Offline billhubb
#1 Posted : 28 April 2015 02:43:01(UTC)
billhubb
I was wandering if anyone has installed interior and marker lights into the 43597 bi-level car set. There is no mention in the catalog and there were no instructions in my set, it doesn't look like a standard slider will work, I may have to do a custom job but I thought I would check for a plug and play set first.
Bill
Offline Shamu
#2 Posted : 28 April 2015 07:30:25(UTC)
Shamu
I'm fairly sure there is a Marklin lighting kit for them, in fact I may have a couple I picked up in a bulk deal last year.
I'll see if I can find them and post the item #.
Offline Tom Jessop
#3 Posted : 28 April 2015 07:42:09(UTC)
Tom Jessop
Gee how many bulk deals have you wrangled in the last year ?& better still where did you get notice of them from ?
Tom in Oz
#4 Posted : 28 April 2015 07:47:12(UTC)
Hi, Bill,
I have the Trix version of those coaches - and they are prepared for interior lights. Only problem could be the centre rail slider, as you guessed.
Offline Shamu
#5 Posted : 28 April 2015 07:55:44(UTC)
Shamu
Ok Bill,
Its the 73140 lighting set.
Includes the double bank of lights (globes NOT leds)
2 x current conducting couplers
1 x offset pickup shoe
2 x "A" frame thingy's for the coupler power
1 x current pickup for the wheels
and the extension whatsie to bring the power feed up from the wheel pickup
Tom,
These particular bits came from Nev W's clear out end of last year.
Shamu attached the following image(s):
#6 Posted : 28 April 2015 09:45:21(UTC)
That could be a problem: the trucks do not have an offset pivot point and the offset slider may lead to problems (if it fits at all).
The set 73140 is for the 264 mm double stock coaches, the question is about the 303 mm double stock coaches. Did anyone install lights into the 303 mm coaches?
This page was generated in 0.386 seconds.
