Offline Lollo
#1 Posted : 26 January 2013 08:47:24(UTC)
Lollo
Here are some Marklin magazine articles on coupler conversion, & other usefull info.
Brian.
File Attachment(s):
Kurz_gekuppelt_01.pdf (1,178kb) downloaded 495 time(s).
Kurz_gekuppelt_02.pdf (1,101kb) downloaded 343 time(s).
Kurz_gekuppelt_03.pdf (1,377kb) downloaded 229 time(s).
Kurz_gekuppelt_04.pdf (1,308kb) downloaded 180 time(s).
Kurz_gekuppelt_05.pdf (677kb) downloaded 182 time(s).
Kurz_gekuppelt_06.pdf (827kb) downloaded 164 time(s).
Kurz_gekuppelt_07.pdf (1,147kb) downloaded 182 time(s).
Kurz_gekuppelt_08.pdf (842kb) downloaded 171 time(s).
Kurz_gekuppelt_09.pdf (740kb) downloaded 162 time(s).
Kurz_gekuppelt_10.pdf (517kb) downloaded 169 time(s).
Kurz_gekuppelt_11.pdf (784kb) downloaded 149 time(s).
Kurz_gekuppelt_12.pdf (591kb) downloaded 153 time(s).
Kurz_gekuppelt_13.pdf (710kb) downloaded 152 time(s).
Kurz_gekuppelt_14.pdf (739kb) downloaded 152 time(s).
Kurz_gekuppelt_15.pdf (726kb) downloaded 159 time(s).
Kurz_gekuppelt_16.pdf (538kb) downloaded 156 time(s).
Kurz_gekuppelt_17.pdf (845kb) downloaded 162 time(s).
Kurz_gekuppelt_18.pdf (1,021kb) downloaded 216 time(s).
Brian
Yaasan's Desktop Station/Railuino & Marklin MS2, DB Era III/IV Diesel & Steam, ESU Loksound/Lokpilot & Lokprogrammer, Marklin mSD, Tam Valley Depot Octopus III Servo Controller.
thanks 9 users liked this useful post by Lollo
#2 Posted : 26 January 2013 08:56:50(UTC)
All 18 parts of that series are available here:
http://www.maerklin.de/m...n_specials_downloads.php
The first of Brian's links is now dead as is H0's link above, so I have reposted a copy of File no 1 in post #14 /BDNZ 18082023
Edited by moderator 17 August 2023 22:14:12(UTC)  | Reason: Not specified
thanks 8 users liked this useful post by H0
Offline Jackson
#3 Posted : 25 February 2013 00:52:37(UTC)
Jackson
Brian,
I have a coupling issue with the Rhinegold Cars. They have a "slip in" type coupler in order to provide power to the lights in the cars. The first car has a normal Marklin coupler in order to connect to the locomotive. They are always uncoupling. Any suggestions? If you have a pdf link, which one should I look for?
Wayne
Offline franciscohg
#4 Posted : 25 February 2013 02:17:20(UTC)
franciscohg
Chile
What is uncoupling?
The cars? or the cars and the loco?
I have no problems with the coupling to the loco.
I have replace the original current conducting couplers with 72021 and they work great
Offline GSRR
#5 Posted : 25 February 2013 03:00:35(UTC)
GSRR
Wayne,
Have you tried the RTS type?
http://www.maerklinist.d...gen/frame-kupplungen.htm
http://www.ralf-bueker.de/RTS_Kupplung.htm
r/Thomas
edit for Marklin E272140
http://www.schnug-modell...auf/Kupplungen/Kuppl.htm
Edited by user 25 February 2013 07:53:59(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by GSRR
#6 Posted : 25 February 2013 07:40:25(UTC)
The tin-plate Rheingold (I presume we're talking 'bout the tin-plate H0 version) uses special draw bars that are shorter. With any other couplers, the distance between coaches will be larger.
See post #3 for a picture:
https://www.marklin-user...0-Merkur.aspx#post185188
Maybe the draw bars are not fully pushed in? Also check that the metal part inside the coupler pocket is in the correct position (sometimes it gets moved out when you push the draw bar in).
Maybe the draw bars are worn and have to be replaced.
Offline Mark5
#7 Posted : 27 February 2013 04:08:18(UTC)
Mark5
What is uncoupling?
Hi Francisco,
Why did you not want the current conducting couplers?
- Mark
#8 Posted : 27 February 2013 09:25:47(UTC)
Märklin close couplers don't work for me if I have a heavy haulage behind the loco, they are great for coupling but when you put them under load the coupling just gives away and slips out of the shaft, the material they made of is to soft and the end bits don't hold them in, what I've done spread them out and insert them again sometimes it helps sometimes it doesn't..
I didn't realize there are added short coupling conversions available from Märklin, I know they've made many different shafts for locos.
regards.,
#9 Posted : 27 February 2013 09:47:37(UTC)
this website has left out Fleischmann electrical couplings, not many modellers are aware of them they exist.
they come as a 2 wire or 4 wire item. if you need a secure coupling these are the ones to get but to put them together is another story, most the time you have to lay the carriages on their head to be able to connect them and the same is with taken them apart you could break your coupling shaft.
I've used some of them (at the time) as they have been slightly cheaper than Roco electr. couplings.
Roco electrical couplings are great, they do fit most the time and are easy to connect or take apart but there have been instances whereas the 4 electrical contacts bend to a position not lining up with the opposite coupling. storing carriages: be careful they don't break
Roco - Fleischmann electr. 4 pin couplings: Fleischmann couplings have just the edge over the Roco couplings when it comes to the space between 2 carriages.
In one of the web links it is shown the conversion of the iron ore hopper carriages from metal to plastic short couplings and shafts, there is a benefit: shorter distance between carriages. I've bought about 50 carriages with the later design (plastic short couplings), yes they fit together closer but the whole mechanism is a disaster. the frame is metal and the coupling is plastic and it has occurred the coupling mechanism doesn't move at all unless you oil it so it can swing from side to side and on this subject I admit metal is better than plastic and they should have left it the way it was (first production) except make the coupling shorter) I also found the wheels fall off (newer version).
regards.,
#10 Posted : 27 February 2013 11:24:57(UTC)
The Flieschmann 2 pole Couplings are a disaster. Unlessyou are super carefull they will fail
have not tried the 4 pole Flieschmann and to me the Roco couplings are very bulky
NN
Offline Lollo
#11 Posted : 28 February 2013 19:39:03(UTC)
Lollo
Krois-Modell make conducting couplers, standard & digital couplers. You can buy from the online shop direct.
http://shop.krois-modell.com/Krois-Modell:::1.html
http://krois-modell.com/produkt/stkupp/
http://krois-modell.com/produkt/digikupp/h0/
Brian.
Brian
Offline GSRR
#12 Posted : 01 March 2013 02:11:27(UTC)
GSRR
regards.,
There is also the Viessmann 5071 four-pole electric live coupler
http://www.viessmann-mod...1c0ae39aa8df9b1138d6dda0
and the Viessmann 5048
http://www.viessmann-mod...f80b251284a9a63171dbf957
Offline Jackson
#13 Posted : 01 March 2013 02:28:02(UTC)
Jackson
All of this information is useful. I will follow up on all of the suggestions. Thanks to all of you for replying.
#14 Posted : 17 August 2023 22:08:59(UTC)
Since H0's link is now dead, as is the first of Brian's downloads, I'm posting another copy of the first article.
Kurz_gekuppelt_01.pdf (1,699kb) downloaded 64 time(s).
This page was generated in 0.813 seconds.
