08:49:49(UTC)
Hi everyone BigGrin
Thank you
Thewolf
I use Lenz LS150 turnout decoder and it works only with the DCC.
It works excellent.
I did tested Märklins new mfx/DCC digital signal and it does work superb with the DCC protocol.
#5 Posted : 15 November 2015 09:16:03(UTC)
It works excellent.
Why do you post this? I cannot see any relevance for the question that was asked.
I assume Serge already bought the decoders and I guess it is too late to recommend other brands.
Back to topic: I would use DCC to fully exploit the capabilities of the decoders. But I am familiar and comfortable with DCC programming (I never use the CS2 for DCC programming because it is much easier with Intellibox or Central Station Reloaded).
The DIP switches are there to give beginners a way to use the decoders without programming.
And when the DIP switches are used, then IMHO it makes no difference whether you set them to MM or DCC because I assume both protocols give the same level of reliability.
If special features are needed at a later time, it is still possible to program the decoder using DCC, but continue using it with MM protocol.
#6 Posted : 15 November 2015 09:43:44(UTC)
It works excellent.
The question was relevance about to use protocol.
Offline Thewolf
#7 Posted : 15 November 2015 15:59:55(UTC)
Thewolf
Hi Goofy BigGrin
Hi TomBigGrin
Thank you for your replies
I have received a message from my dealer and friend Mike : always use MM and use DCC for Trix-2 rails
Have a nice day
Thewolf
#8 Posted : 15 November 2015 17:32:20(UTC)
Since 2003 I use DCC for Märklin three-rail whenever possible.
There is no technical reason to "always use MM".
But if you rely on Mike for advice and support, things will be easier if you follow his advice.
Offline Thewolf
#9 Posted : 15 November 2015 17:51:26(UTC)
Thewolf
Yes Tom..I follow the advices of Mike. I am not enough an expert to contradict him I know my limits
Have a nice day
Thewolf
This page was generated in 0.446 seconds.
