Offline acwertheim
#1 Posted : 22 January 2008 23:33:33(UTC)
acwertheim
Does anybody know if I can use a 4 degree incline with HO?
or do I need a 2 or 3 degree incline.
Abe
acwertheim
Offline dntower85
#2 Posted : 22 January 2008 23:41:02(UTC)
dntower85
yes and no, with a good heavy loc and a few lite cars you can pull a steeper grade, but pull a a few lit coaches and it might struggle with 4%.
DT
Offline Frostie
#3 Posted : 23 January 2008 00:14:16(UTC)
Frostie
I am using 4% inclines with woodland scenics styrofoam inclines and it works ok.
But most importantly you have to have a smooth even incline. If you have a long locomotive and there are dips in the incline the wheels will just spin.
I am really having some fun on free form inclines without styrofoam to control the rise.
CS/MS Digital Era 1/2
Offline drstapes
#4 Posted : 23 January 2008 00:26:16(UTC)
drstapes
To get the best results for all locos on inclines I recommend a 1mm rise for every standard M track rail.
Geoff (UK)
Offline perz
#5 Posted : 23 January 2008 01:18:11(UTC)
perz
Do you meen 4 % or 4 degrees?
A 4 degree incline corresponds to 7 %, and 7 % is definitely over the recommended, even though many heavy locos will manage it. 4 % is usually not a problem, according to my experience.
Offline kbvrod
#6 Posted : 23 January 2008 03:04:57(UTC)
kbvrod
5% max!And make it smooth,like your approach to women,....
If it gives you a problem,double-head the train,...heck the real railroads do!
Dr Dirt(graded)
#7 Posted : 23 January 2008 03:24:37(UTC)
[size=1" face="Verdana" id="quote]quote:Originally posted by drstapes
<br />To get the best results for all locos on inclines I recommend a 1mm rise for every standard M track rail.
That's a bit over the top, don't you mean 10mm per track. If I used 1mm per M track piece, it would take 100 track pieces on my layout for my inclines to reach bridges 100mm in height, then another 100 pieces to get back down to baseboard level. I don't think I've got 200 consecutive track pieces on my layout.
The Marklin catalogues usually give some details on incline measurements for a bridge at 104.5mm, most of the height changes are around 9mm per track piece, with around 3mm per piece at the start and end of the incline.
Offline TTRExpress
#8 Posted : 23 January 2008 03:29:37(UTC)
TTRExpress
Abe,
We assume you meant a 4% incline rather than a 4 degree one. I would not go beyond a 4%. If you do not feel comfortable making your own incline risers, Woodland Scenics makes a nice set of styrofoam inclines up to 4%. They are relatively inexpensive compared to the rest of the items we buy for our beloved hobby.
Have fun!!
Regards (a Scottish Highlander in Wisconsin)
Offline sudibarba
#9 Posted : 23 January 2008 05:02:13(UTC)
sudibarba
I have to admit I have been to ashamed to ask the question but now will. Does 4 degrees mean like 4 degrees on a 90 degree protractor and does 4 % mean like 4 % of 90 degrees or 3.6 degrees? I thought I was pretty well educated but I guess not. Please define the issue clearly.
Eric
#10 Posted : 23 January 2008 05:17:59(UTC)
4 degrees means 4/360th of a circle. (so yes 4° as on a protractor)It is not usual to talk of a rail incline in terms of degrees but rather in % (or per thousand in the prototype)
4% means for every 100m of horizontal travel the height will change by 4m
so a 45° slope, would be 100% - for every foot you move you also change height by one foot.
Offline sudibarba
#11 Posted : 23 January 2008 06:09:55(UTC)
sudibarba
Thanks as usual.
Interesting, roofing in the USA is on the rise in 12ft. A 4 foot rise in 12 feet is called a 4 pitch roof. Why I brought that I up I don't know.
Eric
Offline sudibarba
#12 Posted : 23 January 2008 06:25:22(UTC)
sudibarba
Not meaning to insult the rest of the world on metric, that means a 4% rise would need 8 feet of run to get a 3.84 inch rise. Clearly, it appears to me that many layouts I see must exceed 4%.
OK
8 feet = 2.44 meter
3.84 inch = 9.75 centimeters
(see how global I am)(humor?)
What do you think - or have I messed this up?
Eric
#13 Posted : 23 January 2008 07:41:38(UTC)
Acwertheim: Sure you can use a 4 degree incline.
The picture I show below is from a time when trains could climb mountains Cool
Many of my trains can climb up to 8-10%, it does however look a bit strange.
