Poll Question : Do you want Märklin do multi locomotives like ESU?
Choice Votes Statistics
(Poll is closed)  Total 47 100%
Guests can't see poll choices and poll results. Try login or register. Guests can't vote. Try login or register. The poll has expired.
2 Pages12>
#1 Posted : 23 July 2015 09:12:34(UTC)
ESU has become more popular with theirs multi protocol locomotives by use with two or three rails.
So i decides to see if members of Märklin want to see Märklin do it same way,by vote.
#2 Posted : 23 July 2015 21:37:23(UTC)
The concept of a universal locomotive was first brought to my attention in a flyer from the Swiss firm RailTop. The new generation of decoders can operate with AC or DC power. The hard part is designing the model so that it can be run on 2 rail DC or 3 rail AC. AC uses the centre rail and both rails for common ground. 2 Rail DC uses one rail for positive and the other one for negative. The universal locomotives can be switched from one system to the other by installing (either screw mounting or clipping on) a slider for the third rail and joining the axle contacts to provide a common ground.
This can still be problematic as the axle/wheel contacts would have to be split in order to avoid a short on DC tracks. Having the wheels remain isolated can avoid this, but it makes it harder to use such a locomotive with Maerklin sensors that use the common ground to trigger solenoids.
The ESU models are designed to be easily changeable from one system to the other. In the case of the recent Lima Expert ETR 600/610, conversion requires changes to pin switches on the PC board and the installation of a cable for the centre rail slider. This is not a clip-on and go solution.
There also remains the issue of wheel profile and wheel spacing that would become an issue, especially on older M Track or Fleischmann DC tracks.
It is an interesting concept that will be reality over the next few years, but I don't see this becoming mainstream for Maerklin as this would cut into sales of Trix versions of the same models.
#3 Posted : 23 July 2015 21:50:31(UTC)
Is that really an issue? Märklin use the same wheel sets for the Märklin and Trix Hobby TRAXX locos - and I haven't heard complaints about that loco.
#4 Posted : 23 July 2015 21:55:53(UTC)
But it would be great to take your M loco to a 2-rail layout too, instead of buying one Märklin and one Trix of the same prototype...
Kind of would embrace the thought of "one model railroading for all" as a single hobby for individuals, clubs and display layouts...
Maybe even the DC/DCC guys would then look at M as a viable alternative to shop for, even if the price might be a bit steep for
some - but M acceptance among "the rest of the world" would probably mean increased sales also for M when the rumour spreads...
Offline biedmatt
#5 Posted : 23 July 2015 22:23:26(UTC)
biedmatt
If they design it right, this is not a problem. You will need pickups for both sides of the loko for two rail, now you just need a SPDT switch or simply a two position jumper (3 pins) and you can open the hot side of the decoder from the right rail pickup and close the pickups of both rails together. This will allow old M contact track to still function. Now make the third rail to the hot side of the decoder power and you are done.
Matt
Era 3
#6 Posted : 24 July 2015 09:23:52(UTC)
Both side of the wheels do have contact with the rail as common ground.
ESU do have this and it works fine with Märklins sensor like s88.
Just pull off the pick up shoe,you have two rail locomotives and the wheels are isolated,which do have work for the other solenoids sensor.
ESU locomotives also works with the ABC technology,by use with the brake generator like Lenz BM1.
To have an multi locomotive makes more richer variation for the model railway.
When Märklin produce one model,they produce in two way,three and two rail system,which means you buy two models,while with the ESU just one!
#7 Posted : 24 July 2015 13:56:48(UTC)
I think a multi system model is only really attractive to those who are undecided on which system to choose. I would not imagine there are many people who will buy both AC and DC versions of the same loco to run on different layouts, so normally one would buy either the Marklin or the Trix version, depending on your track.
I'm always wary of products that claim to work just as well as two different ones. There's always a compromise somewhere.
Offline rbw993
#8 Posted : 24 July 2015 15:45:17(UTC)
rbw993
I have to agree with Ray. I am strictly 3 rail so it offers no benefit.
