Offline Tiki734
#1 Posted : 07 September 2015 02:25:09(UTC)
Tiki734
Would anyone be so kind and upload the spare parts diagrams of the RET800(3014), CEB800 and CM800. I am chasing the old exploded assembly diagrams.
Roger
Edited by user 07 September 2015 06:21:36(UTC)  | Reason: Not specified
#2 Posted : 07 September 2015 08:40:20(UTC)
I will see what I can find for the 3014/RET800.
Please send me your email by Private Message. I have the files for you.
#3 Posted : 07 September 2015 13:51:44(UTC)
If Mike doesn't have them, I'm pretty certain I do.
#4 Posted : 08 September 2015 21:52:45(UTC)
Roger
Hi Roger,
https://www.marklin-user...partsinfo/info-pre57.htm
RE, RES, RET800 are similar, the RE & RES sheets are on my site above and may help you.
Note that the RE800 was superseded by the RES800 and then the RET800 with simplified/improved mechanisms along the way. RET800 became 3014 with the 1957 numbering change.
I don't have the RET800 but may have the 3014 which I can check later if no one else puts it up
Also, see this thread.... https://www.marklin-user...arest-H0-locomotive.aspx
Offline Tiki734
#5 Posted : 09 September 2015 14:20:02(UTC)
Tiki734
Thanks gents I think I have what I need. I've checked the availability of the parts I need for the RET800 and it will cost over $100 in parts so it may no be worth fixing as the body is not great so it's borderline. I started thinking this is great, screws 1 Euro and then the cost mounted up. I have attached some photos of the task. The old owner even snipped off the top light connection on the 2 end plates. No idea what the intent was and it was done by an adult as it's too neat. With the same set there were some 0 Gauge Elastolin figures. I initially paid no attention to them and then had a good look and could not believe the detailed painting. I believe these are from the 50's.
RogerP1190483.JPGP1190490.JPGP1190484.JPGP1190485.JPGP1190486.JPGP1190487.JPGP1190491.JPGP1190489.JPGP1190488.JPG
Exploded parts diagrams (H0-scale)
by Michael4 05/11/2022 12:00:32(UTC)
DL800 Parts Diagrams (Collector's Corner general)
by Tiki734 30/07/2014 06:46:58(UTC)