Offline al_pignolo
#14 Posted : 23 January 2008 09:32:07(UTC)
al_pignolo
You must also consider if they run straight or you have curves. In my layout I have a long 4.5% sloping, that is straight in the first part, with an R3 curve in the last one. Almost all my locos can run without difficulties on the first (with a reasonably heavy train) but a little more of them begin to skid when reaching the curve, with a passenger train with 5-6 cars.
#15 Posted : 23 January 2008 13:29:01(UTC)
Yes, the curves stress the locos a lot.
One can use up to 10% with no big problems on straights, but this should be halved on curves.
4% on a STRAIGHT will be no problem with most M. lok, even with longer trains.
Own actual layout; pulling 4m long and HEAVY trains up a 2.8% incline on 4-rounds R5 curve: No problem!
Offline acwertheim
#16 Posted : 23 January 2008 15:22:56(UTC)
acwertheim
Yes I meant 4% and not degrees. Sorry about that.
I was planning to by the foam incliners from Woodland and I was not sure if my train (like the Marklin 3 car ICE set 29785)could make a 4% incline.
Woodland says to make a 4% incline you need about 8 feet of space to get to a 4 inch height. A 2% incline needs 16 feet and I don't have that.
Abe
acwertheim
Offline nfotis
#17 Posted : 23 January 2008 18:44:20(UTC)
nfotis
You can combine an incline with a curve/helix, so the ruling grade will be kept low.
This is the reason for loops like Tehachapi, e.g.
Nick the Greek
Offline drstapes
#18 Posted : 23 January 2008 21:56:59(UTC)
drstapes
Bigdaddynz,
"That's a bit over the top, don't you mean 10mm per track. If I used 1mm per M track piece, it would take 100 track pieces on my layout for my inclines to reach bridges 100mm in height, then another 100 pieces to get back down to baseboard level. I don't think I've got 200 consecutive track pieces on my layout."
1 stand corrected &lt;g&gt;I did in fact mean 10mm or the thickness of one of the slim M track bridge supports, I have forgotten the part number.
The point I was trying to make is that a too steep an incline leads to hours of frustrating running. Whilst some of the bigger locos will pull 3 or 4 carriages over a steeper incline there are plenty that will stall. I had to rebuild a previous layout when I made a similar mistake. From memory only I think it took 10 M track tracks to get a suitable incline to go over a normal track with no catenary, however I may be a bit pessimistic. Anyhow the point is,the gentler the incline is the better the running.
Geoff (UK)
Offline Hemmerich
#19 Posted : 23 January 2008 22:39:51(UTC)
Hemmerich
<br />Bigdaddynz,
Hi Geoff,
the bridge pieces you're likely talking about are #7066 (green base plate, 3mm), #7065 (brick pylon, 6mm) and #7064 (brick pylon, 30mm).
So, these Märklin pieces are suitable 6 or 12mm steps on a 180mm track lenght (18mm would already be rather "extreme"), but Märklin too just recommend to use only 6mm.
BTW: Today's C-Track bridge pieces still have those specs (3,6,30mm). wink
Offline drstapes
#20 Posted : 24 January 2008 03:13:42(UTC)
drstapes
Lutz,
Thanks for the info, I was looking in an old catologue which shows the track schematic for bridge building. This recommends a gradient of 5% with less at the end of the approach ramp. Interestingly it advises 3mm,6mm and 9mm increments.This gives a 10 M track rail approach for track without catenary and 14 if you have to clear catenary
Geoff (UK)
#21 Posted : 24 January 2008 03:28:06(UTC)
Point taken Geoff. I'm using 15 1/2 M track pieces for my ramps to clear catenary at 104mm, so that pretty much lines up with what you say. Cheers.
Offline sudibarba
#22 Posted : 24 January 2008 03:36:50(UTC)
sudibarba
This has been a usefull topic for me.
Eric
Offline Tex
#23 Posted : 24 January 2008 21:54:38(UTC)
Tex
I used 4.25 % grades more or less on my previous layout and had no problem with heavier engines like the metal V200 and Class 41 engine but it greatly limited my train length with older and lighter engines especially around curves. My new layout will use a helix with 5200 M track. Limiting the rise per level to 3.5" ,89mm ,which will produce a grade of about 3.25%. the approach section will be about half that amount. This is as tight as I dare make it with 1/4 inch plywood. Does anyone have this close a spacing ?
Tex
Offline Tivvy
#24 Posted : 03 February 2008 08:02:49(UTC)
Tivvy
How long are the trains that you would assume might start causing locos trouble above 4% grades?
I have quite steep grades but at most I will have 5 coach + loco OR 6 car railcars. Is this likely to be problematic? Should I try and re-engineer the grade before I get too far into the construction of the layout?
Ep IV / V Marklin Layout
Under construction.
#25 Posted : 03 February 2008 10:05:56(UTC)
Welcome to the forum, Tivvy.
This page was generated in 1.424 seconds.
