Offline nohab
#1 Posted : 06 January 2011 19:15:41(UTC)
nohab
I bought an used Märklin loco (3067, Danish Nohab Diesel) with a decoder inside that I don't recognise.
Does anyone recognise this?
Offline Lollo
#2 Posted : 06 January 2011 21:07:39(UTC)
Lollo
Is there any conponents on the other side?, and is there any numbers stamped on it?
Brian
Yaasan's Desktop Station/Railuino & Marklin MS2, DB Era III/IV Diesel & Steam, ESU Loksound/Lokpilot & Lokprogrammer, Marklin mSD, Tam Valley Depot Octopus III Servo Controller.
Offline spitzenklasse
#3 Posted : 06 January 2011 21:18:49(UTC)
spitzenklasse
Greetings, it sure looks like the early 6080 Motorola format. Is the Loco a 3600 series?
These only controlled headlights on/off/reversing front/rear. There was no high efficiency propusion when these were introduced. Circa 1985 through.
Offline Lollo
#4 Posted : 07 January 2011 07:17:55(UTC)
Lollo
It looks like this has been retro fitted, as the 3067 originally is a analog loco with a reversing relay. No electronics at all.
I can not find any thing about that component. Can you post a photo of the other side?
Brian
#5 Posted : 07 January 2011 10:25:40(UTC)
It´s an home madeself decoder...?
Think that has been following by after shat schedule.
But i can see reverse numbers on the PCB and it stand 6080...
#6 Posted : 07 January 2011 13:09:40(UTC)
Is there a chip on the other side that says "Zymos" on it? In that case it's an 80:s 6080 decoder...
Offline pmrenier
#7 Posted : 07 January 2011 16:15:44(UTC)
pmrenier
It looks like the decoder from the 1986-1987 catalog on page 148.
Paul
#8 Posted : 07 January 2011 16:22:19(UTC)
Excellent Paul!
You found it!!!
ThumpUp
Offline nohab
#9 Posted : 07 January 2011 17:00:37(UTC)
nohab
Great detective work !
In the meanwhile I tried to look at the backside, however the decoder was mounted with strong doublesided adhesive tape, so when a pulled it apart the plastic broke...Sad
With the backside "naked" the number and manufactor is easily revealed..
Well, it's not the latest top-notch decoder and now I got even more reasons to replace it
Offline Ranjit
#10 Posted : 07 January 2011 17:07:21(UTC)
Ranjit
Great! A mystery has been solved!
Sorry about the extra work you have to do now, Niclas.
#Get Vaccinated
Offline hemau
#11 Posted : 07 January 2011 23:11:32(UTC)
hemau
Very interesting that this decoder is evidently produced by Blaupunkt, a well known German electronics factory! If they still exist, I'm not sure!. Google tells me they do!
Kind regards, Henk
C and M track; CS1R and 2 MS
This page was generated in 0.941 seconds.
