Offline madhu.gn.71
#1 Posted : 16 August 2015 03:39:33(UTC)
madhu.gn.71
India
You have been a member since:: 16/04/2014(UTC)
Hello all,
Last night I was running couple of my trains with the infrared controller that came with my 29163. After controlling with the remote for sometime, it stopped working. When I tried with another IR control, which I had, the trains moved. What could be the reason for this? I checked batteries, power feed connector and the transformer. No problems found with them as the trains moved with another remote. Please help
P.S.: Even though I have MS2, I rely heavily on IR control when it comes to quick set up and tear down.
Here is an image of the IR remote:
Link from google Image Search
Edited by user 19 August 2015 03:37:34(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by madhu.gn.71
#2 Posted : 16 August 2015 11:52:30(UTC)
Hi Madhu,
I think the infra red remotes have an auto-shutoff when they've been left with trains running for a while. Could this have been your problem?
I hope you get it sorted soon!
Offline Shamu
#3 Posted : 16 August 2015 12:16:41(UTC)
Shamu
Madhu,
The easiest way to check if the remote is OK is to point it at digital camera, like your computer or mobile phone.
You will see the flash when you press a button.
thanks 2 users liked this useful post by Shamu
Offline madhu.gn.71
#4 Posted : 16 August 2015 19:21:22(UTC)
madhu.gn.71
India
Hi Madhu,
I think the infra red remotes have an auto-shutoff ...........
Ray, I was operating the buttons in quick succession. So definitely inactive time limit was not at all reached. I just started one train, switched on the light, increased the speed. That's it. It just stopped working
Madhu,
Whoa! that was cool! I checked it against my mobile phone camera and the remote is working. i.e. I do see the flash when I press the buttons. But the trains just wont move. However with another IR remote, it just works fine. Weird!
Madhu
#5 Posted : 16 August 2015 19:28:28(UTC)
Is the light a fluorescent lamp or low energy lamp? I have had problems with these when turned on and then I immediately try and use the TV remote. It seems that during the warm up phase they emit enough infrared or UV light to overwhelm the remote control receiver. A minute or two later (like the amount of time it took you to get the other controller) the lamps will have warmed up enough and the receiver will see the controller again.
Shouldn't be a problem with old tungsten filament light bulbs or LED lamps.
Have you tried the 'faulty' controller again with the lights off? If you haven't it is probably worth doing.
Offline madhu.gn.71
#6 Posted : 17 August 2015 19:58:51(UTC)
madhu.gn.71
India
I tried the steps suggested by you, KiwiAlan. After a little while it worked. Thank you!
But I still did not understand why this is happening now? I've been operating with this remote since 4 years. Could you explain this sentence of yours a bit more " I have had problems with these when turned on and then I immediately try and use the TV remote." ?
Madhu
#7 Posted : 18 August 2015 18:01:32(UTC)
Madhu
In our lounge we have some wall lights that are fitted with candle type low energy bulbs, these were the 'fluorescent lamp' type which take a little while to warm up to full brightness (they are now LED ones, so the problem doesn't happen now). I could use the TV remote to work the TV (change channels or volume, etc) but immediately after turning on the wall lamps the remote would no longer work. After a couple of minutes the remote would work again, once the bulbs had 'warmed up' and were putting out full brightness.
I suspect you are seeing a similar effect, without knowing your house layout and type of bulbs you are using.
happy to help.
Alan
Offline Jay
#8 Posted : 18 August 2015 19:51:58(UTC)
Jay
Hi Madhu thanks for starting the topic and Alan for the explanation and a remedy for the problem.I have not encounted the problem myself
but am fascinated by the phenomenon.
J
thanks 1 user liked this useful post by Jay
Offline madhu.gn.71
#9 Posted : 19 August 2015 03:37:02(UTC)
madhu.gn.71
India
happy to help.
Alan
Lovely explanation Alan! Thank you and I'm changing the status of this question to solved.
Madhu
#10 Posted : 19 August 2015 18:18:16(UTC)
happy to help.
Alan
Madhu
You are welcome Madhu, I must admit it is an odd problem.
@Jay, I haven't come across it elsewhere, I suspect it is only a limited range of these bulbs that do it, some take a while to 'warm up', others do seem to give full light output almost immediately, and I suspect they won't have the problem.
Jay
#11 Posted : 19 August 2015 19:50:56(UTC)
Low energy bulbs can indeed take a while before they are fully functional after turned on, and indeed they emit reddish/purple - at least some of them, before they are fully shining after several minutes...
Interesting phenomenon, this effect on IR remotes - you learn something new in the forum every day... ThumpUp
Offline baggio
#12 Posted : 20 August 2015 03:29:36(UTC)
baggio
I guess you checked the back of the remote to make sure you matched the position input (1,2,3,4) to the train you were trying to control?
Also, did you try to lift the loco off its tracks and put it back on? When I did this on my set, the loco sound came back....
Offline madhu.gn.71
#13 Posted : 20 August 2015 05:18:11(UTC)
madhu.gn.71
India
Yes Baggio. All the basic troubleshooting was done. Address was set right, hard reset was done by unplugging the transformer from the wall socket, loco re-positioned and battery checked. If I may recall, just before this incident, one of my loco's pantograph (this is a dummy pantograph on the loco from start pack 29752) brushed against the tunnel portal ceiling and the loco got derailed. I disconnected the main AC power source immediately, lifted the train and placed it back in position. After that remote had stopped working.
Now it is working fine
This page was generated in 0.573 seconds.