Roger
Offline grnwtrs
#9 Posted : 24 July 2015 17:57:28(UTC)
grnwtrs
Roger
Me too!!
I have enough trouble changing to Marklin couplers from Viessmann as an exampleBigGrin BigGrin
Offline biedmatt
#10 Posted : 24 July 2015 18:14:27(UTC)
biedmatt
The advantage is to the manufacturer, they would not need two product lines (Marklin and Trix) and/or they could streamline inventory. As ESU is doing. But as Marklin wants to be a plug and play company, this would be incompatable to their traditional customer base.
Matt
Era 3
Offline Hackcell
#11 Posted : 24 July 2015 18:27:12(UTC)
Hackcell
Costa Rica
I think that having M developing this kind of equipment will take a part of the other manufacturers' share; eventually forcing them to do the same. It will eventually mean more 3 rail equipment actually not available (US equipment).
Danilo Jiménez
Costa Rica, pura vida!!
Offline taliesin
#12 Posted : 24 July 2015 18:38:05(UTC)
taliesin
Most would want one or the other, I certainly would not want to pay more for a more complicated and possibly compromised engine with features that I would never use, three rail does me fine, cheers Rob
thanks 1 user liked this useful post by taliesin
Offline mrmarklin
#13 Posted : 24 July 2015 19:47:56(UTC)
mrmarklin
The real problem with this is that DC and Three rail use differing flanges.
We run in a modular environment on the ETE layout, and this is an issue in terms of reliability.
Offline Hackcell
#14 Posted : 24 July 2015 21:55:53(UTC)
Hackcell
Costa Rica
Somehow ESU figured out how to deal with that issue without exchanging the wheels.
Danilo Jiménez
#15 Posted : 25 July 2015 06:33:16(UTC)
I also agree, even with other brand "3 rails"
Over the years on some occasions I have bought a non-marklin "3 rail" when I particularly wanted a model which was not made by M.
Whilst they have all "worked", most do feature some compromise which has been a little disappointing.
I must say however that my last venture into this area, a Piko DB 219 ("UBoat"), was a faultless exception.
PJ
#16 Posted : 25 July 2015 07:49:43(UTC)
Yes...when we are talking about other brands models.
ESU do produce wheels,that fits for the two and three rails.
If ESU decides to start produce wagons too,they will put all wagons with the same wheels flanges.
Simple to understand,ESU do hold to the NEM 310 wheels as standard.
Märklin use NEM 340.
But you can also run with the NEM 310 wheels on the Märklin tracks.
#17 Posted : 25 July 2015 07:55:01(UTC)
If ESU decides to start produce wagons too, they will put all wagons with the same wheels flanges.
Yes, and then most Märklin users will want to change the wheel sets anyway, if the use detection on the layout.
Unless of course, ESU mounts a resistor in all axles, which most 2-railers then wants to remove.
#18 Posted : 25 July 2015 08:10:22(UTC)
Useless to use resistor in all axles,if not ESU do offer the wheels as special.
Yes Märklin users CAN CHANGE to non-isolated wheels,if they want to use detection on the layout with the three rail.
#19 Posted : 25 July 2015 08:29:33(UTC)
Märklin use identical wheelsets for two-rail and three-rail versions of TRAXX, Ludmilla, EuroRunner, V 80.
Do you have problems with those?
Märklin already have wheelsets for universal locos, and they also have the decoders. They only need a switching mechanism.
Unified parts for Märklin and Trix reduce their production costs. A single ref. number for an "AC/DC" version would reduce logistics costs.
#20 Posted : 25 July 2015 10:50:21(UTC)
No, not if you know how to do it, and have the right equipment.
Of course it won't work with relays.
#21 Posted : 25 July 2015 21:53:54(UTC)
These locomotives are bogie designs. The short wheel-base on bogies make them more tolerant of track standards.
A long wheelbase design like for example a two axle container car or a "Thunder-box" coach would be less likely to run well with a wheel-set that is not accurate to the relevant standard.
