Offline Jvt1
#1 Posted : 18 July 2015 06:39:01(UTC)
Jvt1
I have a brand new CS2 updated to the latest software updates.
The Issue is my CS2 does not recognise the 2nd S88 connected. I have check all my cables and s88 modules and they are all working.
In my layout in cs2 all the 2nd s88 are yellow while the 1st are all white on the layout icons.
Appreciate anyone's assistance.
JVT
Edited by user 03 November 2015 06:38:42(UTC)  | Reason: Not specified
Offline siroljuk
#2 Posted : 18 July 2015 08:48:21(UTC)
siroljuk
If your first S88 works fine then try to find the order of those devices and then test again.
This is how you find if the second device is broken.
Remember that only the first device should have mass connection.
Of course check the cable between first and second.
Cross-check everything also carefully connector of the flat cable.
Jukka
Offline Jvt1
#3 Posted : 18 July 2015 09:04:16(UTC)
Jvt1
Jukka
G'day
I have cross checked everything, modules, cables and they all work. What do you mean 'find the order'? And what do you mean 'mass connection,?
My first s88 is connected to the CS2, and the second s88 is connected to the first s88.
JVT
Offline efel
#4 Posted : 18 July 2015 09:46:35(UTC)
efel
Is your CS2 configured for several s88?
Fred
Offline Jvt1
#5 Posted : 18 July 2015 10:31:16(UTC)
Jvt1
Fred
Hi Fred
How do I configure the CS2 so it know how many s88 I have connected?
JVT
Offline siroljuk
#6 Posted : 18 July 2015 11:47:03(UTC)
siroljuk
Hello, as far as I know there is no way to configure several S88. CS2 itself configures device automatically but . . .
Read this help information:
Fehlersuche
Wenn Sie S88 einsetzen, empfehlen wir dringend im Layout der CS2 eine Seite mit S88-Kontakten anzulegen. Ohne die Kontakte direkt in der CS2 anschauen zu können ist eine erfolgreiche Fehlersuche sehr schwierig wenn nicht sogar unmöglich. Schon bereits zur Inbetriebnahme der Rückmeldemodule sollte eine Seite angelegt werden, auf der alle verwendeten Rückmeldekontakte in Reih und Glied angeordnet sind. Beispielsweise 3 Reihen mit je 16 Kontakten wenn sie 3 S88 verwenden.Dies ist auch dann empfehlenswert wenn nur der PC Automatiksteuerungen durchführt. Zur Fehlersuche kann diese Seiteverwendet werden, um die Funktionsfähigkeit der S88 zu überprüfen
Wenn Sie Automatiksteuerungen mit dem memory einsetzen möchten, die auf Rückmeldekontakte reagieren, sollten sie auf jeden Fall eine Seite im Layout anlegen auf der die entsprechenden Fahrstrecken mit den Rückmeldekontakten angelegt sind. Sie sollten dann den Fahrablauf von Hand durchspielen und im Layout die Rückmeldekontakte genau beobachten. Insbesondere Kontaktgleise müssen so gründlich überprüft werden. Erst danach sollten sie beginnen die Fahrstraßen im memory zu programmieren oder einzuschalten.
•Sind die Kontakte frei wenn kein Zug da ist ?
•Werden die Kontakte belegt wenn ein Zug da ist ?
•Bleibt die Belegung beim kompletten Überfahren stabil ?
•Hat die Kontaktgabe die richtige Position ind Länge ?
All das lässt sich anhand einer Seite im Layout überprüfen.
Tranlation of Google is here:
Troubleshooting
If you are using S88, we strongly recommend that the layout of a page with CS2 S88 contacts create. Without being able to contact directly in the CS2 look is successful troubleshooting very difficult if not impossible. Already been to commission the feedback modules a page should be created, to which all feedback contacts used are arranged in rows. For example, 3 rows of 16 contacts when they 3 S88 verwenden.Dies is also recommended if only the PC performs automatic controls. For troubleshooting this site can be used to verify the functionality of the S88
If you want to use automatic controls with the memory that respond to feedback contacts, you should definitely invest in a page layout on the corresponding routes are created with the feedback contacts. You should then run through the driving sequence of hand and closely monitor the layout the feedback contacts. In particular, contact rails must be thoroughly checked. Only then you should start the routes in memory to program or turn.
