Offline Carlos
#1 Posted : 18 March 2015 18:36:31(UTC)
Carlos
How can I install the s88 Viessmann 5217 with the c track 24994 and the Central Station 60215?
Offline PMPeter
#2 Posted : 18 March 2015 19:59:49(UTC)
PMPeter
The wire from the 24994 goes to one of the 16 sensor input terminals on the 5217. Assuming you have 2 wires from the 24994 this then goes to two of the 16 sensor input terminals.
You then connect the special S88 cable from the Output terminal of the 5217 to the underside S88 receptacle on the CS2.
If this is your first S88 type module you will also need to run a ground (common brown) wire to the appropriate reference terminal of the 5217 (Usually an upside down T) but check the 5217 instruction since I do not have a 5217 handy.
Offline Carlos
#3 Posted : 19 March 2015 18:52:24(UTC)
Carlos
Hi Petert, I forgot to say that is to be connected to the signal Marklin 76391. Is this the correct way.
Thanks, regards,
Carlos.
My English is not very good.
Offline PMPeter
#4 Posted : 19 March 2015 19:39:39(UTC)
PMPeter
Hi Carlos,
The Viessmann 5217 is an S88 type feedback module that lets the CS2 know if a sensor has been activated by a locomotive/car/train. The CS2 can the be programmed in the Memory in order to activate the signal. The signal wiring does not got to the Viessmann 5217 module. It must be connected to and controlled by its own decoders.
#5 Posted : 19 March 2015 19:52:59(UTC)
You can use a Viessman 5211 decoder to operate your signals and turnouts.
Offline PMPeter
#6 Posted : 19 March 2015 20:11:49(UTC)
PMPeter
A Marklin K83 can also be used.
Offline Carlos
#7 Posted : 20 March 2015 17:38:40(UTC)
Carlos
Hi Carlos,
Hi Peter, Thank you again
Regards, Carlos
Offline Carlos
#8 Posted : 20 March 2015 17:42:25(UTC)
Carlos
Hi David :
What's the difference between the 5211 and 5217?
Thank you, Regards,
Carlos
#9 Posted : 20 March 2015 21:12:18(UTC)
The 5217 is a feedback decoder, the 5211 is a K83 solenoid decoder designed to switch turnouts, signals and other devices on a layout. They are not interchangeable.
Offline Carlos
#10 Posted : 20 March 2015 23:12:48(UTC)
Carlos
Thank You David, regards,
Carlos
This page was generated in 0.562 seconds.