#22 Posted : 25 July 2015 23:23:57(UTC)
This thread is about universal locomotives. While Märklin so far use universal wheelsets on two-truck locos only, ESU use them also for steamers like the new BR 94.5-17.
Even if this approach should not work for all rolling stock, it apparently does work for some rolling stock (Bo'Bo' and Co'Co' locos from Märklin/Trix).
#23 Posted : 26 July 2015 00:22:55(UTC)
I'm just giving these as an example.
BTW, will ESU's Br94 run on R1 track? No, I thought not....
Offline Shamu
#24 Posted : 26 July 2015 03:33:05(UTC)
Shamu
Its pretty much a moot point to me, if I wanted to run 2 rail I would have chosen from the plethora of manufactures.
If I wanted the largest selection of loco's and rolling stock I would have chosen 2 rail.
However asides from a childhood desire for Marklin I wanted to run 3 rail not 2 so the choice was obvious. I have no desire to have 2 layouts ( 3 and 2 rail) so I see zero benefit in having "M" (or anyone) making dual purpose loco's.
Those that consistently seam to want or expect "M" to do things like the 2 rail brigade astound me, why buy or touch "M" in the first place Confused.
To each their own I guess Laugh.
thanks 4 users liked this useful post by Shamu
#25 Posted : 26 July 2015 07:58:01(UTC)
The ESU approach: digital locos with many features and prepared for two-rail and three-rail.
Märklin and others could choose a different approach.
Many Trix customers complain about factory-installed decoders in Trix locos - they want purely analogue locos.
Many Märklin customers complain about factory-installed decoders in Märklin locos - they want DCC or something else that Märklin don't provide yet.
Many Märklin and Trix customers complain about the sound of factory-installed decoders - they want better sound or quiet locos.
The approach could be: sell an analogue loco with speaker and NEM decoder socket, but without decoder. Yes, it won't run on three-rail without a decoder.
Advantages: a single ref. number for both rail systems. Customers who want analogue two-rail operation will be happy. Customers who want three-rail operation with ESU sound and ABC braking will be happy.
The friendly service-oriented dealer has new opportunities to show good individual service.
Only dreaming. Märklin won't do it. I think Roco and Fleischmann won't do it either.
Piko use two-rail wheelsets that do not work on Märklin C-track, so their wheels are far from ideal - not a good starting point.
Offline Danlake
#26 Posted : 26 July 2015 09:41:16(UTC)
Danlake
I am not an expert, but looking at these videos and already myself experienced issues with M-track turnouts derailment, I would hesitate buying anything that may or may not fit probably..
https://www.marklin-user...ets-and-C-Track-turnouts
Anyhow, the thread is an interesting discussion. The ideal would of course have been to have one common norm for HO scale regardless of manufactures.. But I guess it all comes down to a compromise between protypical design and sturdiness and reliability.
ESU locomotives are really nicely looking and impressive with their new design features. But also fairly expensive and the range is rather limiting...
Brgds - Lasse
#27 Posted : 26 July 2015 10:01:59(UTC)
But Märklins curved track R1 is to tight.
ESU will solve the problem,if not less they report by saying:Sorry you need large curve tracks.
#28 Posted : 26 July 2015 10:11:34(UTC)
Brgds - Lasse
Märklin users complain about the C tracks geometry!
In fact they do derailment other companys products too!
Even if you have non-isolated wheels like Rocos,it won´t sometimes fits with the C tracks.
So this will says:Not always all models can use with the C tracks.
I have seen ESU multi locomotives use on the C tracks in the youtube.
It works fine and it has same trucks for the two rails.
#29 Posted : 26 July 2015 13:03:56(UTC)
Marklin also make G1 locos that will not run on the tightest radius G1 track that Marklin makes. It is not a new phenomenon.
#30 Posted : 26 July 2015 15:54:43(UTC)
I notice about C tracks from Märklin and Trix.
Both of them do have same geometry on the tracks and live frog too.
The only difference are the height of the rail.
Märklin code 90
Trix code 83
Märklin and Trix locomotives do have same chassis and bogie.
