Offline Ken Mitchell
#1 Posted : 24 February 2015 10:43:58(UTC)
Ken Mitchell
Hi folks, i am finishing of a N scale layout, practice run, for our loungeroom which is 75 cm (2' 6") high, perfect for my eye level from my arm chair whilst drinking the morning coffee and 2 1/2 year old grandson to stand and watch the running trains.
Currently planning a m track vintage layout, pre 70's, with 3 x 5 m area available and looking at a T shaped baseboard, so i can reach all areas of the layout without too much difficulty. I have recently read that the recommended baseboard height is 42" minimum, 48" recommended. Not sure that will work with my grandchildren not 4' high yet. I am planning about 90 to 100 cm.
What are the forum's thoughts?
Ken from Berry, NSW
Offline Tom Jessop
#2 Posted : 24 February 2015 11:12:13(UTC)
Tom Jessop
I have my base level at 900 mm , another storage area at 400mm & possibly a branch line at about 1200mm above floor level .
Cheers Tom in Oz
Offline MalinAC
#3 Posted : 24 February 2015 12:27:04(UTC)
MalinAC
Ireland
I dont think there can be a set height because people are all different heights. Some say it should be at eye level as it gives a more realistic view. Others like to look down at the trains. Then if you have to build to suit childern its different again. Also if there are more than one level which level gets the best viewing position. Are you going to sit or stand when viewing etc.The best thing is to build to the height you are comfortable with. Take care and happy building. Eddie BigGrin BigGrin BigGrin
#4 Posted : 24 February 2015 12:50:29(UTC)
I agree with Eddie.
The ideal height depends on what is important for you. A layout set at 48 inches is unlikely to be right if you use a wheelchair or prefer watching your trains while sitting. On the other hand if your layout is too low it becomes impossible to work on the wiring underneath.
I chose a height which is just enough to clear my head when I'm stting on the floor under it. It worked out to be about 80cm, which meant I could use standard tall table legs from my local DIY store. The height was good enough for my then 8 year old son to see over, and comfortable for viewing from a chair.
#5 Posted : 24 February 2015 15:13:18(UTC)
Ken Mitchell
Cheers Tom in Oz
Thankyou Tom, my 900 to 1000 mm is about right. My wife thinks it should be lower so she can get to the back for scenary work. The layout is a joint effort. Regards Ken.
#6 Posted : 24 February 2015 15:15:16(UTC)
Ken Mitchell
Thankyou Eddie, sound points for consideration. Regards Ken.
#7 Posted : 24 February 2015 15:18:16(UTC)
Ken Mitchell
I agree with Eddie.
Hello Ray, thankyou for your thoughts. 80 cm, this is what my wife is suggesting. I am a watcher, prefer to sit and watch the engines running around whilst coffee in hand. Regards Ken
thanks 2 users liked this useful post by Ken Mitchell
#8 Posted : 24 February 2015 22:29:27(UTC)
When Miss 15 was Miss 4, we built the layout 600mm off the floor so that she could reach over and play with the cars and crane on the layout.. 600mm also made it easy to lie under the table to do the wiring etc.. There are a couple of old posts about layout heights and children.
https://www.marklin-users.net/forum/yaf_postst1766_xxup---Layout-Pictures---XXUP-and-Miss-5.aspx
https://www.marklin-users.net/forum/yaf_postst1732_Layout-and-children.aspx
#9 Posted : 25 February 2015 14:26:05(UTC)
Ken Mitchell
Hello Adrian,
Thankyou for your thoughts and the links, wonderful pictures. i am slowly increasing access to my n scale layout for mr 2 1/2, a head strong young lad now living with us with mum, dad and miss soon to be 1. Our daughter has moved back, with family in tow for a while, into our home about 6 weeks ago. i have a cheap bachmann oval on a movable base board with thomas and friends as a introduction to the trains. Has been enjoyable.
The new layout for my marklin HO has about 4 m x 2 m to play with, thinking it will need to be on wheels so i can get around it for building and ongoing maintenance.
Anyway, appreciate your comments re heights and will take then on board, no pun... Intended. Regards Ken
This page was generated in 0.486 seconds.
