Offline Tom Jessop
#1 Posted : 14 August 2014 11:54:55(UTC)
Tom Jessop
I have recently purchased some 2nd hand K track which has a quantity of M2271 points along with some M2273 points . The only difference I can see is some have a mechanical frog whereas others have a solid frog. The 2273 box's have a sticker placed over the original printed # of 2271 ,but the contents still have the same 2271 imprinted on the sleepers or ties . Possibly there has been the wrong left & right handed points put in to the wrong box but I have not come across any stamped 2273 yet .
Is there any obvious differences between 2271 & 2273 points ?
Thanks in advance ,
Tom in Oz.
Offline French_Fabrice
#2 Posted : 14 August 2014 15:17:34(UTC)
French_Fabrice
Hi Tom,
In the past (more than 20 years ago), the 2271 was a boxed set composed of a 2271 Left turnout and a 2271 Right turnout.
Then, for various marketing reasons I suppose, Left and Right turnouts were available separately, but without changing the box and adding a sticker over the "old" reference (2271). The marking on the turnout has always been "2271" for L or R turnout.
So 2272 = 2271 Left, 2273 = 2271 Right;
New references today are 22715 (L) and 22716 (R) and are sold one piece by one piece. These new turnouts have no mobile heart, as the old ones had.
Fabrice
thanks 2 users liked this useful post by French_Fabrice
Offline Tom Jessop
#3 Posted : 14 August 2014 23:28:59(UTC)
Tom Jessop
When was the change from a moveable frog to a fixed one ? Or is the other way round ?
Cheers Tom in oz
#4 Posted : 15 August 2014 00:20:54(UTC)
French_Fabrice
22715 and 22716 appear in the 2000/2001 catalog.
Old 2272 and 2273 were removed 2 or 3 years after.
Fabrice
Offline scraigen
#5 Posted : 07 February 2016 11:00:21(UTC)
scraigen
Hi Does anyone have experience ballasting the 2271 turnouts with the moveable frog? I was looking at them yesterday and it seemed to me that the moving pieces extend over a large area of the switch and therefore a lot of areas to avoid when ballasting.
Stu
Must build something
#6 Posted : 07 February 2016 15:42:14(UTC)
Stu
The best trick here is to leave a cavity under the turnout for any loose ballast to fall into so it doesn't jam the plastic piece that moves the tongue in the frog. If the cavity can have a hole right through the base board that will be even better because then it gets rid of the loose bits completely.
Also by having the cavity the moving piece won't jam on the base board.
This page was generated in 0.288 seconds.
