Offline jimwallace1652
#1 Posted : 12 October 2015 19:11:41(UTC)
jimwallace1652
I have 13 of the MARKLIN 74141 Tower Mast Lights installed and working fine. I discovered one that has a very hot resistor. All others are warm but not "hot" to the touch.
I would like to replace the bulb but can't find a replacement part/bulb and or resistor. I am not sure the bulb can be removed from the socket
#2 Posted : 12 October 2015 20:54:07(UTC)
Does the "hot" resistor have the same color markings as the "warm" ones?
If not, maybe it could be replaced? Or maybe the light bulb used is of the wrong kind and needs to be replaced as you suggest...
When something gets too hot, something is wrong.
#3 Posted : 13 October 2015 00:11:29(UTC)
jimwallace1652
Same bulb as came with product out of the box from a Marklin dealer
Tried to get bulb out but does not want to come out
Offline Chris6382chris
#4 Posted : 13 October 2015 00:53:27(UTC)
Chris6382chris
Jim is it a light bulb or an LED? If it is a light bulb it should screw out of the lampshade.
Chris
Offline NZMarklinist
#5 Posted : 13 October 2015 05:46:56(UTC)
NZMarklinist
From the Marklin Product Database;
74141 Tower Mast with Light.
Group: Accessories
Subgroup: Catenary
Gauge: H0
This is a metal lattice mast. It has a base with a mounting screw and slide-in connection. It is suitable for cross spans or individual catenary hanger arms. It can be used with all track systems. A clear light bulb provides illumination. Mast height without light 170 mm / 6-11/16".
Highlights:
•Metal mast.
•4 mounting points for catenary hanger arms.
Released in:
New items brochure 2004
Product programme 2005
Product programme 2006
Product programme 2007/2008
Product programme 2008/2009
Product programme 2009/2010
Product programme 2010/2011
Product programme 2011/2012
Product programme 2012/2013
Product programme 2013/2014
Product programme 2014/2015
Glen
Auckland NZ
This page was generated in 0.484 seconds.
