Offline vtdochop
#1 Posted : 17 July 2015 02:44:01(UTC)
vtdochop
Hello all,
Just wanted some assistance in updating my CS2. Software 1.4 o(1), HW4.33 Serial # 27283. I have attempted to update over the internet but get the notice that the update was NOT successful. I acquired this CS2 from Germany 2 yrs ago and have not been active in the hobby until recently. Try as I might I have been unsuccessful in achieving up date.
Any suggestions would be appreciated. Confused
Sincerely,
#2 Posted : 17 July 2015 08:01:29(UTC)
Hi, Peter!
Use an USB stick to install the update.
Try online updates again when your CS2 is at 3.x.x - if it still fails there will be a configuration problem.
Hint: if your CS2 shows pink dials after the USB update then simply start the update again - it must be started at least twice.
Wait at least 30 minutes before you assume the CS2 got hung during update.
Go to
http://maerklin.de/de/pr...ds/software_updates.html
Check "Ich habe die Lizenzvereinbarung gelesen und bin damit einverstanden" at the bottom of the page.
Read instructions under "4) USB-Stick Update für die CS2" with Google translate.
#3 Posted : 17 July 2015 09:11:33(UTC)
To get online updates, the CS2 must be connected to a router.
Potential problems and IP configuration have been discussed here:
https://www.marklin-user...-icons-in-CS2#post490676
Offline vtdochop
#4 Posted : 20 July 2015 17:24:15(UTC)
vtdochop
Tom.
Thank you for your excellent instructions...I am now up to 3.7.0 ! I presume I can now update from the internet directly...correct ?
#5 Posted : 20 July 2015 17:56:30(UTC)
Try it. There could be a problem with the IP configuration.
With DHCP there shouldn't be any problems (see the IP tab in the CS2 setup).
Offline vtdochop
#6 Posted : 20 July 2015 18:08:58(UTC)
vtdochop
Tom,
I attempted to do the internet update but got the following message on the CS2...Could not retrieve update information
Any ideas ?
#7 Posted : 20 July 2015 18:20:17(UTC)
Peter,
Which IP address does your CS2 use? Can you see the CS2 in your Internet browser?
See also:
Offline vtdochop
#8 Posted : 20 July 2015 22:51:02(UTC)
vtdochop
Tom,
Tried again and all is good. BigGrin
Edited by user 21 July 2015 02:23:18(UTC)  | Reason: Not specified
This page was generated in 0.511 seconds.
