Offline Cargodog
#1 Posted : 21 March 2015 22:35:29(UTC)
Cargodog
Hi again,
This time it's all about the ESU switch pilot.
I have an ECOS II, and understand I can control my switches from it if I use the switchpilot.
I need to control around 55 M track switches (Regular switches, slip switches, 3 way turn out). I've pretty much settled on the Switchpilot V2.0. However, there's also the Switchpilot extension. For some reason this seems to only be available in a V1.0?
Have I understood it properly when I say that 1 Switchpilot extension needs a Switchpilot to work? Ie, if each Switchpilot/Switchpilot extension can control 4 switches, I'd need 14 units. This means I could use 7 Switchpilots and 7 Switchpilot extensions. Is that correct?
I don't think the info on the ESU website is very good. I read on their website that the Switchpilot can control the motorized turnouts. The M track switches are not motorized. Surely there's no need to motorized them in order to use the Switchpilot?
It's quite an investment I'm about to make (not just in this area), so I'd like to know that I've got it right.
Thanks in advance,
Rene...
If everything's under control, you're just not going fast enough.
There are two types of men. Those who want to build a big layout, and those who didn't get permission from the wife.
thanks 1 user liked this useful post by Cargodog
#2 Posted : 21 March 2015 22:56:43(UTC)
Hi, Rene!
No. A SwitchPilot is like a Märklin k83. With extension it's like a k84.
So you would need 14 Switchpilots without any extensions. Or k83-type decoders from Märklin, Viessmann, Roco or other makers.
You do not need tortoise motors, but the turnouts must have solenoids (for operation with control panels).
Offline Cargodog
#3 Posted : 21 March 2015 23:48:02(UTC)
Cargodog
Hi, Rene!
Thanks for info (again), Tom,
I wasn't aware that I needed to modify my switches. Would you happen to know how much these solenoid cost, and a good place to purchase them online? It doesn't really matter of it's in the states or Europe, as I'll need it to be shipped to the Middle East anyway.
A quick search on eBay revealed a price of around 18 $ for one. That sounds very expensive. That would mean over 1000 $ just for solenoids. If that's the case, I guess I'll have to start out by powering my switches for analog operation. :-(
#4 Posted : 22 March 2015 07:39:33(UTC)
M track is not my area of expertise.
I assume that turnouts with lanterns always have the solenoid. Some - from starter sets - even came with a factory-installed decoder.
Turnouts with a lever do not have the solenoid ex works. And AFAIK the solenoid was not sold separately, so replacing the turnouts might be the best solution.
If your turnouts have lanterns then they probably have the solenoids and you will only need decoders.
If they have levers then they cannot even be operated remotely using control boxes. Conversion should be possible, maybe even using tortoise motors, but that is beyond my scope.
Offline Cargodog
#5 Posted : 22 March 2015 07:59:33(UTC)
Cargodog
Yeah, I just did a bit more research, and you have just confirmed my findings. Indeed, it makes sense that you can't just use a decoder for a manual turnout. However, all my turnouts are the electrical turnouts with 1 yellow and 2 blue cables. Hence it should work with just the Switchpilot and no other accessory needed.
Thanks, Tom.
Separate trafo for digital switches (Digital)
by robertrt 28/02/2006 01:48:28(UTC)
This page was generated in 0.393 seconds.
