Offline morsing
#1 Posted : 25 April 2015 13:24:49(UTC)
morsing
I installed RocRail, and can start it up fine. It listens on port 8051, so far so good. Documention on this is really, really poor, so it took me a while to figure out you had to run RocView to connect to it...
Anyway, running rocview.sh I just get this:
./rocview.sh: 32: ./rocview.sh: /opt/rocrail/rocview: not found
I don't have any rocview binaries after the installation of the .deb:
root@albert:/opt/rocrail# locate rocview
/opt/rocrail/rocview.sh
What do I do now?
Marklin C-track + CS3+
Offline French_Fabrice
#2 Posted : 25 April 2015 13:42:14(UTC)
French_Fabrice
The script rocview.sh makes in your home directory a sub directory call rocrail and finalizes the installation.
It seems you are missing some icons in the graphic menu. Does /opt/rocrail/rocview.sh has execute permission set ?
The icon starting rocview should run : "/opt/rocrail/rocview.sh %f"; see at the bottom of the script the run command (must be run from your account, not root).
I'm using a version I've compiled myself on openSUSE 13.1; never used either .deb or .rpm
Last advice: for this kind of very technical issue, post a request on rocrail forum, answers will be more accurate.
Fabrice
Offline morsing
#3 Posted : 25 April 2015 13:58:05(UTC)
morsing
Fabrice
I tried to register on the RocRail forum, but it requires admin approval, so posted here instead.
What is %f meant to expand to? Icon or not, it just runs rocview.sh, which tries to call rocview which doesn't exist. Even if I run it as my own user, it is not going to make it appear...
#4 Posted : 25 April 2015 14:14:27(UTC)
French_Fabrice
If the rocview binary is missing, then you will not go further Sad
%f is the 3rd argument passed to the command line, I don't know what it means exactly...
Seems your installation is incomplete; try to reload an older version and reinstall. An alternative is to build from sources...
Good luck
Fabrice
Offline morsing
#5 Posted : 25 April 2015 14:16:41(UTC)
morsing
rocview isn't even in the .deb:
root@albert:/home/morsing/rocrail# dpkg-deb -c rocrail-server-8736-debian6-i386.deb | grep view
-rwxr-xr-x root/root 608 2015-03-15 10:10 ./opt/rocrail/rocview.sh
When I get a moment I will get the source and comile it. With a bit of luck I can just drop it in to the existing directory.
Thanks for your help
#6 Posted : 25 April 2015 14:22:59(UTC)
French_Fabrice
You have loaded only the server (i.e. rocrail) !!! All the client part (rocview) is missing !
Try to load the full install with both parts if it is available for your configuration, or build from sources.
See there: http://wiki.rocrail.net/...php?id=develop-corner-en for building
Fabrice
Offline morsing
#7 Posted : 25 April 2015 15:03:51(UTC)
morsing
Ah cool!!! Thanks for that :-D
Offline morsing
#8 Posted : 25 April 2015 18:35:18(UTC)
morsing
So, all works now thanks. Can I just ask if there are cheaper alternatives to connecting this to your track than buying a £500 Central Station? I have seen something called Arduinio modules costing about £20, do they do the same thing, or am I completely wrong?
#9 Posted : 25 April 2015 19:38:47(UTC)
French_Fabrice
I don't have any expertise with Arduino chips. I know there is a project about building a Command station based on Arduino chips (see Yaasan thread : https://www.marklin-user...station--Railuino.aspx).
Other members may have more accurate answers.
Fabrice
#10 Posted : 25 April 2015 21:01:42(UTC)
You only need a booster if you try DDX. A cheap booster could be Märklin 6604 or 66045.
If you do not need a colour touch screen, maybe try an Intellibox or a Tams Easy Control instead of DDX.
Offline trainbuff
#11 Posted : 18 June 2015 15:22:14(UTC)
trainbuff
Hello Morsing,
If I understand your question, instead of a central station there is also the CAN Digital Bahn Project that works with RocRail. I use it (CCSchnitte) with RocRail and MS2. I think it could be used without an MS2, just the 60113 connector box.
Good luck
Offline bertc3p0
#12 Posted : 04 September 2015 18:14:23(UTC)
bertc3p0
If you own a Maerklin 60112/60113 (aka Gleisbox) you only need a CAN interface to control your locos. CAN Interfaces are normally expensive, but with a BeagleBone Black/Green or BananaPi you'll get an CAN interface (you only need to wire a CAN tranceiver).
BTW: with can2lan you can also use M*rklins Software (PC&App). In fact, the software aims to be a CS2 without a screen :-). And, your are not limited to M*rklins Software - Rocrail (and others) are also possible to use.
Gerd
PS: I will show a cheap and easy to build CAN2USB in the next days.
This page was generated in 0.579 seconds.
