Offline arrate
#1 Posted : 12 October 2015 22:58:06(UTC)
arrate
I am using the decoder 74461 and 74491. drives with a central 60215. I do something wrong I wanted to change many drives and that's not normal. What I can do wrong?
Edited by moderator 13 October 2015 11:59:29(UTC)  | Reason: Added proper thread title
Offline Thewolf
#2 Posted : 12 October 2015 23:37:09(UTC)
Thewolf
Please Arrate could you better explain what you want?
What do you want to change ? I use 74461 and 74491 with of course 60215BigGrin
Thewolf
Project The Richelieu Valley Railway-CS2-Track C- Itrain-Digital
Offline arrate
#3 Posted : 13 October 2015 00:11:00(UTC)
arrate
What I want to know is that the drives 74491 shortly be working they stop and have to be replaced. for operation I use a decoder 74461 sent by the central CS2 60215
Offline Thewolf
#4 Posted : 13 October 2015 01:06:55(UTC)
Thewolf
Ok ArrateBigGrin
I think that I understand your problem.
Your 74491 suffer from the disease of engines marklin: the purposes of running. Normally engines recently went out of Goppingen should no more have this problem. On another European forum nobody believes in this reliability. I do not believe in it.
Personally I proceeded to an operation: the cut of the purposes of running.
Be attention please : this is for 74490 engine
It is what Mike my dealer and friend told me: do not make it on 74491
On 74491 proceed as this:
What it needs to cut is indicated by the blue arrow
Good luck but I would wait for the notices of the other members who are more competent than me BigGrin
Thewolf
thanks 3 users liked this useful post by Thewolf
Online H0
#5 Posted : 13 October 2015 08:26:14(UTC)
Recent 74490 and early 74491 are just the same.
Recent 74491 are a bit different.
If 74491 fail after a short time, they are most likely like the 74490 shown here.
@Arrate:
BTW: When starting a new thread, you should write a description of the thread into the "Subject" field, not your nickname.
Offline sjlauritsen
#6 Posted : 13 October 2015 12:19:44(UTC)
sjlauritsen
Drives from at least May 2015 and later should not have this problem. I recently got a new batch from Märklin that I installed on my exhibition layout. So far they have been running without any problems. Ealier, even a weekends constant use would have some of the drives failing. This does not happen any more. The future will tell what to expect.
Märklin will change your old drives for new ones if you write them.
I have noticed that the ones I have that are of the "improved kind" have a serial number that starts with 220515nnn. or 220715nnn.. I think it is some kind of date. Here is a comparison of the new and old drive (the new one is the bottom one): http://baneforum.dk/view...64&hilit=74491#p8164
Søren from Denmark
thanks 2 users liked this useful post by sjlauritsen
Offline Thewolf
#7 Posted : 13 October 2015 15:09:15(UTC)
Thewolf
Hi sjlauritsen BigGrin
I am sorry but I am sceptical as for the reliability of these new engines.Blushing
I know at least 2 members of another forum who had problems of functioning after two months of useCrying
Personally I did not want to run a risk, I proceeded to the operation on the new engines as quite a lot of other members on the other forum, by precaution
If Marklin replace the defective engines, it is correct, but Marklin will not solve the problems of the change of engine in the turnouts in a hidden station, especially if we did not think of the accessibility and as we say in french : c'est la poisse la grosse M...eCursing Cursing Crying Crying
I speak only for me, each is free to make as he wishes for it
Have a nice dayBigGrin
Thewolf
Offline sjlauritsen
#8 Posted : 13 October 2015 15:56:02(UTC)
sjlauritsen
I have had some fail even after 6 hours of use. The difference is that the post May 2015 drives had something changed in their electronics. They do not have a different product number, so you have to check the serial number.
I am also reluctant to put my arms in the air, but my initial tests do show that the drives work better than the older drives (with the same product number).
Søren from Denmark
thanks 1 user liked this useful post by sjlauritsen
Offline Thewolf
#9 Posted : 13 October 2015 16:10:30(UTC)
Thewolf
After all, it is a question of confidence and..... I do not trustBlink
This page was generated in 0.360 seconds.
