Offline Mary Kumar
#1 Posted : 29 June 2015 07:02:40(UTC)
Mary Kumar
Hello
Over 10 years ago, whilst living in Germany, I purchased the 29859 starter kit. This comes with the 6021 control unit. I also purchased the following signals: 7036, 7241 and 7242. And I have a 7272 control box. Over the years we have added additional sets and also have a CS1.
Now that the grandkids are older, my husband and I have decided to create a semi permanent layout.
We followed the instructions that come with the 7241 signal. But have not been able to use the signal to stop the train. In reading through this forum, it appears that we may need the K 83 decoder. Also read that this has been replaced with 6084 and 6088.
Am I missing the decoder ? Is there a wiring diagram for this ? Apologies if this is a duplicate question. I searched through the forum and found lots of great links and advice which helped hubby and I to solve some of the other issues.
Thanks in advance.
thanks 1 user liked this useful post by Mary Kumar
#2 Posted : 29 June 2015 07:53:24(UTC)
Hi, Mary,
Welcome to the forum.
It appears you didn't follow the wiring instructions, otherwise the trains would stop without a decoder. Wink
To install the signal with C track, you need an insulated section where the signal controls the power to the centre rail.
These are the 74030 insulators for C track:
http://archiv.maerklin.d...=&wishednumber=74029
Did you install such red insulators before and after the signal?
There even is a 74043 set for signal installation:
You do not need a k83 decoder (aka 6083, 60830, 60831), but can use one to control the signal from the CS1. And decoders 6084, 60840, 60841 are k84 decoders that serve a different purpose. And 6088 are yet another type. Confused
Start simple - signal should work without a decoder.
Offline Mary Kumar
#3 Posted : 29 June 2015 08:34:35(UTC)
Mary Kumar
Hi HO,
Thanks for the reply. The insulators are installed before and after the signal. My wiring is the first graphic in the instruction leaflet that came with the signal. Here is what I have done:
One Red wire before the insulated section to the signal
Red and Brown from the insulated section to the signal
Blue and Yellow wires from the signal are not connected anywhere
Signal is on the base plate
Used 6021 control unit
No light comes on on the signal.
Mary.
By the way, how do I attach diagrams or pictures to a post ?
#4 Posted : 29 June 2015 09:14:01(UTC)
Because the yellow wire is not connected.
Blue wires should go to a control box.
By the way, how do I attach diagrams or pictures to a post?
Use the clipper symbol from the toolbar that shows on the "Post a reply" screen.
See also:
https://www.marklin-user...-Attach--image-to-a-post
Offline Renato
#5 Posted : 29 June 2015 17:22:04(UTC)
Renato
Hi Mary,
Renato
Offline Mary Kumar
#6 Posted : 30 June 2015 00:43:56(UTC)
Mary Kumar
No luck getting the light to work. Pretty sure that I am missing some connection. I will take a picture later this evening when I get home and post it.
Offline Mary Kumar
#7 Posted : 30 June 2015 17:24:00(UTC)
Mary Kumar
Update: Hubby took apart the 7241. Found a couple of open circuits. Fixing and checking. He thinks it should work when he puts it back together.
Offline Mary Kumar
#8 Posted : 01 July 2015 17:34:47(UTC)
Mary Kumar
7421 signal is working. As usual, learnt a lot from resolving this issue. Thanks for the help on what to look for.
This page was generated in 0.451 seconds.
