Offline Shintaro
#1 Posted : 25 January 2012 03:55:42(UTC)
Shintaro
This is a question for the Au/NZ crowd I guess.
I'm going to order a 60653 MS2 from Germany.
My question is will the 66361 work here in Au (it is rated for 230volts).
The deal I am getting includes 60653, 60113, 66361, for 127Euro (including postage).
This price can't be matched here locally.
The only other extra information I have about the 66361 is:
66361: Switching Power Supply 36VA.
PRI 230 V - 50-60 Hz
SEC 18 VDC - 36 VA
For dry rooms only - INDOOR USE ONLY
And many thanks for all of the help I have already recieved so far.
Marc.
Offline DigitalNZ
#2 Posted : 25 January 2012 04:22:43(UTC)
DigitalNZ
Hi Marc,
It should be fine in either NZ or Aus. Give me an hour or so as we've just got some visitors and I'll check my 60va Trafo. My turntable stroboscope is for 50hz so it should be fine.
Kind Regards,
Daniell
EDIT: My Traffo 230v 50/60 HZ so you should be fine. You may need to use adapter or jet a new plug placed on it though.
Edited by user 25 January 2012 08:10:45(UTC)  | Reason: Not specified
Offline Shintaro
#3 Posted : 25 January 2012 06:42:36(UTC)
Shintaro
Thanks Daniell.
I'll purchase it tomorrow after the mortgage repayment comes out of my account. Cool Laugh
Marc.
P.S. I know I'll need an adapter.
Offline DigitalNZ
#4 Posted : 25 January 2012 08:17:15(UTC)
DigitalNZ
Hi Marc,
You look fine with that Trafo. Our dealer in Wellington also fixes TVs as his main business and he put Kiwi/Aus plugs on our trafos before he gave them to us if they weren't already there. Any local electrical repair shop should be able to do that for you at a hopefully nominal charge! It saves having ugly adapters and solves any potential phase reversing problems if you plug it in the adapter upside down! So glad we don't have that problem down here!
Kind regards,
Daniell
Offline Shintaro
#5 Posted : 25 January 2012 08:47:15(UTC)
Shintaro
Thanks again Daniell.
In regards about an adapter, there is no way around it. If it was a suspended step-down, then yes I would just fit a new plug. But since the transformer is at the plug, I got no other choice.
Have a good week.
Marc.
I attached a pic for reference.
Shintaro attached the following image(s):
Offline DigitalNZ
#6 Posted : 25 January 2012 08:53:32(UTC)
DigitalNZ
Sorry - double post, my router crashed and the data-cap has just blown. Dial up speed for until the 4th!BigGrin
Offline DigitalNZ
#7 Posted : 25 January 2012 08:58:52(UTC)
DigitalNZ
Sorry there Marc, I did look it up and completely forgot about that!
Perhaps it's going back to school next week blues! Hard to believe its my last year!
Have a good week too, you'll certainly be busy with a little one around the house!
Daniell
This page was generated in 0.374 seconds.
