Offline Sang Joon Oh
#1 Posted : 13 September 2015 09:33:11(UTC)
Sang Joon Oh
Hello guys.
I have a problem with moving loco in my layout.
When Loco moves in my layout, he often stop to move especially on curved rail.
Also, It occured very often, when loco moves with slow speed.
and although loco didn't stop to move, his sound often restarted on curved rail.
What's the problem with my layout?
Is it need to add a booster or just rail connection mistake?
Please check for my video in youtube.
moving problem1
moving problem2
Thanks.
#2 Posted : 13 September 2015 10:17:08(UTC)
Hi Oh,
Dirty track will be the problem.
Clean the track and the centre studs with a cleaning rubber, or use a 1200 grit emery paper or sandpaper.
#3 Posted : 13 September 2015 10:17:44(UTC)
Welcome to the forum!
Rusty centre rail or dirty outer rails - or both.
Running the locos a few laps at full speed should remove rust from the centre rail.
If problem persists, check outer rails. Residue from traction tyres can build up and lead to contact problems.
A booster won't help.
#4 Posted : 13 September 2015 10:20:14(UTC)
Clean the track with a cleaning rubber, or use a 1200 grit emery paper or sandpaper.
I wouldn't use abrasive cleaners (Roco rubber or sandpaper) for the outer rails. Dirt will stick even better on sandpapered rails.
#5 Posted : 13 September 2015 11:00:20(UTC)
He means to reduce dirt on the studs,by use sandpaper or even better fine file.
The dirt on the rail can been removed with the chemicals gasoline,by use clean cotton like old shirt.
#6 Posted : 13 September 2015 12:20:09(UTC)
Sang Joon Oh
Hi Oh,
Thank you for your advice.
one more question.
Center stud means metal stud bottom of the Loco?
#7 Posted : 13 September 2015 12:38:42(UTC)
I agree. Use some coarse cotton, like old denim or cotton lab coat, with some surgical spirit or denatured alcohol as a cleaning fluid. Some people also use smoke fluid, but I hesitate to do this as it can attack some paints.
Also don't forget to clean the inside edge of the rails, not just the top surface, as the wheels tend to ride on the corner between the flange and tread of the wheel, so that area of the rail needs to be clean. Don't forget to clean all the wheels of locos and wagons as well.
Rubbing with something abrasive leaves tiny grooves in the rail which any oily dirt gets into and binds to eventually leading to a build up of dirt.
#8 Posted : 13 September 2015 12:41:01(UTC)
I wouldn't use a file or sandpaper on the studs. Cleaning them with alcohol should suffice, and then run a loco around at a good speed until it runs reliably should be enough. Filing or sanding leaves bare metal exposed that will then rust and give problems later on.
#9 Posted : 13 September 2015 12:49:53(UTC)
The tracks are metal, the studs are metal and they will corrode. Due to the running of wheels and slider on them there will be wear. When the tracks are not used for a while the tracks and studs, especially when they have been worn slightly, will corrode faster. My experience is that no matter how well you clean them the only way to get rid of surface rust is to pass a track rubber over them.
#10 Posted : 13 September 2015 13:20:26(UTC)
My experience is: no rust when tracks are stored in a room with low humidity. For tracks stored at normal humidity (Western Europe), a few laps at full speed normally solve the problem. If problem persists after a few laps, I sometimes draw the blade of a screwdriver over the centre-rail studs.
I don't have a rubber - never needed one.
Experience may be different in coastal areas or rain forests.
#11 Posted : 13 September 2015 18:21:44(UTC)
We have periods of high humidity both in Summer and Winter, which no doubt aggravates the situation.
As long as I run trains every day I don't need to clean the tracks, but as soon as I have a break of more than a few days I start getting "dead spots" on the track. On my C track I notice that on the affected areas the rails get considerably darker. This is alleviated with cleaning with alcohol or similar, but some locos still refuse to pass unless I rub the track lightly with a rubber, making the metal shine.
#12 Posted : 14 September 2015 07:04:26(UTC)
Originally Posted by: Sang Joon Oh Go to Quoted Post
Hi Oh,
one more question.
Studs means along the middle (centre) of the Marklin track. The little protrusions of metal are called studs or pukos.
The spring metal bottom of the Loco is called the slider, or pick-up shoe. This picks up the positive (+) current, from the pukos.
The Loco wheels pick the negative (-) current from the outer rails.
Offline Sparrow
#13 Posted : 14 September 2015 07:26:48(UTC)
Sparrow
I'd consider slightly and carefully bending pick- up shoe's 'legs' downwards.
When slider is somewhat loose, contact tends to be faulty.
Dirt should be remover often, of course, but is not always the cause of issues like those described here.
Best regards.
Luis.
thanks 1 user liked this useful post by Sparrow
This page was generated in 0.711 seconds.
