Offline Thewolf
#1 Posted : 27 October 2015 20:57:27(UTC)
Thewolf
Hi Everybody BigGrin
I have made an excel table with the numbers of turn outs . I followed the table of Marklin annexed to the decoder.
I have 8 old decoders (74460) and new decoders (74461)
I think that I did a great mistake, because in my excel table the turn out #5 has the address 5, according to is if a old decoder is used or a new.
But in fact it this turn out #5 occupy the place 8 on the keyboard of the CS2, another address (8 of the CS2) appears and it is the one that it is necessary to use, I think no?
Thus it seems to me that it is important to follow the addresses given by the cs2, especially if I insert between 2 turns outs a signal or other one.
I hope to have been precise,... it is an important question.... I wait for the answer to continue
Thank you for your reply
Thewolf
Edited by moderator 29 October 2015 11:34:58(UTC)  | Reason: Not specified
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
#2 Posted : 27 October 2015 21:30:14(UTC)
I'm afraid I don't understand.
In the CS2 you can select between old and new decoders. This is only relevant to have the CS2 display the correct DIP switch settings.
Address 5 is address 5. But for a 74460 decoder use the table from the 74460 manual, for a 74461 decoder use the 74461 manual.
Sometimes decoders are faulty and respond to address 6 while it should be 5 or something like that.
Offline Thewolf
#3 Posted : 27 October 2015 21:48:38(UTC)
Thewolf
Thank you very much Tom
I am going to try to explain better but before when you say
''Sometimes decoders are faulty and respond to address 6 while it should be 5 or something like that.''
what can I do in this case ?
Thank for you reply
Thewolf
Offline Thewolf
#4 Posted : 27 October 2015 22:28:36(UTC)
Thewolf
I followBigGrin
The 3 firts turn outs are ok
this is what I name the place 4 of the keyboard
what you see here (adress 5 of the cs2 ) in my excel table this is adress 4 and this is my great mistake ...because I have configurated all my decoders by following the excel table based on the table of decoder Marklin.....I did not follow the CS2 like this
I hope that it is understandable what I try to explain
Sorry English is not my mother tongueBlushing Blink
Thank you for your understandingBigGrin
Thewolf
#5 Posted : 27 October 2015 23:16:13(UTC)
Thank for you reply
Thewolf
The contact in the little slide switch goes faulty and doesn't make contact anymore. It may also become intermittent with vibration.
Offline Thewolf
#6 Posted : 28 October 2015 00:32:14(UTC)
Thewolf
OK thank you very much....but I suppose that it is necessary to replace the engine or about of other one?
Thwolf
Offline Thewolf
#7 Posted : 28 October 2015 06:42:12(UTC)
Thewolf
Hi everybody Cool
Would the addresses 4 and 5 of the keyboard be defective and in this case, it is better not to use them, no?
Pass at the address 7 would be the good solution, I don't know . I am not a specialist of the cs2. I think that Marklin is miserly of information about the correct use of the cs2. I did some research on internet and I did not find a lot of information
Thank you for your replyBigGrin
Thewolf
Offline Thewolf
#8 Posted : 28 October 2015 14:31:27(UTC)
Thewolf
Hi Everybody Cool
No answers ? Don't worry
I think that I am going to manage as a bigCool
Thewolf
Offline Thewolf
#9 Posted : 28 October 2015 17:10:25(UTC)
Thewolf
Hi all Cool
I tried with a new motor in the turn out...with another adress...the motor does not work
I give up..I am going to sell everything...with all the locos
Thewolf
Offline Thewolf
#10 Posted : 29 October 2015 07:44:31(UTC)
Thewolf
Hello everybody Cool
I had joined on this forum to be possibly able to receive from the assistant seen the very high number of members worldwide.The first question was positively solved and thank you again for the received informations.
The second only... an answer at the beginning... but then the total silence. The problem always exists. I tried to configure 12 turn outs on the keyboard of the cs2. All my turn outs has 74460 or 74461 (8 old and 4 new) The layout contains 40 turn outs (8 74460 32 74461) .
On 12 configured only 4 turn outs work, 8 don't . I almost gave up yesterday and resell all my matos marklin seen the absence of help on this problem. But I decided to pursue that I receive from the help here or not. My dealer is going to help me
I am only a little disappointed ....can be that I badly expressed myself.
Have a nice day
Thewolf
Offline Martin T
#11 Posted : 29 October 2015 08:45:45(UTC)
Martin T
Sorry to hear you have problems configuring your turnout decoders in CS2.
The process is like this:
1) All switch decoders must have their own address. Set address on the decoder DIP-switch. Instruction found here:
2) Set the correcsponding address for the switchposition in your "cs2 keyboard". The process is described here:
Hope this helps.
