Offline shaygetz
#1 Posted : 15 June 2008 08:04:13(UTC)
shaygetz
I'm sorry if this isn't the right place to ask. I found this for $1 US at a train show today. Its package says that it is made in Austria by a company named UMEX. It's model number is U-310, it is beutifully balanced so it will not tip in any direction and it is called a Liebherr Turmdrehkran 8A. It is intended to be towed behind a vehicle. I'm interested in an appropriate time period and what type of vehicle would have been used to haul it. Any help is greatly appreciated.
"To escape the error of salvation by works we have fallen into the opposite error of salvation without obedience.”
---A.W. Tozer
Webpage... www.freewebs.com/shaygetz
Blog... http://misterbobsmodelworksemporium.blogspot.com/
#2 Posted : 15 June 2008 12:28:00(UTC)
The vehice might have Concrete counter-weights.
#3 Posted : 15 June 2008 21:03:40(UTC)
This is a well know manufacturer of self erecting cranes, used often in building projects.
I have one similar to that right in the front of my house, right now, hauling material for the roof refection (above the room that will house my new layout)!
It would be towed by any construction truck.
In the case of your model, after disassembly, the tower and the jib would be carried on a flat semi trailer, while the mechanism/ power truck would be towed separately.
Hope this helps
Offline MartinB
#4 Posted : 15 June 2008 21:44:58(UTC)
MartinB
UMEX is listed on line 443 in this list.
http://www.ho-modelle.de/php/db_mo_ausgabe.php
They are no longer in business.
Best regards MartinB
Märklin Systems
K-track and C-track
Deutsche Bundesbahn Ep.3
Offline shaygetz
#5 Posted : 16 June 2008 03:54:22(UTC)
shaygetz
Thank you very much for your help. I was really pleased with my purchase when I set it up, the lacy look of the booms really stand out. It will help satisfy my desire for one of those mammoth Kibri units for now.
---A.W. Tozer
Offline Andyroo
#6 Posted : 22 June 2008 02:09:18(UTC)
Andyroo
Here's a link to a review of a Conrad Model in 1:50 of the same crane with a slightly different configuration.
http://www.cranesetc.co....adreviews/1041/1041r.htm
Doesn't really answer your questions, but I thought you might be interested all the same.
This page was generated in 0.579 seconds.
