Offline Kim R
#1 Posted : 13 June 2012 04:21:00(UTC)
Kim R
I live in Australia and I have just started out. I am trying to get hold of a transformer to run my setup and I am aiming to use analogue as I have no modern gear. It is all pre 1980.
Will the new 6647 or 66470 transformers do the job? What is the difference between the two units?
Kim
#2 Posted : 13 June 2012 10:40:40(UTC)
Hi, Kim!
They don't explain. 66470 is called "Sicherheitstransformer" (safety transformer) while 6647 is just a transformer.
Maybe they added protection against reverse transformation (if you feed 16 V into the back of a 6647, you will get 230 V on the blank ends of the disconnected mains plug).
They are for 230 V (+/- 10 %), but probably they are the best choice for the 240 V (+/- 10 %) in Australia. If mains voltage remains below 253 V, you use it within its specifications.
Offline Kim R
#3 Posted : 13 June 2012 11:38:32(UTC)
Kim R
Thanks for that. I found the local dealer only has the 6647 unit anyway. Also it appears that they only put out 14v ac as well compared to the old blue ones that put out a maximum of 16v. I guess that is not a big problem though. A couple of volts less should stress all the components less (eg light bulbs) and increase their lives.
Appreciate the reply Tom. There is so much to learn!!!
Kim
This page was generated in 0.248 seconds.
