Offline rogerabbit
#1 Posted : 22 July 2015 14:51:18(UTC)
rogerabbit
Hello. I am new to this excellent site - so I hope you will forgive what you will probably consider to be a very simple query.
I have just purchased a Marklin BR 50 Heavy Goods Steam Engine. The model is Marklin 3684 - AC digital. I want to adapt the model to run on old-fashioned standard M track. I have researched and discovered that it is fitted with a 6080 decoder. There is a slider beneath the tender so I assume this will pick up from the centre studs once the decoder is removed. It seems from the plans I have found that I will need to de-solder several coloured wires to remove the decoder. Before I destroy my model can I ask for your advice !
1. Have I got this right - and will the model run on three rail AC once I have removed the decoder ?
2. Is there anything else I need to do to convert the model ?
I'm sure your wondering why on earth I bought an expensive digital model when a much cheaper second hand non-digital one would have served the purpose. Well, I acquired this loco in mint condition for a fantastic price ! And of course I can sell on the decoder once I have removed it.
I would really appreciate your advice.
#2 Posted : 22 July 2015 14:56:12(UTC)
Hi, Roger,
Welcome to the forum.
Originally Posted by: rogerabbit Go to Quoted Post
1. Have I got this right - and will the model run on three rail AC once I have removed the decoder?
It won't run unless you add a reverse unit. Well, without reverse unit you can run in a single direction only.
With the decoder left in place it can run on analogue tracks. Why remove the decoder?
With decoder, lights will not work in conventional operation. Beside that there is no need to remove the decoder.
Offline rogerabbit
#3 Posted : 22 July 2015 15:10:34(UTC)
rogerabbit
Hi, Roger,
Thank you so much, Tom. The model has not been delivered yet. When it does I will NOT remove the decoder! I had thought the decoder might bypass the conventional drive.
Is there any way that I can get the lights working ? Or is this tricky ?
Thanks again. Roger.
#4 Posted : 22 July 2015 15:37:11(UTC)
Is there any way that I can get the lights working?
Simple and cheap trick: bypass the decoder, connect the lights directly to the slider.
Or replace the decoder for a modern type - this is neither simple nor cheap. I wouldn't replace the decoder as long as you want to drive analogue.
Offline rogerabbit
#5 Posted : 22 July 2015 15:43:00(UTC)
rogerabbit
Thanks Tom. You are a star ! This I will do.
Very best. Roger.
#6 Posted : 24 July 2015 20:19:11(UTC)
Rather than wiring the lights directly to the slider, you may wish to consider upgrading the old 6080 decoder to a newer one which provides lighting in both digital and analog use. You could use either a 6090 or more recent decoder. Some upgrades may require adaptation of the magnet and other motor parts as well. There may be a kit from Maerklin that would fit your model and provide all of the parts, decoder in one kit.
Offline Renato
#7 Posted : 24 July 2015 22:48:02(UTC)
Renato
If I were you I should use the locomotive as it is without any modification (less cost and no trouble on changing the decoder).
Renato
Offline rogerabbit
#8 Posted : 17 August 2015 22:56:42(UTC)
rogerabbit
Many thanks to everyone who helped with this. Much appreciated. The loco arrived and of course everything was exactly as you indicated. Runs beautifully with no modification. I managed to connect the bulb to the slider pickup without soldering ! So it's easy to bring the loco back to its original condition if needed. Lights are working perfectly - but a very odd thing. Confused Perhaps someone can explain it.
When the bulb is lit it sheds light all over the place - underneath the loco, beneath the front lamps and through the funnel ! I can't think Marklin would intend this to happen. It leads me to suspect that something is missing - maybe a smoke unit which has been removed. Looks awful. Anyway, I think I can mask the light internally - inside the body- like I mask my Faller buildings!
What do you think ? And many, many thanks again. Roger.
This page was generated in 0.569 seconds.