Regards / Martin T
#12 Posted : 29 October 2015 10:59:52(UTC)
Hi all Cool
Okay. Sorry to hear that. Nice seeing you. Bye!
#13 Posted : 29 October 2015 11:16:34(UTC)
It surely does not help to discuss one problem in two or three threads.
We can only look at the information you provide and look for errors you may have made. If you don't know where the problem is, then it is better to provide too much information than too little.
And I have to admit that so far to me it is unclear what you are asking. English is not my native language, neither is it yours. That surely does not make things easier.
#14 Posted : 29 October 2015 11:34:10(UTC)
Topics have been merged.
Offline Thewolf
#15 Posted : 29 October 2015 15:12:52(UTC)
Thewolf
It is perfect like that Cool
Thewolf
Offline Thewolf
#16 Posted : 29 October 2015 15:19:53(UTC)
Thewolf
Hi all Cool
I don't give up...(my topic of 29 October 2015 03:44:31)
In my life I have never given up and I am going not to begin at my age ThumpUp Smile
Thewolf
Offline Thewolf
#17 Posted : 29 October 2015 15:30:02(UTC)
Thewolf
Hope this helps.
Hi Martin BigGrin
Thank you,,,but it is exactly what i have done with 12 turnouts...the motors of 8 turnouts don't work Cursing Mad
Thewolf
Offline Thewolf
#18 Posted : 29 October 2015 15:33:22(UTC)
Thewolf
Hi TomBigGrin
Thank you for your reply. Don't be worry. I was discouraged
Thewolf
Offline Thewolf
#19 Posted : 29 October 2015 15:40:15(UTC)
Thewolf
I think that it is a "physical" problem which exceeds my skills and my understanding.
I have curent on the born A and O of the turn out …but the motor do not work as if the motors did not receive electric impulse
I don’t understand this absence of reaction. Something smells fishy in the engine or something else.
So the cs2 and the not working turnouts will be send to Mike
Have a nice day
Thewolf
#20 Posted : 29 October 2015 15:53:48(UTC)
I´m glad to see that you are still with us.
I dont run digital, so my help probably wont be huge, but I think you must try a different apporoach;
Use a simple setup; just the CS, power and 1 decoder and 1 switch-motor. Nothing else connected. Set the decoder to one of the addresses that you know works, and then try each motor individually one by one, in this minimal setup. (You could even powercycle the CS before each test ?!)
If the switch-motor has cutoff-contact, you must assure that they are not permanently cut off (which can be the case with K-track motors, when these contacts gets "tired")
You can also try mixing decoders and switch-motors; Combine decoders that work, with switch-motors that dont work, and vice-versa.
Offline Thewolf
#21 Posted : 29 October 2015 16:23:01(UTC)
Thewolf
Hi Henrik Cool
I appreciate your reply Cool
I worked all the night long on this problem...and your suggestion I tried it...nothing Crying and.....this morning the box for shipping is ready Wink
Thewolf
#22 Posted : 30 October 2015 08:07:24(UTC)
I hope you made the standard checks: never swap red and brown, not with the CS2 track connection, not with the decoder connection. Red to B, brown to 0.
The 74490/1 turnout motors fail quite often.Repeat the test with a turnout motor that worked. Just plug the motor into the decoder without installing it into the turnout.
With the new decoders 74461 yellow must be connected even if no lights are connected to the decoder.
When setting DIP switches make sure to use the correct code table.
Offline Thewolf
#23 Posted : 30 October 2015 16:15:41(UTC)
Thewolf
Thank you Tom BigGrin
Blushing Blushing Blushing This is my fault...I cut the yellow wire of the decoder...because as I did not need it I could cut itBlushing Cursing
I read the manuel a few days ago but...forgot this peculiarity.....my eternal distractionBlushing Blushing Angry Angry Cursing
I suppose that it is the reason why the turnouts don't work, no Tom ?
Thank you for your help
Thewolf
#24 Posted : 30 October 2015 17:55:54(UTC)
I suppose that it is the reason why the turnouts don't work, no Tom?
Most likely. Worth a try with the yellow cable in place again.
How are your soldering skills?
Offline Thewolf
#25 Posted : 30 October 2015 18:05:43(UTC)
Thewolf
Thank you Tom BigGrin I appreciate your helpBigGrin
My soldering skills ? If we spoke about something else TomBored Nothing ...Never welded by my life
Thewolf
Offline Thewolf
#26 Posted : 30 October 2015 18:31:12(UTC)
Thewolf
Tom when I said this :
If we spoke about something else, this is a joke BigGrin
This page was generated in 0.643 seconds.
