#1 Posted : 17 July 2011 10:48:40(UTC)
after cleaning out some stuff from my build in wardrobes I came across my Berliner railcar.
I thought I sold it several years ago and got a surprise when it was behind all my Märklin Magazine book folders.
So there goes another digital conversion in the near future.
#2 Posted : 17 July 2011 11:09:58(UTC)
That's good news, John!
I've always like those classic tinplate railcars.
#3 Posted : 17 July 2011 12:58:51(UTC)
Here is a photo of the 3017 + an extra carriage
Offline mmervine
#4 Posted : 17 July 2011 18:01:28(UTC)
mmervine
Definitely a treasure! This set is on my wish list.
Offline TrainIride
#5 Posted : 17 July 2011 19:03:33(UTC)
TrainIride
Great model John ThumpUp ThumpUp
I hope I'll find one someday....
Joël
Offline igf2
#6 Posted : 17 July 2011 20:03:44(UTC)
igf2
I am sure you will Joël !
Offline Dreadnought
#7 Posted : 18 July 2011 00:18:52(UTC)
Dreadnought
I had not realised this was MArklin. I have only seen it in the background of pictures of layouts.
Is it the Berlin U bahn? When did Marklin make it?
#8 Posted : 18 July 2011 08:03:20(UTC)
To be precise, it is a Primex production.
It was produced from 1987 and it was offered in the Marklin program under the Hobby version 3128/4187.
Class 275 Berliner Verkehrs Betriebe (BVG)
Length: 40 cm
2 white, 2 red marker lights and with lit destination board
Tinplate
extra middle carriages: 4019
#9 Posted : 18 July 2011 09:16:56(UTC)
It was produced from 1987 and it was never offered in the Marklin program.
That's not quite accurate, John. After Marklin stopped producing models under the Primex label, some of the range was brought back into the main Marklin catalogue.
The Primex 3017 coninued from 1991 to 1994 as Marklin 3128.
RayF attached the following image(s):
Offline Renato
#10 Posted : 18 July 2011 09:54:26(UTC)
Renato
Joël
Hi Joel,
There one listed on eBay:
http://cgi.ebay.it/S11-M...&hash=item1c1b695150
Good luck!
Renato
#11 Posted : 18 July 2011 10:30:06(UTC)
Ray,
you're answer was to quick before I was able to correct it..
regards., John
Offline Markus Schild
#12 Posted : 18 July 2011 11:15:00(UTC)
Markus Schild
Hi John,
The conversion to digital is a liitle bit tricky because of the LEDs used. I would suggest you to bus a second middle-car, then you have what is called a "half-train". Two of these units together made a 8-car "full-train".
You should also think about a second slider on the non-motorized-end and a decoder which can switch the slider.
Markus
#13 Posted : 18 July 2011 11:26:53(UTC)
Markus,
I've just bought another middle-car,
I can't see any problems with the Led's
I have to think about the second slider because of my wiper contact tracks.
I'm in the process of constructing a new way of making contact with the trains wheels to do away with the wiper contact tracks by installing a short track inside to the main track, e.g. like you see on turnouts.
There is another 4 unit train on ebay for Euro 135.00, its not a bad price,, I've paid for the extra carriage almost Euro 30.00
regards.,
Offline Ian555
#14 Posted : 18 July 2011 12:17:31(UTC)
Ian555
Hi John,
Very nice find. ThumpUp
Ian.
#15 Posted : 18 July 2011 12:19:50(UTC)
Markus Schild
Markus,
Hi John,
The five or six LEDs on every side are mounted together with some diodes and resistors on a single circuit-board. With traditional AC-supply they are switched by the diodes depending on the direction of the current. This won't work after converting to digital without modifing the circuit-boards.
That LED-problem is not insolvable but not usual at all for Marklin-models from the 1980s.
Markus
#16 Posted : 18 July 2011 13:49:13(UTC)
Markus,
Hi John,
Markus
Markus,
thanks for the tip.
I have to have another look because I had a 6080- digital decoder in it and I can't remember having any problems with it unless I've changed the circuit-board 3 or 4 years ago,
I just looked at the circuit-board and can only see 4 resistors and 2 connection for ordinary plugs.
I agree with you regarding having Led's in locos especially Primex around this era.
regards.,
#17 Posted : 18 July 2011 22:16:52(UTC)
Date of production Primex 3017 - 1987-89 and Marklin 3128 - 1991-94 (Ray was correct).
Do you have the 4019 extra for 3017?
http://img190.imageshack.us/img190/3125/mearkinss002.jpg
#18 Posted : 18 July 2011 22:24:06(UTC)
Joël
Hi Joel,
Good luck!
Renato
How about this one four car set for less price (Ask seller about shipping to your country).
http://cgi.ebay.de/X6533...&hash=item43a7c6807b
#19 Posted : 19 July 2011 09:13:32(UTC)
Stephen,
and this one from the same seller
http://cgi.ebay.de/X6534...45fb3ef6ae#ht_1153wt_808
please note with the above train set, the seller says: the red colour is slightly different between the carriages.
and this is the middle carriage I bought
http://www.ebay.com.au/i...&_rdc=1#ht_511wt_726
Offline TrainIride
#20 Posted : 20 July 2011 09:47:26(UTC)
TrainIride
Thank you so much to ypou all for finding this wonderful S-bahn for me.
Unfortunatly, I'll go soon on holidays in the south of France,
and I won't order anything now that can be delivered when I'm not home.
Hoping this train wil still be available after my return,
and hoping I'll have some money left..
Joël
#21 Posted : 31 July 2011 12:32:20(UTC)
I will be updating my progress with the S-Bahn railcar later to night.
1.)
Digital conversion
The digital conversion consists of a 60903 conversion set.
A ball bearing will be fitted into the brush plate
2.) Interior lights
Led's will be used for the interior lights and as mentioned before the head & taillights have already been provided with led's.
I will have a led's going through the middle of the carriage as per picture
3.) Roco 4 pin electrical coupling
I was slightly annoyed not being able to separate the carriages from each other (permanent coupling, so this gave me an opportunity to install Roco 4 pi9n electrical couplings,
The 4 pins are ideal for the purpose
1.) blue wire: neutral
2.) white wire: front or rear lights
3.) yellow wire: front or rear lights
4.) Aux 1: green wire: interior lights
the fixed coupling was removed and than I had to come up with an idea how to fix the Roco coupling.
My first attempt was by adding a small double brass plate and fixed it to the current screw hole.
The motorcar, this was a different story as there is no room to extend the coupling.
I had to cut off the clip from the Roco coupling, cut off the loophole of the shaft coupling.
To make sure the loophole from shaft is firmly fixed to the Roco coupling I added again a brass plate, drilled a hole the size of the loophole and than super glued the brass plate onto the loop hole and the Roco coupling.
I was pleased with the end result, looks like it is permanently glued on.
I've retained roughly the same distance between the carriages.
The only thing I've altered on the carriage is the bottom cross bar holding the original coupling bar.
the coupling moves freely from side to side so sharp curves should not be a problem.
When its all finished (more photos) will follow
regards.,
Edited by user 31 July 2011 16:00:55(UTC)  | Reason: Not specified
Guest (2), DefaultCrawler 1.1
This page was generated in 0.817 seconds.
