Offline db ice3
#1 Posted : 05 November 2015 16:13:36(UTC)
db ice3
another newbie question...
is there a reason that there are 2 ways to control a point motor?
either with a concealed decoder fitted under the point
or
using the m83 accessory decoder - this seems the cheaper option esp if 4 points are physically close together.
or am i missing something here?
i understand the m83 can also control lighting ( + effects ) and things like the uncoupler ramp.
many thanks for any help as this has got me a bit confused. Crying
#2 Posted : 05 November 2015 16:18:23(UTC)
Other types of track, such as K-Track and the old M-track, don't have the ability to use the concealed decoder that fits directly only to C track. For these one has to use the K83 or M83.
You can also use the k83 or m83 with C track. As you say it is a cheaper option.
Offline db ice3
#3 Posted : 05 November 2015 22:26:50(UTC)
db ice3
thanks so much RayF - makes perfect sense to me now! - ill probably order a few of these useful decoders now i know what i can do with them!
thanks once again!
#4 Posted : 06 November 2015 00:25:36(UTC)
... the old M-track, don't have the ability to use the concealed decoder ....
How soon we forget .....
Ref 6073
... and with good reason!
As to the 74460/74461/74463. I personally see almost no value in them at all , and certainly none that would sway me away from a 6083(0)/60831
#5 Posted : 06 November 2015 00:40:05(UTC)
Ref 6073
As far as I know the 6073 was only available briefly. The standard decoder to use with M-track and K-track was the k83.
However this is not what I meant in my reply. I was referring to decoders available today, and I include the k83 because many shops will still have some in stock.
Offline sjlauritsen
#6 Posted : 06 November 2015 11:55:19(UTC)
sjlauritsen
When setting up a carpet layout, I enjoy the concealed decoder in the road bed. I do not need any wires for that. When building a permanent layout, I would go for the m83 (or similar decoder), because it is cheaper for this purpose.
Søren from Denmark
Problem with Point Decoder 74461 (Digital)
by Hics 12/02/2019 12:43:50(UTC)
Uhlenbrock Point decoder 63410 (General MRR)
by 9azizz 20/12/2018 15:55:51(UTC)
This page was generated in 0.301 seconds.
