Offline thanethm11
#1 Posted : 05 March 2013 12:25:06(UTC)
thanethm11
Dear my friend.
I just boughh it in last week ang need to run it in my layout with mobile station1.
Please help me to choose moter conversion set & decorder.
60944?+ 60760?
Anyway, lamp will be changed to LED .
ThanethM
#2 Posted : 05 March 2013 13:13:11(UTC)
I converted mine with a 60944 motor kit and a 60942 MLD decoder. You can probably use the decoder from the 60760 kit, but I chose the MLD to give me MFX auto-registration. It's also a better decoder performance-wise.
I kept the original bulbs, and re-used the wiring that runs through the train for the white and red lamps at each end. However I had to do without the ability to change sliders from one end to the other, so as to simplify the conversion.
#3 Posted : 05 March 2013 17:29:30(UTC)
I did a full rebuild, with additional wires through the train, and relays to control the interior light and rear lights.
In addition a bi-stable relay to switch between the two pick-up shoes.
This was doen a long time ago, with the conversion set 60904. Today that means motor set 60944 and decoder 60942, as stated by Ray.
If I should do this today (and maybe a future improvement) I would use an mfx sound decoder, as I did in the set 37500.
For further detail, see my website.
Offline thanethm11
#4 Posted : 06 March 2013 02:51:37(UTC)
thanethm11
I will order motor conversion set-decorder form Germany as soon.
Thank a lot
Offline thanethm11
#5 Posted : 07 March 2013 03:35:42(UTC)
thanethm11
Dear Sir.
Yesterday, i trial to use deltra decorder 66031 to run this car with orginal lamp as temporary
After connect yellow,gray wire to front-rear lamp that are conected to locomotive frame.
When .No running as stop locomotive
lamps : OK can be operated
But after running locomotive
I found that yellow,gray function are broken / zero volt==>fail
But other functions as motor ,aux were still OK
Please recommend me
Thank
thanethm11 attached the following image(s):
This page was generated in 0.391 seconds.
