Offline Token
#1 Posted : 21 August 2015 15:09:40(UTC)
Token
Having completed a beautiful soldering job, converting analog to digital, I made one careless mistake which resulted in an ominous plume of charcoal smoke, rising out of my 60946 decoder. Scared
Can anyone advise if it is possible to replace the decoder unit only or do I have to buy the whole set again?
regards,
Michael.
#2 Posted : 21 August 2015 19:10:55(UTC)
Hi, Michael,
These decoders are discontinued items. The 60946 currently sells for around € 50, the 60940 for around € 40 (incl. VAT).
If you do not use AUX3 and AUX4 in that loco, the 60940 can be used as a replacement.
When you buy another 60946, maybe you can sell the board. Or use it for another loco, maybe with an ESU decoder (comes without board).
#3 Posted : 21 August 2015 19:14:50(UTC)
regards,
Michael.
What exactly did you do mistake?
Offline Token
#4 Posted : 22 August 2015 03:28:01(UTC)
Token
Thanks for the heads up. I stupidly reversed the decoder when placing it on the pins without realising it - lack of attention. Hopefully I have only fried the decoder and not the board as well?
If so, will I be able to buy an ESU decoder without the rest of the bits as indicated by Tom? Can anyone advise the part number? I was trying to install a sound decoder for diesel (hence 60946).
Thanks and regards,
Michael.
#5 Posted : 22 August 2015 07:08:43(UTC)
Only if you neither use AUX3 nor AUX4. ESU Sound decoders without board are more expensive then Märklin decoders with board. If you want sound, this won't be cheaper.
Warning for all (yep, we had this before): when you install the decoder the wrong way around there will be a small gap between decoder and board. Do not apply power if there is a small, uneven gap!
#6 Posted : 22 August 2015 08:22:22(UTC)
There should be warning,about how to install decoder correct way and incorrect.
#7 Posted : 22 August 2015 09:32:50(UTC)
There is such a warning in the manual.
This would not happen if the hole for the "index pin" (the missing pin) was completely filled.
This page was generated in 0.316 seconds.