• If the contacts are free if no train is there?
• If the contacts assigned when a train has arrived?
• If the complete assignment when crossing stable?
• If the contact is the correct position ind length?
All this may be checked one side in the layout.
Translation is not very good but it still might be worthy.
Huh
Jukka
thanks 1 user liked this useful post by siroljuk
Offline efel
#7 Posted : 18 July 2015 22:57:06(UTC)
efel
Originally Posted by: Jvt1 Go to Quoted Post
.. And what do you mean 'mass connection,?
The symbol: "T upside down" of the s88 should be connected to the lateral rails (=brown cable: ground).
Fred
Offline Jvt1
#8 Posted : 18 July 2015 23:28:53(UTC)
Jvt1
Fred
Hi Fred
I can confirm I have done thi
JVT
Offline Jvt1
#9 Posted : 02 November 2015 10:38:59(UTC)
Jvt1
Dear All
I have been working in remote location for sometime and only just got back to my layout,
This problem is still occurring.
Any further help would be appreciated
Thank you
Justin
#10 Posted : 02 November 2015 20:01:31(UTC)
Justin,
You do not indicate
- model number and software version of your CS2
- make and model number of your S88s and associated cables.
Please
- provide a photo(s) showing the S88s, including the cable connection between them
- specifically answer the question... "If you connect your 2nd S88 as the 1st S88 by itself , do the sensors 1-16 still work"
Offline Jvt1
#11 Posted : 02 November 2015 20:36:33(UTC)
Jvt1
Hi Peter
Well done on the World Cup victory.
Central station 60215
Hardware version 5.1
Software version 3.8.1(11)
Version 2.43 (information tab)
S88
Viessmann 5217 and so are the cables.
I cannot get in position well enough for a photoCrying
If I connect the 2nd s88 as the first it works. I have do this to check all the s88 I have.
Justin
Offline fkowal
#12 Posted : 03 November 2015 02:52:12(UTC)
fkowal
Hi Justin:
Based on what you are describing we assume you are connecting the S88 directly to the CS2 via the ribbon cable connection on the bottom of the controller. As you mention the exchange of the two Viessmann S88 units have provided the same positive result, both S88's are ok. This yields only 3 remaining options as a source of the problem. 1) the second Viessmann unit needs its own ground connection (brown ground to upside down "T" (this is a guess as I only have Marklin S88's) 2) the ribbon cable between the two S88's is twisted and therefore not connected correctly or 3) the S88 cable between the two S88's is defective.
Based on what you describe, I believe option 3 is the most likely. Do you have another S88 ribbon cable to connect between the two S88's to try to see if it works? if not, try exchanging the cable between the CS2 and the first S88. If the first S88 no longer works, then we know the cable is the culprit.
As an aside, I hope you have made a series of test S88 nodules on the CS2 Layout page with the numbers 17 thru 32 to test the second S88.
Offline PMPeter
#13 Posted : 03 November 2015 04:26:48(UTC)
PMPeter
Make sure that the cable from the 2nd unit is connected to the correct location and orientation. If by accident you connect it to the incoming side instead of the outgoing side, all of the sensor indications on the 2nd unit will show yellow.
I had exactly the same situation today when I added a third party S88 module in between LDT and Marklin S88 modules. The CAT5 patch cable caused all subsequent S88 modules to show yellow. Once I switched to an LDT cable with the normal pin connectors all worked fine.
Good luck.
Offline Jvt1
#14 Posted : 03 November 2015 06:42:35(UTC)
Jvt1
Dear All
Thank you for your help.
I set up a separate test and borrowed a friends S88.
For some reason one of my S88 works in the 1st position but not 2nd.
Once I used the other s88 the second s88 worked.
I need to purchase a new s88
Justin
CS2 S88 problem (Digital)
by Peter Claesson 05/02/2019 22:00:21(UTC)
Traincontroller Silver 7 and CS2 s88 feedback (Model railroad software)
by craigericks 26/11/2015 18:48:30(UTC)
CS2 s88 Interval Query default (Digital)
by et1 23/10/2012 22:00:49(UTC)
This page was generated in 0.826 seconds.
