Offline steen damsgaard
#1 Posted : 02 December 2014 21:21:44(UTC)
steen damsgaard
Hello
Please advice where to find a wiring diagram for the E6302 analog or AC engine.
Normaly the lamps are connected directly to the ac power. This thou is diffferent due to separate front and back lamps. Is it correct that the power for light front or back is taken from the reverse switch. As a result, the voltage on the lamps is only a few volts. Is this engine may be using lamps for a lower voltage ? Please help.
Thanks in advance
Steen
Frederikssund
Offline Markus Schild
#2 Posted : 03 December 2014 00:31:24(UTC)
Markus Schild
Hi Steen,
Yes, the wiring is correct for the earlier years and yes, the lights are not as bright as they could be when connected directly to the rails.
Unfortunately you can't change the bulbs to a type of lower voltage, these would not stand the voltage of the switching - pulse.
Markus
#3 Posted : 03 December 2014 22:02:55(UTC)
steen damsgaard
Hello Markus
Thank you for your reply. Nice information for me.
All the best
Steen
parts for marklin E6302/CEB800 (H0-scale)
by lrk 04/03/2020 03:46:51(UTC)
E6302 lok (Collector's Corner general)
by steen damsgaard 02/04/2014 22:45:38(UTC)
Question concerning lightbulb replacement - 1953-7 Marklin HO Scale CE 800 Swiss Elec Engine E6302 (General MRR)
by Chris6382chris 20/08/2011 02:54:07(UTC)
E6302 (Collector's Corner general)
by foumaro 25/09/2007 12:14:58(UTC)
This page was generated in 0.316 seconds.
