Offline Dreadnought
#1 Posted : 14 December 2014 01:03:54(UTC)
Dreadnought
I am trying to make a "Y" with C track. It is proving frustrating. I cannot get the "tail" of the Y at 90 degrees to the through track. it always ends up a few degrees off.
I think someone on the forum in the not too distant past posted a diagram and listed the needed pieces. I would be grateful for any help.
On a brighter note my M track oval is set up around the Christmas tree. (It would not be a Christmas tree without a train!!)
My old RE 4/4 3014 is making a lovely noise pulling two 4014 cars and a 4035 red restaurant car.
Offline tulit
#2 Posted : 14 December 2014 01:34:42(UTC)
tulit
See the post from elukka
https://www.marklin-user...ack--wye.aspx#post280022
2 | Märklin C-Track 24077 Straight 77.5mm
2 | Märklin C-Track 24130 Curved R1=360mm 30°
3 | Märklin C-Track 24206 Curved R2=437.5mm 5.7°
2 | Märklin C-Track 24236 Straight 236.0mm
1 | Märklin C-Track 24430 Curved R4=579.3mm 30°
2 | Märklin C-Track 24611 Left Turnout 188.3mm R2=437.5mm 24.3°
1 | Märklin C-Track 24612 Right Turnout 188.3mm R2=437.5mm 24.3°
The image doesn't show up in the thread but if you google image search it does.
#3 Posted : 14 December 2014 08:07:36(UTC)
Hi Dreadnought,
This is the wye usually used. It is not symmetrical but works.
This one is symmetrical off a straight section, but uses a 3 way turnout. I have not tried this configuration.
Offline Dreadnought
#4 Posted : 20 December 2014 04:05:27(UTC)
Dreadnought
Thank you Kimball,
The need to be at 90 degrees to the cross track, and space limitations mean I shall likely go with the three way switch. It will look odd with the stump end. Perhaps I can make a short siding and park something small.
If I make it into the dealer tomorrow it will make his Christmas, and pay for his week in the sun.
I appreciate your detailed diagram.
D
#5 Posted : 20 December 2014 15:06:51(UTC)
Recently forum member Tom (aka "HO") posted a compact "90º solution wye" with three regular turnouts. I just cannot detect it right now. Maybe you could contact him via PM.
Offline Dreadnought
#6 Posted : 21 December 2014 23:49:21(UTC)
Dreadnought
Thank you AK,
By the time I saw your post I had driven the 100 plus KM to my dealer and back. I had him assemble a three way switch with motors, and a digital decoder. I was anxious to try it. Luckily I had him test it before leaving the store.
Two hours later he could not get it to work. It seems the new style de coders use DC rather than AC. As a result I would have had to get a DC transformer to run it. No thanks, so it will be run by the push button control box. I am surprised Marklin would make a decoder that requires DC power. I have to say the instructions were not very clear in either French or English.
In any event I spent a small fortune getting the necessary bits and pieces. My dealer's Caribbean family holiday is assured
thanks 2 users liked this useful post by Dreadnought
#7 Posted : 11 January 2015 00:41:13(UTC)
Found an example for a compact 90º wye in the German Stummiforum - see image.
Source:
http-//www.stummiforum.de/viewtopic.php?f=15&t=46016&start=75
This page was generated in 0.343 seconds.
