Offline fadich
#1 Posted : 21 April 2011 21:21:38(UTC)
fadich
I am new to DCC
I have purchased a new startup set from marklin with the new Central station 60214.
By mistake when I was calibrating the stylus pen my hand hit a wrong area and calibration was wrongly set.
and since then i was not able to bring the cursor to the Setup menu due to wrong calibration to recalibrate again.
Is there a way to reach the setup menu other than by stylus, or to reset the CS to out of box status?
i am stuck and not able to do any settings.
thanks for help
#2 Posted : 21 April 2011 21:38:58(UTC)
Use a computer mouse with USB plug to save your CS2. With the mouse you can still reach the Setup menu.
Offline alistairiancampbell
#3 Posted : 20 January 2015 00:48:31(UTC)
alistairiancampbell
Thanks, I had the same issue, you saved my life mate, thanks!
Offline PMPeter
#4 Posted : 20 January 2015 01:23:34(UTC)
PMPeter
Me too a few months ago, by missing one of the 4 corners in the calibration process. After sheer panic I was able to approximate where the setup menu might be and after a few attempts actually successfully got it to launch.
Nice to know that a mouse through the USB port would have saved me a lot of anxiety, or provide me with an easier fix in case this ever happens again.
Offline IanC
#5 Posted : 25 April 2016 17:31:47(UTC)
IanC
Same problem as eloquently described. I was looking for a 'reset' button or similar having somehow screwed it up and unable to get the little arrow to the top of the screen. Panic over, I shall try the mouse and USB port technique. Many thanks and much relief. IanC
This page was generated in 0.558 seconds.