The only difference are the height of the wheel flanges and to isolated or non-isolated wheels.
If Märklin do start with the multi locomotives,they will support NEM 310 wheels and add this in the ac locomotives.
However there is still some problem and it´s the tracks,which do have wrong live frog and guide/check rail.
Offline Hackcell
#31 Posted : 26 July 2015 19:34:20(UTC)
Hackcell
Costa Rica
Märklin code 90
Trix code 83
MTH and ESU found a way to use the same wheel in both AC and DC locomotives: NEM 311, which is 99,95% similar than RP25 wheels. The only thing is the distance between flanges.
Danilo Jiménez
Offline Hackcell
#32 Posted : 26 July 2015 19:37:51(UTC)
Hackcell
Costa Rica
Marklin C R1 and R2 curves plainly suck. R3+ radius look better and allow larger wagons and locomotives to deal with it without any issues.
Danilo Jiménez
#33 Posted : 26 July 2015 19:57:15(UTC)
Objection:
- Not everybody disposes of an entire basement.
- Out of sight, R1 is utmost space-saving and thus extremely helpful to turn trains around (hidden dogbone reverse loops, shadow station...) .
- Working with easements, coaches running over a R2 curve look better than on a wider radius curve without easements.
- When viewing a curve from the inside (even better: from below), even a train on a tight radius looks good.
Thus said, C-track geometry plus locos and rolling stock mastering the former are the only reason why I am in the HO business.
:o)
#34 Posted : 26 July 2015 23:27:16(UTC)
Well said, Ak!
I don't like being told that my layout "plainly sucks". It gives me many hours of pleasure and allows me to run my collection of Marklin trains instead of being restricted to just keeping them in their boxes.
thanks 7 users liked this useful post by RayF
Offline Hackcell
#35 Posted : 27 July 2015 07:55:24(UTC)
Hackcell
Costa Rica
Well said, Ak!
I did not mean to offend anybody or their layouts, perhaps the wording I used wasn't the best. If I did sound offensive (it seems that's the case) I apologize. I also feel upset when people criticizes my hobbies and they don't even have one.
At least in my case I had tons of issues with R1 and R2 curves, therefore for my specific case these radii "suck". It doesn't mean I contempt other persons' work by using these radii on their layouts.
And just for the record I don't have a whole basement for my layout. I wish I had but that's not the case.
Danilo Jiménez
thanks 2 users liked this useful post by Hackcell
#36 Posted : 27 July 2015 08:41:18(UTC)
The question is whether Märklin should produce universal locomotives for two-rail and three-rail operation.
IMHO nobody wants Märklin to make only universal models. But since some models share more than 95% of parts between 2R and 3R, it would be just a small step to make some universal locos.
Compatibility with R1 is not the key question here. Universal locos could be limited to two-truck locos if steamers should make trouble with R1.
Märklin made several H0 models that are not fully compatible with R1 - and I think more such models will come in the future.
Off topic: I won't buy any more shortened coaches and I do not use R1 where passenger trains are meant to go.
Märklin made 303 mm coaches, but I don't think they will make more moulds for that length in the near future.
#37 Posted : 27 July 2015 08:54:21(UTC)
Likewise!
#38 Posted : 27 July 2015 09:19:17(UTC)
There is a potential benefit for Märklin. Well, higher profit for Märklin or lower prices for the customers. The benefit could be split between Märklin and the customers.
#39 Posted : 27 July 2015 09:55:03(UTC)
Tom(H0) has right.
Märklin should offer customer with bigger deal,by produce smarter locomotives like ESU.
Distance between wheel flanges are 14,0-14,2 mm which are standard both for three and two rail.
It´s normally today.
I have both Märklin and Trix same wheels and they show same distance,but they are isolated and non-isolated.
Offline mbarreto
#40 Posted : 27 July 2015 15:59:14(UTC)
mbarreto
You have been a member since:: 18/02/2008(UTC)
I voted for the multi-system locos. I don't see any problem for us (users/collectors/buyers) in a loco have more functionality.
At least it would be more practical.
