Offline elsleuth
#1 Posted : 04 January 2005 17:28:35(UTC)
elsleuth
I run c track and wanted to add an arch bridge, so I bought transition track and stuck the bridge and track into my c layout. The loc now stops at the bridge. I traded bridges and got the same result. It looks like the center rail is connected and the side rails are connected. Why?
Offline verheyen
#2 Posted : 04 January 2005 17:52:00(UTC)
verheyen
You have been a member since:: 25/01/2004(UTC)
No clue. I have the same combination, c-track with transition to m-track for the bridge and back again with no problems. You may have a contact issue. Check the connections of the track pieces again. It does work.
[size=1" face="Verdana" id="quote]quote:Originally posted by elsleuth
<br />I run c track and wanted to add an arch bridge, so I bought transition track and stuck the bridge and track into my c layout. The loc now stops at the bridge. I traded bridges and got the same result. It looks like the center rail is connected and the side rails are connected. Why?
Offline rschaffr
#3 Posted : 04 January 2005 18:35:34(UTC)
rschaffr
Yes it does. I use a C to M connection piece for my turntable. No problems.
Make sure the "tongue" of the M track is making contact. If one or the other got bent down it may not be conducting.
-Ron
Offline perz
#4 Posted : 05 January 2005 00:17:20(UTC)
perz
It's the old 360 mm metal bridge, isn't it? I have three of them. On one, trains stop when running slowly. It's a problem in the bridge itself but I haven't found out the exact cause and haven't been able to cure it. I have verified that there is contact out to the bridge even when the train is stopped because of the problem. Luckily, I only need two of the bridges on my layout so I can put the faulty one aside.
Another of the two bridges showed a little bit of the same problems but it worked after careful cleaning. Cleaning didn't help the one with the worst problems but maybe it is a dirt problem anyway.
This page was generated in 0.614 seconds.