I think the right way of having customers is by excellence of product and service, and in this perspective I don't think M* has anything to fear.
More than that, many model railroaders could easily test both systems and decide for which one to go. Maybe some 2-railers would find that it is much easier and trouble-free to setup a 3 rail layout than a 2 rail layout (specially for the less skilled ones).
And now let's think a little further, and go a little beyond what exists. M* (hope not others do it before...) could score if it moved to this. My suggestion is a multi-system loco that dynamically change from 3 to 2 rail operation and vice-versa. I think this is not patented yet, so M* can do it ))))))))))
Probably this would be of no widespread use, but it was something more advanced that could bring advantages in some situations. It would anyway have some benefits for those having both systems in the same layout that in the current days are running independently.
Miguel
Mostly Märklin H0.
#41 Posted : 27 July 2015 17:09:51(UTC)
ESU do have multi locomotives,but i´m not sure if they have patented this way.
Of course can Märklin decides by produce multi locomotives,but not the same way like ESU.
ESU do have micro switchable inside of the locomotives,when you pull off the pickup shoe,the micro switch make sure you convert to two rail at once.
So Märklin must solve in other way.
One good example is to use jumper in the PCB.
#42 Posted : 31 July 2015 08:52:31(UTC)
Three weeks left to vote!
I thought there should be more members to vote.
Perhaps it´s holiday for mostley of the members.
Offline mbarreto
#43 Posted : 31 July 2015 09:53:02(UTC)
mbarreto
Probably for most Märklin fans, 2-rails is not important and so multi-system locos are not important too.
Off course for Märklin a decision on that is important, but for now they think "No" as we can see. Or better, as we don't see any Märklin multi-system loco. Anyway it seems that Märklin newly designed locos are not difficult to convert from 2-rails to 3-rails. The opposite is more expensive if you need buy wheels, that is what happens in most of the cases. It makes some sense from Märklin's perspective...
Long ago I really decide for 3-rails and all other systems are part of the world's desirable diversity.
To finish this post I would like to say that there are much better aspects of the hobby that are worth to think than if it is 2 or 3 rails.
Miguel
Mostly Märklin H0.
#44 Posted : 09 August 2015 15:03:32(UTC)
Thirteen days left by vote.
I´m quiet disappointed when there has only 32 so far did voted. Sad
#45 Posted : 17 August 2015 09:27:15(UTC)
Five days left!
This poll question seems scaring Märklinist.
Only 37 voted... Blink
#46 Posted : 20 August 2015 09:28:17(UTC)
Two days left!
#47 Posted : 20 August 2015 12:02:31(UTC)
I do buy DC and AC locos but for a different reason, a.) HAG AC analog locos are to expensive to convert to digital so I buy DC locos and I do buy other DC locos just for the type of loco (E-loco) and run them from my overhead system.
Offline Nigel Packer
#48 Posted : 20 August 2015 17:04:12(UTC)
Nigel Packer
The universal locomotive for AC and DC, three-rail and two-rail, is a nice idea, but I haven't found it particularly reliable in practice with the ESU locos I have.
Here's a link to the ESU page where they promise a design fix for the Class 66/77 range of locos:
ESU Class 66/77 pick-up fix
I found that the recommended soldered solution could not be made to work, and I had to disable the switch feature inside the loco with super-glue. That did work!
But the promise from ESU for a proper solution has been on their web site for at least 18 months, and nothing has appeared.
And the V60 series from ESU is not quite universal, as some features are not supported on AC. My ESU V60 loco has very little traction, and can handle only two or three wagons, so I can't use it on my layout for the purpose for which I bought it.
As always when I've tried locos from other manufacturers, I end up deciding I'm better off with Märklin!
Nigel
thanks 4 users liked this useful post by Nigel Packer
#49 Posted : 21 August 2015 00:05:32(UTC)
Nigel
It´s an problem with theirs weak motor at the model V60.
#50 Posted : 21 August 2015 19:13:00(UTC)
Last day to vote!
2 Pages12>
This page was generated in 1.427 seconds.
